advice on an attic mounted tv antenna | FerrariChat
Discussion in 'Technology' started by photonut, Jan 12, 2014.
  1. photonut
    photonut F1 Rookie
    4,080
    Michigan
    Joel
    any recommendations?
    i am trying to pull in a digital tv signal from 5 or 6 stations, all are 25-30 miles away.
    i live in micihgan (the area is very flat).
    is there a benefit to an omnidirectional antenna?
    all the broadcast towers are clustered within a 25 degree angle.
    the mount will be 12-14 feet above ground level.
    is there substantial signal loss when the antenna is mounted inside an attic?
  2. JJ
    JJ F1 World Champ
    Jan 6, 2010
    11,362
    PA
    I've had Mohu recommended to me by someone in the industry (who works for a competitor). I had excellent results and keep one around for when sat goes down (like today). YMMV as the results are highly location-specific. Worth a shot.
  3. photonut
    photonut F1 Rookie
    4,080
    Michigan
    Joel
    have you used this in an attic?
    i understand roof shingles can adversely attenuate the signal.
  4. photonut
    photonut F1 Rookie
    4,080
    Michigan
    Joel
    just ordered a winegard hd 1080. $33.91 at amazon.
    will provide feedback after it is installed.
