Advice on 3 in 1 machines? | FerrariChat
Discussion in 'Other Off Topic Forum' started by Mr. Nice Guy, Feb 1, 2009.
  1. Mr. Nice Guy
    Mr. Nice Guy Formula Junior
    Apr 11, 2007
    301
    Southern NH
    Eric
    I was wondering if any of you have experience with 3 in 1 machines? I was considering getting something like:
    Machine #1
    or
    Machine #2
    But, I was wondering that the pros and cons of these sort of machines are - compared to going with a straight milling machine like this.
    Any advice would be appreciated. TIA!
  2. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    I have the same one as you have listed as machine 1.. While it is not perfect it can do an acceptable job if you have the time and the tooling. Perhaps the biggest weak links i find is:
    1. all dials are in metric.
    2. all lead screws have a good amount of free play.
    3. t-slots are 1/2" not the normal 5/8.
    4. not a whole lot of movement of the mill table on the y axis
    5. mill height not adjustable.
    6. Mill spindle is MT instead of R8
    Even though it has faults it is usable. I have made spacers for dial bore gauges with the machine as well as re contour combustion chambers for my jet ski engine. the biggest thing with any of these Chinese made machines is you need to check it out and make adjustments to make sure that the centers are in line on the lathe. You will also have to figure out the proper centering of the cutter bits on the tool post to make sure they are centered on the item you are turning.
    For the price it is not that bad but if i were to purchase another machine i would get one through http://grizzly.com as they are better quality and they support there equipment better than harbor freight does.
  3. Mr. Nice Guy
    Apr 11, 2007
    301
    Southern NH
    Eric
    How about something like this Jet? I know it's not a 3 in 1- but it's R8.
    I checked out the Grizzlys - and they were all MT spindles, what's the real drawback to MT vs R8?
    Grizzly #1
    Grizzly #2
    Thanks again!
  4. beast
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    R8 has a lot more tooling options over MT IE collet holders and such. with a MT if there is vibrations it can release from the taper where as an R8 is secured with a draw bar.
