Advice On Removing Pin on Camshaft | FerrariChat
Discussion in '308/328' started by Dancia, Nov 21, 2023.
Tags:
  1. Dancia
    Dancia Rookie
    May 15, 2015
    35
    Hi Everyone,
    I'm hoping that some knowledgeable Ferrari fan can give me some pointers. Thanks in advance!
    I have a 1978 308.
    I am trying to extract the pins that retain the distributer drive to the back of the camshafts.
    I tried driving them out with a punch but they didn't want to move. So I paused to consider options and ask for help and advice.
    I have torches - yikes.
    20 ton press.
    lots of little ball joint mini presses.
    Pretty sure I have an oven at home.
    and some other stuff
    I would have put it in the press but I'd have to come up with the correct size of pin drive which might be a pain.
    The reason I'm doing this is because I bought some core cams and had Web Cams make them a bit hotter. The cores did not come with the distributer drives so I am transferring them over from my originals.
    Thanks again for any assistance!
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    You will want to cut a V slot in a block of 4x4 wood, long enough to rest the cam shaft into the V so it does not twist while supporting the pounding pressure. Drill a 1/2 inch hole into the wood block at the location where the pin is so it has a place to fall into.
    Position the camshaft in the V, with the pin facing up. Use a new punch with the appropriate size, and pound away. Heating it with a heat gun may help. I had to drill one out, once.
  3. Dancia
    Dancia Rookie
    May 15, 2015
    35
    Thanks for your help and advice Yelcab.
    I did get them out yesterday.
    It is just a tight interference fit. I was worried about damaging the journals of the hollow cam.
    I had V blocks to support the cam well. After some attempts with a punch I used a press to push them out a bit then finished them with the punch.
    I read on another post here that the spline drives were a solid material in the cam. And that it's an interference fit in to the cam.
    I needed to use a puller to get them out of the cams.
    It all worked out.
    You do need to drive them out in a certain direction.
    On one side where the dowel pin goes through there is a hexagon shape instead of the hole to secure the dowel. Interesting.
    bitsobrits and waymar like this.
  4. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Thank you for the update. Very informative……
  5. Dancia
    Dancia Rookie
    May 15, 2015
    35
    NP I thought so too
