Advise on changing F1 pump | FerrariChat
Discussion in '360/430' started by 993man, Aug 18, 2015.
  1. 993man
    993man Formula Junior Silver Subscribed
    Sep 20, 2009
    878
    New Zealand
    Graham
    My new pump F1 will be here tomorrow, but I only need the motor.
    I was going to just unbolt the motor from the new unit and bolt it up to the old pump.
    But if I swap the complete unit out will it need the SD2 to make it work?
    What about bleeding? Will it need to be bled?
  2. vrsurgeon
    vrsurgeon F1 World Champ Silver Subscribed
    Dec 13, 2009
    16,528
    Charleston, SC
    Curt
    Dude I would just switch the motor... if you bleed it IIRC you need an SD to bleed the system..
  3. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,733
    Just East of Weird
    Bob
    Be careful when unbolting the motor from the pump head. i stripped one of the bolts. end of the swap for me. left the old one in.
  4. 993man
    Sep 20, 2009
    878
    New Zealand
    Graham
    Some thing I would avoid like a root canal without anesthetic.
    The SD2 is a days trip there and back alone.
    Ta
  5. Juri
    Juri Formula Junior BANNED
    Mar 15, 2010
    604
    Houston, TX
    Juri
    Here is instructional video I made describing how to change the electric motor in the F1 pump:
    https://www.youtube.com/watch?v=LdDmbUFOVyc
    If you need more information, send me a PM.
    Juri
  6. jjsaustin
    jjsaustin Formula Junior
    May 11, 2008
    579
    Austin, TX
    Jim
    I switched out just the motor and followed Juri's excellent video. Everything went smooth.
  7. galt
    galt Formula 3 Owner
    Jun 19, 2005
    1,141
    Great video. Thank actually looks as easy, maybe easier, than replacing a battery.
  8. JoaoPedrosasantos
    JoaoPedrosasantos Rookie
    Oct 23, 2013
    24
    My 360 F1 2004 just stall today in the middle of traffic !!
    The f1 pump dashboard light was on,crazy beeping and engine light was also on.
    The engine was dying eveytime i was hitting the ignition key.
    I dont know if its the pump or the relay or something else. After a couple of hours it came back to normal and all lights were off.
    I read that the relay goes bad pretty soon. I dont get gear slipping and i dont know how long the clutch still has left.
    Im scared to take it to Ferrari dealership and get those kind of thousands of Euros clutch service,when in reality i only needs x or y parts changed...
    You see what i mean ?
    Any ideas so i can isolate the problem and have them fix only what it really needs to be fixed ?
    Joao
