Advice sought - tyre valve | FerrariChat
Discussion in 'Technical Q&A' started by IanOgden, Aug 14, 2005.
  1. IanOgden
    IanOgden Rookie
    May 28, 2005
    9
    Ibiza
    Hi Guys
    Im stuck on an island off spain - Ibiza. I went to check the tyre pressure on my 550 and the tyre valve snaped right off - instant flat tyre.
    My problem is that there are no specialist tyre shops on the island. The valve looks differet to the norm - am I right or just being paranoid
    Is replacing it a job to be trusted to a local garage or should I have the car collected and trucked to barcelona at great cost !
  2. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    Is this your only mode of transportation? You might be better off shipping the wheel over to a reputable shop. Even if a local can do it, chances are - they will scratch the rim itself.
    The tire just needs to be dismounted, a new valve put in and remounted. Simple process, but the quality of the machine and the installer will determine if you get a scratched wheel or a broken bead on the tire.
