Advice on Sanden A/C compressor | Page 2 | FerrariChat
Discussion in 'Mondial' started by Corradosv, Sep 1, 2022.
  1. Alden
    Alden F1 Rookie
    3,713
    Central Florida
    You can call Gretchen at polar air in Fort Lauderdale she's very knowledgeable, you can also use r12a in an R12 system instead of converting to 134, it's much cheaper than original R12 and seems to work very well, for what I've been told 134 doesn't work as well in our cars is the original R12
    She can be reached at 954-463-6610
  2. 85QVEuro
    85QVEuro Formula Junior
    Jan 15, 2021
    570
    NYC
    Joe
    Had my original sanden 508 compressor rebuilt last fall by Yellow Rose Distributors in TX. Eric Watson was the person who helped me with questions and advice and he was excellent:
    moysiuan and afterburner like this.
  3. greg246
    greg246 Two Time F1 World Champ
    Jun 2, 2004
    26,683
  4. moysiuan
    moysiuan F1 Rookie
    4,239
    Canada
    R12a is an excellent refridgerant, but it is more or less propane, which with any leaks will be an explosion risk. R134 works fine, albeit it leaks through the old style hoses, ideally you have new barrier hoses installed with a 134 conversion. Not sure if the R12a also diffuses through old style hoses, probably not but I have not heard anyone weigh in on that. Most don't mention the R134 hose permeation issue, which requires a top up each year or two.
    I am not aware of anyone who make plug and play replacement hoses, seems like those who do the change have custom work done. I would think there would be a market for hoses that are sized correctly with fittings installed that can be bolted in.
  5. Alden
    Alden F1 Rookie
    3,713
    Central Florida
    From what I understand, the molecules of R12a are larger than R12, so it shouldn't leak thru, the distributor even claims that R12a will sometime seal leaks in older systems.(?)
    Alden
  6. moysiuan
    moysiuan F1 Rookie
    4,239
    Canada
    Interesting, thanks for the information.
