Affordable 16" replacement wheels for Mondial 390s? | FerrariChat
Discussion in 'Mondial' started by rolindsay, Nov 13, 2008.
  1. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    Anyone found an affordable replacement wheel, 15", 16" or 17", for the 390mm size Mondial wheels?
  2. Argento839
    Argento839 F1 Veteran
    Oct 21, 2005
    9,103
    Rick, I'm not sure if this is in your price range but Superformance makes 16" Mondial wheels. I've never seen the Mondial wheels in person but they look pretty good from the pic on their website: www.superformance.co.uk BTW, you can probably buy through Rutlands as well.
  3. Steve Magnusson
    26,826
    #3 Steve Magnusson, Nov 13, 2008
    Define "affordable".
    Are you saying that 348 wheels or the Superformance Mondial 16" reproductions aren't affordable enough?
  4. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    +1
    When I was looking to replace my TRX's, I found a couple of companys charging about $250.00 per wheel. I could drudge them up, if that is your ball park. That being said, I still think the 348 wheels are the best--and most economical swap on the Mondial. I bought a set of 4, w tires for $750.00.
    Note: If you are going the 348 wheel route, make sure you get 58mm bolts in front and 55mm in back. You can get 60mm bolts from H&R for 7 bucks a bolt and have a machinist cut them down for 20 bucks. The 55mm 348 bolts are too short in front for my comfort.
  5. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    In another thread, someone stated that certain Volvo wheels have the correct bolt pattern but the center hub hole was too small. If that's the case, then pick out a Volvo aftermarket wheel that you like (with the correct offset) and have the center hole enlarged. The machining costs should not be more than $35 each wheel.
  6. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    And then be sure to never take the car out in public ;)
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Did it just get cold in here?
  8. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Change the emblems and most people will not know the difference, including most Ferrari owners. And for those that do know, they will also know that you are not "proper" because you don't have the original 390mm wheels on the car. Once you leave the stock / concours world, the only limitation is your taste and $$$.
  9. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    True, true, just please don't forget to change the emblems ;)
  10. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    A car is a object that should give the owner maximum pleasure - whether it's concours, racing, or just taking a Sunday drive. In my case, my 308 is so far from stock that concours committees send me trophies to NOT show up. So put on whatever wheels that work for you.
  11. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    Steve looking at Rick's note I would think he is looking for wheels that are competative in price to what can be found at Tire Rack or other speed/wheel shops. Other then the F cost driver in Ferrari the cost of wheel should fall in the $150-$300 range . I believe that the replica's are running at $2000 a set which may put them out of a lot of 308 owners price range. So if you go with a middle of the road wheel/tire combination it should cost you around $1200 for the whole deal. I would think that if someone came up with a wheel/tire package in that price range a lot of folks with 14" and 390mm wheels would buy in. Just my thoughts here.
  12. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    goto thread 3x8/mondial aftermarket wheels and look at the possiblities anything will fit from 16 to 19 and look DAMN good
  13. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    Unfortunately, due in part to the unique Ferrari bolt pattern, I could not find any inexpensive (quality) options out there. Personally, the cheapest I found new-were $250.00 a wheel. With a set of Kumho's you may get out the door for $1400 total, but it won't be easy. If you do find something good for cheaper, please post. I am sure a lot of TRX owners would be interested in hearing some new options.
    Good luck in the search!
  14. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    #14 350HPMondial, Nov 14, 2008
  15. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    that's a good one ... mind if I use it?
    cheers
  16. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    That's a great deal.
    Word of warning: if those are the original Goodyear Gators you may want to put on new tires.
  17. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    #17 pad, Nov 14, 2008
    LD, be my guest. No copyright infringement.
    What is do is send the judging committee a picture of my car, and they send me the trophy and usually a notice stating the the show has been changed to a new location (they never stay where, however). Over the years, I have gather a wall of trophies this way.
  18. luckydynes
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    cool now I'm acutally looking forward to the Concorso (or whatever that gathering is near Monterey ;))
  19. Steve King
    Feb 15, 2001
    4,367
    NY
    Joe the bolt pattern is not the problem. Ther are other cars that have a 5x108mm pattern . It is the offest that is the issue. If you can get something close it's not a problem. I don't recall the offsets but seem to remember that it was discussed a while back. Maybe doing a search will get the info if anyone is interested.
  20. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,459
    Philly suburbs
    Joe
    My memory is a little hazy now, but I think you're right. Either way, I had a bear of a time trying to find inexpensive aftermarket wheels for the car. Most aftermarket manufacturers were a no go at anything approaching reasonable. In the end, I still think the cheapest and best way to go is to find some used non-metrics from another Mondial or a 348.
    BTW, if someone ends up finding nicer wheels than the 348's at a better price, just know that you will be ruining my day- I hope you can live with that ;)
  21. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    Rick here again; I've purchased new 16" Mondial wheels from SuperPerformance in the UK. Onto those wheels I'll mount the General "Exclaim UHP" tires (245/50ZR16) I also ordered. This turned out to be the closest to stock solution - and surprisingly, the cheapest!
    Thanks to everyone for the kind suggestions.
    rick
  22. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Rick - let's see some pics!!!
  23. Steve King
    Feb 15, 2001
    4,367
    NY
    I did a quick look in the search section and from what I found the 308 wheel off-set is +10.95 MM (positive). Most people use 11MM so if you contact a few wheel manufactures and ask them for all wheels that have 5x108 with a 10-15mm off-set you may be able to find wheels to your taste in the $150-$300 range. It would be interesting to see what range you could go with off-sets without effecting the geometry. Just my thoughts.
  24. brettski
    brettski Formula 3
    Feb 29, 2004
    1,754
    north of toronto
    brett swaykoski
    #24 brettski, Nov 16, 2008
  25. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Looks really good - what tires did you decide to use?
