430 - Advice on two potential F430s | FerrariChat
430 Advice on two potential F430s
Discussion in '360/430' started by oc23, Feb 22, 2024.
  1. oc23
    oc23 Formula Junior
    459
    Rob Yo
    Hi all,
    There are two F430s I'm considering purchasing, and as much as I'd like to educate myself from past threads to make a good choice I'm still nervous as a first time buyer. Could I get some of your expertise and thoughts on which one I should go for?
    Car 1: 2005, 30k miles, exact color scheme I am looking for down to the stitching and inserts on the daytonas. Several service records, which show clutch was recently replaced and is probably at over 90%, there was some front bumper repair/repaint along with fiberglass work, and a bunch of other stuff that doesn't seem bad. Previous owner did track it twice, but had it serviced afterwards. Service was done at a very reputable place by this forum's standards. Front seat has decent bolster wear, and some warping on the dash leather. Few paint chips as well but nothing major. Will definitely require a bit of minor cosmetic work, but mechanically seems fine. Seems like original headers but not sure. It has been kept outside however on a lot with a cover the past few months. It's local and I've seen it in person. Can probably get it for 100-105k.
    Car 2: 2006, 12k miles, I like the color combo but regular standard seats (electric though). Seems like it is in great cosmetic shape, with no visible cosmetic issues. Clutch last year or two years ago measured at 40% used (60% remaining) which seems like some high usage for just 12k miles. Only driven 400 miles in the past 2.5 years, kept in garage on a tender. Cold start video seems like it took an extra second to start up, and some white smoke from one of the exhaust tips (not sure if this is a big deal?). Basically no service records. Most likely original headers. Located across the country so not seeing it in person, but have local PPI from a good shop ready to go. Can probably get it for 110-112k.
    I'd do a PPI on either. To the extent it matters, I'll probably convert it to manual right after buying it. And of course, there's always the option 3 which is to forego both and just wait for a better choice to come along.
  2. MichaelMatic
    MichaelMatic Karting
    Dec 19, 2020
    167
    Raleigh, NC
    Michael D
    Being able to buy local is a big plus, but I wouldn’t “settle” just because it was local.
    I was in a similar situation a year ago looking for a car specifically to convert. I looked at many cars and came to the realization that no matter how many service records the cars had or didn’t have, they all had maintenance items/issues that needed to be addressed if you’re anal about your cars (I am).
    Ultimately I decided I wanted a car that was low mileage, had a clutch done recently, at what I thought was a relative deal. I ended up finding just that, but in a color I wasn’t originally looking for (yellow). A year later and the color has really grown on me and I’m very content with my purchase. I guess the advice would be to identify whatever your top 3 criteria are and look until you find what fits that.
    cavlino and oc23 like this.
  3. oc23
    oc23 Formula Junior
    459
    Rob Yo
    Thanks. Other than the cost, was there a specific reason you wanted the clutch to have been done recently?
  4. BlacktopRacing
    BlacktopRacing Formula 3
    1,003
    Pittsburgh
    Dale
    What exactly is your ideal color scheme and type (coupe vs. Spider)??
    I have my red over tan 2005 coupe with 14k miles listed on ilusso for 145k, but I'd sell it to an fchat member for 130k. It's had its 15k factory service done already too. It's near mint and extremely well taken cate of.
    3POINT8 likes this.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,937
    Central NJ
    Dominick
    Just keep in mind that 2006 had a few improvements over the 2006 .. a few around the F1 system. ..
    oc23 likes this.
  6. MichaelMatic
    Dec 19, 2020
    167
    Raleigh, NC
    Michael D
    Yes, I knew that I didn’t want to DIY a clutch and I didn’t have a local shop that I trusted to do the work.
    Finding a car with a relatively new clutch meant that I could convert it using an “F1 fluid based kit” from Cambio Manuale (basically keep the F1 fluid compatible throw out bearing in place and use hydraulic fluid instead of brake fluid) for a much simpler install.
  7. oc23
    oc23 Formula Junior
    459
    Rob Yo
    Small world I've seen your car. I'll send you a PM tomorrow.
    BlacktopRacing likes this.
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Given the age I would be looking at the ball joints, track rod ends, anti roll bar bushing, rear tie rods etc
    Also water pump for leakage at the tell tails.
  9. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,481
    Tough call, seems like the low mile car is a winner on the surface (only paying 55 cents per mile, when I normally allow for $1.50) but the high mile car might be in better condition and is the spec you want.
    I would recommend you got through the PPI process on the local car first to make sure of no hidden issues.
    oc23 likes this.
  10. DutchFerrari
    DutchFerrari Formula Junior
    Apr 7, 2022
    778
    Bollenstreek - Netherlands
    Jeroen
    Id go for car 1 from the sounds of it...
    Oengus and oc23 like this.
  11. oc23
    oc23 Formula Junior
    459
    Rob Yo
    Thanks, that is helpful to know. It was not something that was on my radar before.
  12. CoreyNJ
    CoreyNJ Formula 3
    2,467
    New Jersey Shore
    I agree also. While there were some improvements to the 2006 vs 2005 it’s not as dramatic as comparing a 2005 to 2008.
    The 2005 sounds like it is exactly what you are looking for and you won’t ever regret you settled for a different spec than your dream.
    Either way these are nearly 20 year old cars so they will all need something and 1 year difference isn’t a lot.
    cavlino likes this.
  13. oc23
    oc23 Formula Junior
    459
    Rob Yo
    I appreciate the feedback so far. I honestly thought #2 would get more votes just because of the lower mileage and being in cosmetically great shape. But good to hear the different thoughts.
  14. Oengus
    Oengus F1 World Champ
  15. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    Just something to think about. A clutch is $9000-$10000. Replacing the leather on the dash is $4000-$5000. These are dealer prices, an Indi may be less.
    cavlino, flash32 and oc23 like this.
  16. swc5150
    swc5150 Formula Junior
    725
    Wisconsin
    Scott Calderwood
    I’d go car 1, but look at the recent service records to see what all has been done. Valve cover gaskets are an easy “while you’re in there”, along with motor mounts and trans mount. Ball joints and bushings were likely/hopefully done around those miles too? Car #2 will get expensive quickly if not sorted, so get a good PPI. It’s really not good to let these cars sit. Good luck!
    oc23 likes this.
  17. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,281
    Hard to tell without pics but by the description it seems #1 is a little banged up. If the price difference was greater I'd say #1 and drive the heck out of it but at the prices listed I would say #2
  18. oc23
    oc23 Formula Junior
    459
    Rob Yo
  19. oc23
    oc23 Formula Junior
    459
    Rob Yo
    Well a bit of an update... #2 is no longer in the running. They were both firm on the original pricing (at 120k) and also were not open to any credits or covering anything that popped up at PPI. Given the car hadn't been serviced in years that isn't something I'd want to take on as an unknown.
    However, as luck would have it there's a serious #3 in consideration. Recently serviced, 2007 and pricing is fair. The only thing holding me back on this one is the current owner put on Scuderia style stripes on the car. Does anyone know how hard it is to remove them, and if it would lead to any paint damage or discoloration?
    cavlino likes this.
  20. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,281
    wow this isn't bad at all. looks pretty normal. Heck I'd probably leave the leather as is. If it bothers you there's plenty of folks who can replace it or dye/color the worn spots
    oc23 likes this.
  21. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,937
    Central NJ
    Dominick
    A good cleaning probably will help
  22. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    Are the stripes covered in PPF?
    How long have the stripes been on the hood?
    Do they look good? Maybe leave them there.
    cavlino likes this.
  23. oc23
    oc23 Formula Junior
    459
    Rob Yo
    The front stripes are on the PPF, the hood and rear are on the paint directly. I think about a year or two, car has been garaged. I just can't do stripes :D
    cavlino likes this.
  24. BlacktopRacing
    1,003
    Pittsburgh
    Dale
    I thought you were going to say my car was #3. It's probably the nicest one for sale in the entire country.
  25. swc5150
    725
    Wisconsin
    Scott Calderwood
    If the striped are just vinyl, a hair dryer help will take them off no problem.
    Looks like #1 just needs a good cleaning on the seats and maybe a spray? Leatherique will do the trick. My driver bolster is actually a little worse, and I do my best to not rub against it. Nature of Ferrari leather I think.
    oc23 likes this.
