Advice needed on strange 360 problem | FerrariChat
Discussion in 'Technical Q&A' started by SoftwareDrone, Oct 6, 2006.
  1. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner
    Jan 19, 2004
    7,870
    San Jose, California
    I turned the knob under the front hood to disconnect battery power while the car sat for two weeks, waiting for the rear grill to get powder coated. Last night I turn the power back on, reset the radio, the car runs perfectly and everything works perfectly except: no cold air from the A/C. I get vents, hot air, temp changes, everything else. I checked the A/C fuse with an ohmmeter and swapped out the A/C relay. Can hear a loud click from the engine compartment when I turn on the compressor (tells me that it's getting the signal).......but no cold air. What on earth could have happened???
  2. fatbillybob
    Aug 10, 2002
    29,241
    socal
    You may be out of freon or any number of things.
    1) take it to mechanic or
    2) put a guage set on it. Turn it on. Report the numbers and we will tell you what is wrong.
  3. SoftwareDrone
    Sponsor Owner
    Jan 19, 2004
    7,870
    Thanks man, I'm putting a set of gages on it before I do anything else
  4. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
