Advice Please - Car Just Dead When Key Inserted | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by Akajak1, Aug 22, 2020.
  1. Akajak1
    Akajak1 Karting
    Jun 24, 2020
    82
    Wonder if anyone can offer any advice ?
    Car is a California T.
    When I put the key in ignition there is nothing just a blank screen/s; I have to use the key release feature to release the key.
    I put the car on a CTEK conditioner and it reaches the 3/4 full indicator and then generates an error and stops.
    Similarly the Ferrari conditioner gets to 4 or 5 lights then throws an error .
    I garaged the car with the roof down after a long run (just 2 days ago), have I made a mistake doing this ?
    Can't think what the problem is just as dead as a dodo.
    TIA
  2. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Crystal Lake, Illinois
    Alex
    How old is the battery?
  3. ttforcefed
    ttforcefed F1 World Champ
    19,256
    you arent trying to start it with the tender connected are you?
  4. Akajak1
    Akajak1 Karting
    Jun 24, 2020
    82
    Hi Guys, the battery is a couple of years old, on Thursday went for a long drive so was expecting all aok with battery.
    No, I disconnected the tender.
    I'm surprised that nothing is switching on, although I can lock/unlock using the key fob
  5. ttforcefed
    19,256
    never heard of this issue before...try disconnecting the battery and reconnecting. sometimes these cars need a good old fashion cntrl-alt-delete
  6. Akajak1
    Akajak1 Karting
    Jun 24, 2020
    82
    ok thank you, will give it a go, just surprised nothing is switching on
  7. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Alex
    I think there's a thread on the forum regarding the disconnect/reconnect procedure.
  8. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    Just thinking of loud...
    Could it be the key? Have you tried both keys?
    Perhaps the ignition switch is somehow goofed up?
    T
  9. Akajak1
    Akajak1 Karting
    Jun 24, 2020
    82
    just an update; none of the cars key fob functions are now working (tried both sets) so cannot lock/unlock etc
  10. Akajak1
    Akajak1 Karting
    Jun 24, 2020
    82
    the car seems to have just shut down !
  11. SLViper1
    SLViper1 Formula Junior
    Mar 25, 2014
    767
    Nashville/Destin
    Steve
    test battery voltage/replace
    Good Luck
    whatheheck likes this.
  12. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Alex
    Possibly just an anecdote, but not long ago a Portofino owner posted a thread regarding battery issues after the car was stored with the roof in the open position. I always close the roof before I enter the garage (Cali 30 owner). I have no idea if keeping the roof open has any effect on battery drainage, but you might want to keep it in mind.
  13. Akajak1
    Akajak1 Karting
    Jun 24, 2020
    82
    thank you will do
  14. Akajak1
    Akajak1 Karting
    Jun 24, 2020
    82
    F assist coming out to take a look..............
    tomc likes this.
  15. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Alex
    Good news...please keep us posted!
  16. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    As others have mentioned most likely its a battery issue.
    It doesnt have enough power to start the car or even unlock doors.
    Get a new battery. Ensure its fully charged before you install it in your car and your car should fire right up.
    And ensure you follow the battery reset procedure.
    Here it is.
  17. Redneck Slim
    Redneck Slim Formula 3
    Mar 10, 2011
    1,652
    Palo Alto,CA,USA
    Walt Kimball
    With the Portofino,information on roof operation is spread over six pages. There are many warning,but nothing about storing the car with the roof open. If I had a suitable garage I would leave the roof down for months at a time.
    The starting point for your problem is measuring battery voltage.
  18. Akajak1
    Akajak1 Karting
    Jun 24, 2020
    82
    Dear all
    Thanks for the helpful replies.
    F Assist came out very promptly and their focus was immediately on the battery. They found that the negative terminal was not secured correctly . Thankfully a simple fix. They then cleared the engine error codes, asked me to road test (all aok).
    I was very impressed with their prompt response and rectification of the issues.
    I’ve put the battery back on the tender but it seems to be struggling to get to fully charged status. I’ll leave it overnight and check in the morning. A copy of their report is being sent to Ferrari which shows what the issue was and also the detail of the error codes cleared.
    For info the car was returned from the dealership 2 days ago for some faults to be addressed. I shall ensure they have a copy of the F Assist report for their attention.
    Once again thank you all.
    RamsHmb, whatheheck and tomc like this.
  19. RamsHmb
    RamsHmb Formula 3
    1,226
    San Francisco
    James
    So I was going to reply with my fix but u got your answer. I had this exact issue happen to me on my cali t. Drove to the grocery store, parked and when I came out it was dead...zero life. I called f and scheduled a truck. While I was waiting I decided to pop the hood and take a look...the negative clamp had come loose and popped off. Put it back and all was good. I would highly recommend all t owners to check the clamps to make sure they are tight. Too coincidental....
  20. alex
    alex Formula Junior
    Dec 19, 2003
    699
    Alex
    So glad it was a quick fix! Hope your battery was not drained too much by this issue. Thanks for sharing the info with us. We learn from each other (not so much the manual!)
    Akajak1 likes this.
  21. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    Get a new battery. The fact that the battery struggles to take a charge, means that the battery is done. This combined with the fact that Ferrari stock batteries are junk, means that it is just a matter of time before you are stuck somewhere.
    Get a battery suitable for your car, namely a Braille B10049. You are not driving a Chevy Spark, so forget the Interstate stuff. For all intended purposes the Braille is dirt cheap for the level of performance and reliability you get. Do it once and do it right.
    tomc likes this.
  22. Akajak1
    Akajak1 Karting
    Jun 24, 2020
    82
    I have looked but in UK seem difficult to now get hold of
  23. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Ah. Thought you were US based for some reason. I can't get the Brailles here in Europe either, so use Varta Silver Dynamic. So far going strong.
  24. Akajak1
    Akajak1 Karting
    Jun 24, 2020
    82
    Wheels1 likes this.
  25. Il Co-Pilota
    May 29, 2019
    6,023
    A.B
    Wheels1 and Akajak1 like this.
