adjusting timing chain 69' 365GT 2+2 | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Waltf, Apr 9, 2014.
  1. Waltf
    Waltf Rookie
    Apr 9, 2014
    12
    I am the proud new owner of a 69' 365GT 2+2. I have the operations/maintenance manual that shows where the adjustment screws are for the timing chain, but doesn't describe how to tell when the chain is properly adjusted. Are there instructions elsewhere or can someone described the method for checking the chain tension. Thanks.
  2. DaveO_48
    DaveO_48 Karting
    Jul 29, 2013
    184
    Henderson, Nv
    David Odland
    Search "timing chain adjuster" or look down the page your post is on in this forum.
  3. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,679
    Romulus, NY (Finger Lakes)
    Ken Battle
    Walt
    Try to find out first if the tensioner is a sprocket type or rubber pad. You can easily find my recent post about tensioners on my 400i, with a pad type tensioner over-tightening may be subtle but increase wear rate of pad.
    Ken
  4. Ashman
    Ashman Three Time F1 World Champ
    Sep 5, 2002
    33,264
    MA
    The engine in a 1969 365 GT 2+2 is completely different than the engines in the 400i series and you should post your request in the Vintage section for best results to your questions.
