Advice needed on TR Door Grills | FerrariChat
Discussion in 'Technical Q&A' started by Frank512, Oct 29, 2004.
  1. Frank512
    Frank512 Karting
    Jun 16, 2004
    57
    Buckinghamshire, UK
    Frank Marconi
    Can anyone advise me as to how the door grills on a 512TR come apart? We've taken them off the car and now need to take the horizontal slats apart for re-spraying, but I can't figure out how they're attached to the vertical strut that holds them in place. There are rubber plugs at both ends of the strut that (if I prise them off) would let me look inside, but I don't want to risk damaging them until I'm sure this is the right way to go. Any guidance would be much appreciated!
  2. BWS550
    BWS550 Wants to be a mod
    Apr 1, 2002
    8,933
    NEW JERSEY
    BRUCE WELLINGTON
    I HAD A 88 TR AND MIGHT BE DIFFERENT
    ON THE CHAT, GET A HOLD OF 91TR (STEVE) OR HENRY K
    THEY ARE THE BEST TO ASK FOR THIS SITUATION
    GOOD LUCK,
    BRUCE
  3. Frank512
    Frank512 Karting
    Jun 16, 2004
    57
    Buckinghamshire, UK
    Frank Marconi
    For the record, in case anyone is interested, the solution was indeed to remove the rubber seal at the bottom of the vertical strut. Once that's off, you will see the end of a thin aluminium (aluminum for the Americans) rod which runs through the centre of the strut and through the ends of the grill elements, holding them in place
    With a bit of patience, and the help of an assistant, it's just about possible to get a grip on the end of the aluminium rod with a pliers and pull it straight out. Once that's out of the way, the whole lot can be easily taken apart. Reassembly should just be a case of reversing the procedure.
