advice- transfer case cover: sealed with a gasket!? | FerrariChat
Discussion in '308/328' started by jimmynail, Aug 27, 2009.
  1. jimmynail
    jimmynail Rookie
    Aug 22, 2008
    17
    Playa Del Rey, CA
    Jimmy N
    #1 jimmynail, Aug 27, 2009
    So the last fool who worked on my transmission sealed up the transfer case cover with some kind of gasket (at least I think this means they were a l fool...). I've got all the bolts off the studs but I cannot for the life of me remove the cover.
    Any advice how to break a soft gasket? It appears to be a red material, but it is very old, hard to tell for sure.
  2. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    hmmmmm, I'm working on a 328 right now that, must be the same fool, used a sh*t load of silicone to seal the bell housing to the block. I had to use a rubber hammer and pry bar to break it loose.
  3. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    Everyone I have worked on had RTV on it also.
  4. jimmynail
    jimmynail Rookie
    Aug 22, 2008
    17
    Playa Del Rey, CA
    Jimmy N
    maybe I'm the fool- I thought the cover was "supposed" to NOT have a gasket?
  5. Steve Magnusson
    26,826
    That's correct -- no gasket. Another possiblility is that the red material is Loctite 518 (an anerobic sealant that is a better choice for close-fitting, metal-to-metal joints than RTV IMO). You probably will just have to get a little "physical" to break the bond whatever you have.
  6. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    That is what I use is Loctite 518. Works great. No it doesn't have a gasket but what I was referring to was caking of rtv. When it is caked on you have to be very careful when seperating the cover from the case.
  7. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    I use a high heat copper gasket sealer, a very thin layer, it all it takes. All you are doing is keeping the dust and dirt out of there. No need to go overboard.
    Wade
