Aesthetics of a 355 vs. 360 | Page 2 | FerrariChat
Discussion in '348/355' started by shawsan, Mar 8, 2005.
  1. 4i2fly
    4i2fly Formula 3
    Apr 16, 2004
    1,333
    SF, Bay Area
    Let me just add that the efficiency of HP/torque delivery to the rear wheels are much greater with 360, so typically you would see as much as 40 HP more with the 360. Also max torque for 360 happens much earlier in the RPM range than in F355 and is again more than 30 lb.ft more. Also when the variable intake rail change to deliver more HP and Torque the delay in reaction is well pronounced in F355 and almost transparent in 360 around 5500 RPM. These are some of the specifics that I have noticed can make the car lazier than 360.
  2. JERRYZ
    JERRYZ Formula Junior
    Sep 1, 2004
    662
    Orange County, CA
    I'm still in love w/ my 355 Spider and I agree that it has the classic Ferrari lines in it. However, it is starting to look a little aged only because of the pop-up headlights. I love the rest of the car's styling, particularly the side vents on the doors. My favorite part of the 360 Spider is the raised bevels behind each seat that frame the roll bars. I foresee a 360 Spider in my garage once they take the big depreciation hit in a couple of years due to the 430's emergence.
  3. W00dEar
    W00dEar F1 Rookie
    3,592
    LI, NY
    Chris
    #28 W00dEar, Mar 10, 2005
    Exactly.
    the rear end of F355 is just beautiful. low and wide. the side profile is great too, love the door vents. just the front is dated, with the 90's pop-up headlight.
  4. W00dEar
    W00dEar F1 Rookie
    3,592
    LI, NY
    Chris
    my 2 cents:
    to me, F355 drives alot more like a real sports car, u sit very low, for crying out loud i need to supporting my arm on the door step to get out. the sound is amazing. the cockpit in simple. basicly u feel like you are operating a serious piece of driving machine.
    however, one reason that made me looking into 360(i eventually went for the CS), is that i feel the F355 is not holding up under aggressive driving condition. in all honesty, it is a 10 yrs old car(i have a '95), some components might not be up to today's standard of a sports car. the steering feels light at high speed, the brakes does not give me confidence at high speed.
    thus, i think 355 drives more like a sports car, but 360 has better performance and gives more confidence when u push it.
  5. shawsan
    shawsan Formula 3
    Jul 2, 2004
    1,090
    Vancouver, Canada
    When I started this post, my main interest was to compare the aesthetics & styling of the 355 vs. 360 – largely a subjective assessment, I admit. Many of the posts, however, went a tad further by comparing performance. So, in the interests stimulating a bit more discussion, let me pose the following. Assume you’re a 355 lover on aesthetics, but are drawn like a magnet to improved performance, especially acceleration and cornering. You'd therefore wonder just how much a 360 really outshines the 355.
    The answer seems obvious to the 360 owners but, hey, wait a minute. Let’s compare the cream of the crop, a 98-99 355 F1 Spyder and a 360 Spyder – just like the beauty posted by Vdavie in this discussion. After culling a lot of sources, I come up with the following.
    The 355 F1 Spyder weighs in around 3100 lbs (curb weight), has 375-80 HP at 8250 rpms, 268 ft/lbs of Torque at 6000 rpms, and can zip from 0-60mph in around 4.6 secs and ¼ mile in about 12.9 secs. Remember, I’m describing the F1 where fast shifts helped restore 0-60 times closer to the best 1995 performers.
    The 360 F1 Spyder weighs in around 3200 lbs (curb weight), has 396-400HP at 8500 rpms and 276 ft/lbs of Torque at 4750 rpms (thus more grunt at lower rpms), and can zip from 0-60 in 4.5 seconds and ¼ mile in about 12.6-12.7 seconds.
    Now, let’s help the elder statesman – the 355 – a bit. Let’s install a Tubi which purportedly increases HP by about 10 units for around $4k. And let’s install a Powerchip which purportedly jolts HP up another 25 units and torque about another 20 for around $3k. And let’s replace the 225’s on the front with 245/55s and let's put 295’s on the back wheels (another $1.5K). No need to worry more about skidpad prowess as the 355 Spyder does about as well as the 360, both coming in between .96-.98 (correct me if I’m wrong).
    My hunch is the elder statesman will be slightly ahead of the 360 Spyder in a 0-60 and ¼ mile dash. And you’ll be doing it in a car that costs about 30% less. That sounds like 'value for money' in addition to the aesthetics.
    (BTW: check out this source for an a seemingly comprehensive list of Ferrari's and performance, year by year). http://www.conceptcarz.com/view/vehicle.aspx?carID=1390&optionID=0
    (And ps to davehanda; thanks for the invite to join the seattle group; just might make it; otherwise North Van Italian car show is a certainty. Do I presume correctly that your BMW 540M is one of the rare Canadian V8 imports with M5 package? And if so, neat! and what color?)
  6. W00dEar
    W00dEar F1 Rookie
    3,592
    LI, NY
    Chris
    1) there is no question that 355 is better bang for the buck. u can 95% of performance with 70% of price. although keep in mind, performance is not just 0-60 and 1/4m. i have a '95(they call it the faster yr), i have tubi and decat, i am pretty sure i can run with a 360 easily. but suspension, handling, braking, i am no where near a 360.
    2) i dont think the mods add that much power. a chip for 25hp? then ferrari should have used that chip from the factory.
    3) cant compared modded to stock. what if the 360 gets a tubi and remappin as well :D
  7. husky
    husky Karting
    Feb 13, 2005
    136
    Hong Kong
    Patrick
    agree, i think the rear end of 355 look particular neat esp with the challenge grille !!!
  8. husky
    husky Karting
    Feb 13, 2005
    136
    Hong Kong
    Patrick
    Absolutely !!!! you can read my mind
  9. Koby
    Koby Formula 3
    Dec 14, 2003
    2,307
    The Borough, NJ
    Jason Kobies
    That is a great analysis, I never looked at it this way, and believe me I've given this a lot of thought.
    Although I go back and forth, I'd have to give it to the 360, just for all the brilliant details that you don't see right away. For example the rising accent line that starts as the top of the front bumper and wraps around the car all the way back to the tail, amazing.
  10. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    Well, for starters, your weights are off. The 360 is roughly 200 lbs lighter than the 355. From the 360 sales brochure: "The exclusive use of aluminum has enabled Ferrari engineers to reduce the 360 Modena's weight by 100kg compared to the F355...". I don't have the figures in front of me, but I would guess the 355 Spider would be closer to 3400 lbs. And in every road test I've ever seen, the F1 gearbox is virtually identical to the 6-spd in acceleration times. The real advantage is in consistency, not outright acceleration.
    Gary
  11. 4i2fly
    4i2fly Formula 3
    Apr 16, 2004
    1,333
    SF, Bay Area
    Shawsan,
    I have to make a couple of points:
    1. I have driven both F355 and 360 Modena and there is no comparison in ride quality, handling and pure exhilaration. 360 feels like a thoroughbred just wants to GO no matter what gear.
    2. Both spiders are gorgeous but I would not rig them for sustained high speed maneuvering. I have driven a 2001 spider and even though there is a lot of rave about its chassis being rigid I still find it too uncomfortable push it around the bends compare to the coupe.
    Also, no one is putting F355 down (10 year old technology), you can rig F355 to be more powerful than F430 but when it comes to using the power on the road as WoodEar explains it is much easier to handle a F355 than a 360.
  12. TexasF355F1
    73,083
    Cloud-9
    Jason
    YES! The challenge grille, in my opinion, is the best look on all...
  13. shawsan
    shawsan Formula 3
    Jul 2, 2004
    1,090
    Vancouver, Canada
    You're probably right Gary that the 360 Spider is a few hundred pounds lighter than the 355 Spider. But it's amazing just how difficult it is to nail down a 'correct 'dry weight' vs. ' curb weight', vs. 'laden weight', etc. And some sources are confused about differences between these terms and use them interchangeably. For example, sources I consulted revealed the following disparate weights reported below.
    Let's assume the weight given in MY MANUAL of 3,340lbs is correct. It's a bit more than the Road & Track weight for a 98F1 of 3,290 lbs, but both estimates are closer to your guestimate of 3,400 lbs than the 3,000 lbs one often sees reported for tb, ts, and spider. Would you be so kind as to check YOUR MANUAL to see what it says for your 360 Spider. It would be good to confirm the anticipated 200lb difference based on our actual MANUALS.
    Thanks, Paul
    Euro Sources:
    -- UK 1994-98 355 Buying Guide: Berlinetta (2976lbs) Spider (3100 lbs)
    -- Ferrari Manufacturer’s 355 Sales Brochure: Berlinetta + GTS (2976lbs)
    -- Any citation of “manufacturer’s data” in Europe or in North America : (2976lbs)
    US Sources:
    -- Car & Driver, March, 95, 355 Berlinetta (3268lbs)
    -- Car & Driver, November 95, 355 Spider (3380lbs)
    -- Road & Track, July 98, 355 F1 (3290lbs)
    My 1998 355 F1 Manual (Car sold in Canada)
    -- Berlinetta (3,262lbs)
    -- GTS (3,284lbs)
    -- Spider (3,340lbs)
  14. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    I've got a coupe, not a Spider, perhaps someone else will chime in. I agree there is a lot of confusion over the terms dry weight, curb weight, etc, but when Ferrari says the 360 is 100kg lighter than the 355, I assume they are comparing apples and apples, and the figure probably applies to the Spider as well as the coupe.
    Gary
  15. W00dEar
    W00dEar F1 Rookie
    3,592
    LI, NY
    Chris
    360 is all aluminum, sounds about right.
  16. bumboola
    bumboola Formula Junior
    Mar 7, 2003
    625
    Forget what Ferrari literature states, it's pure bull****. The 360 coupe and 355 coupe weigh virtually the same, The 360 spider weighs more than a 355 Spider mainly due to the top mechanism. The earlier models weigh less than the later models in both cases.
  17. tonyh
    tonyh F1 World Champ
    Dec 23, 2002
    14,372
    S W London
    Tony H
    My '96 Spider weighs in @ 3174 lb according to the manual.....
  18. Prancing Horse
    Prancing Horse Formula Junior
    Nov 2, 2003
    532
    This a particularly interesting thread for me since I am in the throes of deciding between the 355 spider or the 360 coupe. I personally love the lines of the 355 spider and think it's cleaner than that of the 360 spider (the hoops just don't work for me). On the other hand, I still remember the first time I saw the 360 coupe in the flesh- a bright red piece of moving art in a sea of yellow cabs in SOHO NY. I was convinced that this was the best looking Ferrari post the Dino.
    Nevertheless, I love top down driving and started a mini search for a 355 spider about a year ago and have learned an enormous amount from this site. Unfortuntately, I'm nervous making a move on a 355 spider as my first Ferrari given the well established issues and the painful fixes to get the car really right (e.g. exhaust manifolds replaced by those from QV/ London). The 360 so far appears to be more reliable, arguably better performing, and more "current" given its clear presence in the 430. Prices are also dropping within striking range (9 iron-ish) of late model, good example 355 spiders. So I'm leaning 360 coupe.
    Thoughts?
