Advice on oil needed for tapping into Alum. | FerrariChat
Discussion in 'Technical Q&A' started by christopher, Dec 3, 2007.
  1. christopher
    christopher Formula 3
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Hey Guys,
    Can anyone recommend the type of oil or wax (or otherwise) needed to tap into aluminum?
    I'll be tapping new threads into the engine block to accommodate a brand new heartier hose water union for my 79 308 GTB.
    Thanks Guys,
    Chris.
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,823
    The twilight zone
    Believe it or not about the best thing out there is WD-40. There is a product call alumtap that is one of the few things I've found that work better, but you won't have a problem with the wd-40
  3. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    Granger is a pretty good generic source for cutting/tapping fluids and sprays. No good machine supply houses around DC anymore. Can't even start up the lathe without hitting a lawyer with the chips but can't go out and buy a ball end mill without driving to Baltimore.
  4. BIGHORN
    BIGHORN In Memoriam
    Sep 18, 2006
    733
    FLORIDA/NEW MEXICO
    JOHN F KELLY
    Nitro brand cutting fluid
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    ROFL!!
  6. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
  7. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
  8. Verell
    Verell F1 Veteran
    May 5, 2001
    7,025
    Groton, MA
    Verell Boaen
    +1
    I was put onto WD-40 as a cutting/tapping fluid by the Mini-Lathe & Mini-Mill guys awhile ago. It really does a great job. Most regular cutting/tapping fluids don't do that well with Al.
  9. miked
    miked Formula Junior
    Feb 7, 2001
    919
    Cincinnati, Ohio
    X3
    tapmagic (aluminum version) is what I use when drilling and/or tapping aluminum in the machine shop at work. A very thin fluid that allows taps to go through aluminum as if it was soft butter.
  10. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    Has anyone tried the tapmagic aluminum as a cutting fluid?
  11. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,823
    The twilight zone
    I've used the alumtap as a cutting fluid and it works very well, but I've never tried the tapmagic
  12. Roadtripguy
    Roadtripguy Karting
    Nov 26, 2007
    53
    I buy all my machine shop supplies right on line. Check out Grizzly, MSC, and littlemachineshop.. Heck, lots of good stuff on eBay as well. Not only do I get my stuff on line, but it is WAY cheaper than the local supply house.
    Just my $.02
  13. christopher
    Nov 29, 2003
    1,136
    Ontario California
    Christopher
    Guys,
    Thanks to everyone that responded to my question!
    Wow, strong ringing endorsements on "Tap Magic".
    Thank you very much Guys!
    Chris
  14. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    I try to by online as well since no one local. www.useenco.com as well for the chinese stuff. Get on the mailing list for hot deals. Haven't heard of Littlemachineshop? I'll have to look that one up. If you are in the mid atlantic you have to go to the Cabin Fever Expo. Look it up online. Sponsored by Home Shop Machinist Mag. Fantastic show. Should be coming up this month. Amazing things people have built plus workshops and vendors.
  15. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
  16. Roadtripguy
    Roadtripguy Karting
    Nov 26, 2007
    53
    I have both a Chinese minimill (which I converted to R8 and CNC), and also a minilathe. They are both inexpensive and wildly popular, and can be bought from a variety of sources. My minmill is from Grizzly and my minilathe is from Micromark (they are another good source also). Under $600 each for the machines, and well worth it for me. I can make pretty much what I need for my cars right at home. (how many times do you need a custom bushing or bracket, or have to tap a PERFECT hole?).
    Naturally, they aren't the best machines in the world, but for the price, they're first rate, and "support" for parts is pretty impressive.
    Littlemachineshop stocks ALL, and I mean ALL of the spares for these machines, as well as a large variety of tooling for them. Chris over there is extremely helpful. Nice company. Good prices.
  17. Roadtripguy
    Roadtripguy Karting
    Nov 26, 2007
    53
    I'm familiar with Cabin Fever. Those guys make some pretty impressive things. WAY out of my league.
  18. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,313
    Black Forest Germany
    Martin N.
    A lot of magic stuff out there, but believe me or not. The best lubrication for tapping or drilling into aluminium is methylated alcohol.
    Best regards from Germany
    Martin
  19. alvin582
    alvin582 Karting
    53
    I haven't tried it before, but my friend recommends me to try the tap magic, and these days I searched some online, found this one
    http://www.dealstudio.com/searchdeals.php?deal_id=71740
    How do you think of it?
  20. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    #20 KKRace, Dec 7, 2007
    I bought this Square Column mill/drill from MSC a few years ago. Enco and MSC are the same company but Enco is much cheaper. I bought this from MSC becuase I wanted the Rong Fu(tiawan ) instead of the clone made in China. I was too cheap to pay for the third axis on the DRO so I made my own out of a cheap digital caliper.
  21. Roadtripguy
    Roadtripguy Karting
    Nov 26, 2007
    53
    Nice rig, and nice size. My mill is a bit limited in X and Y travel due to it's size. This has messed me up on a few non-auto projects (but for my car stuff, it's adequate). For example, I have CNC plans that I drew for a mechanical grandfather clock that I designed, but my machine is too small to cut some of the biggest gears. Bummer.
    I like CNC though. VERY fun to play with, since I converted. The conversion also solved the VERY weak Z axis problem that is common with minimills of my type. I do some custom engraving for a friend who builds custom electric guitars on my machine on occasion, among other assorted projects. My friend is an autocad ACE, and I have the right programs to clean up his drawings, and convert to G code. VERY fun. Some of the best money I think I've spent.
    I'll try to take a few snaps of my rig this weekend.
