Advice regarding time belt change, 348 | FerrariChat
Discussion in 'Technical Q&A' started by gredinger, Feb 19, 2004.
  1. gredinger
    gredinger Karting
    Feb 19, 2004
    50
    Sweden
    Peter Gredinger
    Hello All,
    I have just registered and hope to get some good support from all the Ferrari experts on this site.
    I start with a question regarding the time belt.
    Change each 36 month acc. to the book.
    My belt was changed in April 2001, then the car was not driven for 1,5 years.
    Do I still have to change the time belt in April this year?
    I read some postings here in the forum and found comments like "every fifth year is ok".
    Please advice. Thank You.
    Regards,
    Peter
  2. mondial86
    mondial86 Formula Junior
    Nov 1, 2003
    298
    MA
    David Holmes
    I think that the 348 is every 3 years ,this is because the belt runs both cams and is under more stress than the two belt set up of the 308 and 355 and 360 system .Look around at old posts on this subject I know that it has been talked about
    DAVID
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    OK the deal with the belts is, usage. The reason they give dates is, if the car isn't driven much the rubber can get hard and brittle. Kind of like tires on a RV that just sits for a long time. They get hard and crack. Anyway with the belts if that happens, they are more prone to breaking. If the belt busts while the engine is running, then the pistons and valves will hit, resulting in the engine having to be rebuilt. But the bigger problem is the bearings. That is what you should be more concerned with. If the bearings go bad they will freeze and then burn up the cam belt, causing it to break, and you know the rest. If you have the paper work on the last time the belt was changed check to see if they replaced the bearings. If you wanna check the condition of the cam belt that is easy. There are two cam belt cover caps on either side of the engine. They are over the top of the intake and exhaust cam pullies. On each cover there are four allen screws that hold them on to the cam cover. Remove the screws and then take the covers off. You will be able to see the top of the cam belt. As for checking the condition of the bearing, well unfortunately, the only way to do that is to have the engine out of the car. It is really up to you if you wanna push the issue. The belts these days can go over 60,000 miles. My work car is a Acura and the belt has 60,000 miles on it right now. I talked to the guy that works on it for me and he said that the belt still has another 30,000 miles before it needs to be changed. However that car gets driven about 1,500 miles a month. Okay to finish up this novel, LOL. If you drive the car alot, and the bearings were changed along with the belt, I wouldn't loose any sleep over it. If you rarely drive the car, I would change the belt and check the condition of the bearings. Hope that helped.
  4. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    The Ferrari 348 manual recommends changing the timing belt every 3 years? Maybe it does, but I find that one hard to believe. Many, many early 348's are still running fine on the original belt. Granted, 13-14 years might be a bit aggressive, but every 3 years? You've got to be kidding.
  5. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    If you ask Ferrari they will tell you to replace the belts every three years! I also believe that they will last longer than that. But it is certain that the risk of destroying your engine is increased by time and usage.
    Ton
  6. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    I've owned 3 Ferrari's.
    I change them every 5 years regardless.
    My second Ferrari broke the belt
    while I had the car for sale. :(
    I ''assumed'' based on old vague records that it had been done but it had not.
    Cost me $$$$$$$$$$ big time.
  7. gredinger
    gredinger Karting
    Feb 19, 2004
    50
    Sweden
    Peter Gredinger
    Thank you for your information.
    I am driving the car regullarly in the summer time, but in winter time (in Sweden) it is not driven.
    Anyway, I will probably replace the belt after the summer, which means 3 years and 5 months which feels quite safe.
    Of course I will check the condition of the belt (thanks for the description ernie).
    Regarding the bearings: I cannot find any information about these in the book, so are they really replaced in a "normal" cam belt service?
    Peter
  8. juliembre
    juliembre Rookie
    Feb 3, 2004
    1
    madrid
    Peter[/QUOTE]
    They should be. Bearings parts Items #149791 & #149807 around 600$ both.
    If can not drive your car, just let the engine run twenty minutes every week and your belt will be fine.
    BTW, Ferrari Spain recommend four years for 348 belt service.
    Soon
  9. andrew911
    andrew911 F1 Rookie
    2,894
    Northern NJ
    While I agree with you that lack of usage can make the belts get brittle faster than they would with regular usage, I don't know that I would recommend starting the car each week in the winter and letting it idle in the garage. I think that would do more harm than good, as a car doesn't warm up properly with idleing for 10-20 mintues for one, and for the other the car's internals wouldn't fully warm up and you might produce moisture from condensation in the oil, which would never burn off week after week of starting and then turning off. Just my $.02.
    My car (while a 911 not a ferrari) sits for a few months in the winter and I rarely start it at all in that time- I just fill up the tank with gas, put some extra PSI in each tire to avoid flat spots (remember to re-adjust in the spring!), change the oil and put the battery maintainer on the car. Maybe I'll start it up once in the winter, but really that probably doesn't do much in and of itself. The best thing for a car is to be driven regularly, but as we all know that's not possible or desirable when there's road salt on the road. I did finally get the car out this weekend though :) It's been a long long winter this year....
    Good luck gredinger- it's sounds like you'll be OK as long as those bearings are good- I never heard about those 348 bearings before this. It's for information like this that I read this board, so I know what to expect and look for if/when I get a ferrari some day. Great info on this board!
    Andrew
  10. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,837
    East Yorkshire
    Justin Kenyon
    I know many that change the belt evry three years or five years but must at 30,000 miles. Mine is due in May 2004 which will be three years, but only covered 10,000 miles. I will change in the winter of 2004. This feels right for me...
