Advice on my plugs, please. | FerrariChat
Discussion in '348/355' started by RebelBanker, Jun 29, 2008.
  1. RebelBanker
    RebelBanker Karting
    Mar 24, 2008
    232
    #1 RebelBanker, Jun 29, 2008
    So, a couple of weeks ago I noticed a bit of oil leaking from the area where a plug wire boot meets the valve cover. I wiped it off, reseated the boot, and went for a quick drive. When I checked it again, there was nothing. So, I decided to leave it be until I had a chance to tackle the project...
    Well, today I got into it and was immediately taken aback. What do you think?
  2. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Looks like a leaking valve cover gasket........ :eek:
  3. RebelBanker
    RebelBanker Karting
    Mar 24, 2008
    232
    Not surprised to hear... I guess the next question should be: "What all should I attempt to replace while fixing the valve cover gasket?"
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Not that it will fix it (OK, very slim chance), but you might as well tighten down your head/valve-cover bolts just in case there is an easy fix at hand (prior to yanking the motor or replacing gasket in situ).
  5. redryder
    redryder Karting
    May 30, 2008
    100
    usa
    george
    o-ring at that area
  6. RebelBanker
    RebelBanker Karting
    Mar 24, 2008
    232
    I read a thread on replacing the O-rings without removing the camshafts. It required cutting them and re-splicing them. How do you all feel about that method?
  7. redryder
    redryder Karting
    May 30, 2008
    100
    usa
    george
    #7 redryder, Jun 30, 2008
    I'm not really sure of what is causing that much leakage......may be the valve cover gasket as others have suggested. I was simply pointing out that there are at each sparkplug, o-rings'....whether or not these o-rings' have anything to do with oil leakage can be answered,hopefully by one who is more qualified to give an opinion.
  8. plugzit
    plugzit F1 Veteran
    7,790
    Redondo Beach, CA
    Bruce Bogart
    #8 plugzit, Jun 30, 2008
    The only seal between the valve cover and head is the gasket, so it probably needs replacing. Be careful, as they tend to slide around. The good gaskets have a line of sealant on them, so you'll just need to clean the area well. I'm assuming that the oil is on the outside of the plug and only gets on the electrode when it's being removed. If it's in the cylinder, that's not good at all!
  9. redryder
    redryder Karting
    May 30, 2008
    100
    usa
    george
    My aplogizes.......did not realize this was for a 348....355's appear to be a different setup.
