348 - after engine out issue | Page 2 | FerrariChat
348 after engine out issue
Discussion in '348/355' started by joshtownsend, Aug 28, 2024.
  1. joshtownsend
    joshtownsend Formula Junior
    Jul 12, 2007
    422
    H-town...TEXAS
    Update... well i got both of the crank sensors right at 0.35. moved the spacer to the top sensor, assuming that's the 1-4 and the bottom one, assuming that's the 5-89, i had to sand it down a little bit to get it to 0.35. I didn't have another spacer. Started the car and the 4114 code went away....
    BUT....
    The 1113 code returned!!! Whats gives? I thought that TB sensor i replaced fixed it but its now back on. Guess ill let the car sit over night with the knob turned off and start it again fresh tomorrow tom some time unless there is another thought.
    Qavion likes this.
  2. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,598
    Ian Riddell
    Never assume...
  3. joshtownsend
    Jul 12, 2007
    422
    H-town...TEXAS
    Very good.. at this piont, 4114 has went away and 1113 has surface again.. puzzling as to why it would do that..
  4. Qavion
    Feb 20, 2015
    14,598
    Ian Riddell
    Is there any adjustment for the TPS on the 348? On my F355 the screw slots/holes in the TPS base allow for slight movement to get the TPS resistance values back into the required range.
    Do you have the resistance range for the 348 2.7 TPS?
    Note that an improperly adjusted throttle cable may not allow the throttle quadrant to go to its proper idle endstop.
  5. Qavion
    Feb 20, 2015
    14,598
    Ian Riddell
  6. m.stojanovic
    m.stojanovic F1 Rookie Silver Subscribed
    Dec 22, 2011
    3,307
    Serbia - Niš
    Miroljub Stojanovic
    According to the 348 WSM, the TPS balancing is done by the voltage measured between ECU pins 53 and 19 (ground). As this is not easy, I measured the voltages on the TPSs as follows:
    Left TPS - between Pins 1 (ground) and 3
    Right TPS - between Pins 2 (ground) and 3
    Instead of tapping into pins 1 and 2, it should be ok to simply measure the voltages on the TPS Pins 3 and a good ground point. The mounting holes on the TPSs are not slotted but they allow small adjustment. If the difference between the left and right readings cannot be brought to within 80 mV, the reason could be too much difference between the gaps of throttle bodies butterflies or because the butterflies are not fully returning to their stops when in idle position. Extract from the 348 WSM:
  7. joshtownsend
    Jul 12, 2007
    422
    H-town...TEXAS
  8. Qavion
    Feb 20, 2015
    14,598
    Ian Riddell
    Is the old one any better?
    Is there anything impeding the return of the accelerator pedal?
    You may need specialist help. Adjusting the mechanical linkages may allow a lower voltage setting on both sides, but you may upset the airflow balance between the banks.
  9. joshtownsend
    Jul 12, 2007
    422
    H-town...TEXAS
    It's definitely mechanical as I swap the old one and it gave me the same reading. Then I swap the left and the right one and the reading stayed on the same side.
    Were going figure this out one way or another ..haha
  10. m.stojanovic
    Dec 22, 2011
    3,307
    Serbia - Niš
    Miroljub Stojanovic
    It is not adjustment of the linkage but adjustment of the butterfly stop that will change the position of the TPS at idle and, consequently, change the voltage reading on the TPS Pin 3.
    As stated in the above extract from the WSM (see the first para), the correct adjustment of the butterfly stop is when the gap between the butterfly and the housing bore is 0.02 to 0.05 mm.
  11. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
  12. Qavion
    Feb 20, 2015
    14,598
    Ian Riddell
    Does this adjustment affect just one bank or both?
    At what point do you have to start playing around with vacuum gauges and such? Is this only for balancing individual throttle bodies, not banks? I couldn’t find a procedure for the 2.7 (348).
  13. m.stojanovic
    Dec 22, 2011
    3,307
    Serbia - Niš
    Miroljub Stojanovic
    Setting the butterfly gaps (openings) at 0.02 - 0.05 mm via their stops does not balance the banks and does not set the idle speed. The mentioned gap means almost fully closed butterflies and the gap is there to prevent their binding in the bore. It also sets the TPS at 400 - 600 mV at idle position (this is what I observed on my 348). The gaps are set at the factory and should not be altered but, sometimes, they are unnecessarily changed to larger butterfly openings resulting in too high baseline voltage readings at the TPSs which may "confuse" the ECUs.
    Adjustment of the linkage is only for the purpose of getting both, left and right, butterflies to start moving off, and return to, their stops at the same time. As it is not very easy to observe the starts of movement of the butterflies from the idle position, I adjusted my linkage by listening to the "clicks" as the butterflies hit their stops when I quickly release them to idle position.
    After the above "geometrical" adjustments, comes the setting of the air bypass valves on the throttle bodies. On my 348, I found that 1 to 2 turns of the adjuster screws out from fully closed works fine. Positions of these screws set the baseline for the Idle Control Valves (ICV) from where the valves control the idle speed. I did not notice any difference between having the bypass screws at 1 or at 2 turns out. This is because the ICV ultimately sets the idle speed - with smaller opening of the bypass, the ICV will open more at idle, and open less if the bypass opening is bigger. This is why the idle speed cannot be changed by changing (within the reasonable range) the openings of the bypass screws, unless you open them so much that the ICV is no longer able to control the idle speed. In such a case, the ICV may fully close but the large amount of air flowing through the wide open bypass may still keep the idle speed to high.
    So, for the "joshtownsend's" adjustments, I would recommend the following procedure (In the absence of the Ferrari special tool):
    1. Disconnect the battery, remove the throttle bodies, check the butterfly gaps and adjust to 0.02 - 0.05 mm if required. Verify that the butterflies hit their stops when in closed position and that they don't bind. Take this opportunity to remove and clean the bypass screws and their orifices.
    2. With the linkage disconnected from the throttle bodies (or making sure that the linkage is not preventing the butterflies from hitting their stops), check the voltages on the Pin 3 of the TPSs. If they are out of the 400-600 mV range, small alterations can be made by twisting the TPS (as allowed by the holes) before tightening the screws. If a bit more rotation of the TPS is required, I would file the holes as needed. At the same time, ensure that the voltage difference left to right is no more than 80 mV. On my 348, I managed to set both TPSs at 480 mV, i.e. zero difference left to right, but this is not necessary.
    3. Connect the linkage and adjust it so that the butterflies start opening (or close) simultaneously.
    4. Set the bypass screws at, say, 1.5 turns out. Connect the battery and perform the "re-learning" procedure: with everything "off" start and run the engine, at idle only, for about 15 minutes. During this period, you will notice idle speed fluctuations as the two ECUs are synchronising the idle speeds of the banks.
    Qavion likes this.
  14. Qavion
    Feb 20, 2015
    14,598
    Ian Riddell
    I'm still not too sure of the geometry of the system on the 348. The parts manual doesn't really show you what's happening. Will or won't the TPS's go to 400~600 mV if, say, the throttle cable is too short or something above the accelerator pedal is stopping the pedal returning to idle? When I replace a frayed cable on my 355, I wasn't sure of the procedure, so I simply made sure that the quadrant went through full travel (and hit its endstop). The TPS value was still too high. The ECU seems happy, so I am happy :D
    I wish this subject had come up earlier. I would have asked my tech to fix it up for me. I don't want to do any filing of holes until I know my butterfly gaps are ok. The idle rpms are ok, so the IAC/ICV is doing its job.
    It was noted on the 550 forum that incorrect cable adjustment was leading to power loss. Power was restored by adjusting the cables.
  15. m.stojanovic
    Dec 22, 2011
    3,307
    Serbia - Niš
    Miroljub Stojanovic
    These would be abnormal conditions and would need to be fixed. As mentioned in the first paragraph of the extract from the WSM I attached earlier, the voltage reading of 400-600 mV assumes that nothing is preventing the butterfly from sitting on its stop at idle position. Of course, if the butterflies are prevented from returning to their stops by tight (no slack) cable, or sticking pedal etc., the voltage reading will be affected. Trying to adjust the TPSs in such a situation would be pointless.
  16. joshtownsend
    Jul 12, 2007
    422
    H-town...TEXAS
    Alright, i have concluded there is an issue somewhere else causing this issue. I followed the instruction and here is what i did.
    Took the TBs off and measured the gap. I didn't really realize how thin 0.02 mm was til i could find one. So i used 0.038mm.. best i could find. I adjusted both TBs to this and cleaned out the air vent.
  17. joshtownsend
    Jul 12, 2007
    422
    H-town...TEXAS
    I used the screw in the picture to do so then put silicone so it wouldn't back out. Picture are more for someone to find later it may help to locate it easier.
  18. joshtownsend
    Jul 12, 2007
    422
    H-town...TEXAS
    I then installed the back, linkage is tight but not forcing anything open and measured between the 2 colored wires with the car ignition on. This is the "good side" 5-8. Closed its measure 0.641 and wide open it measured 4.41
  19. joshtownsend
    Jul 12, 2007
    422
    H-town...TEXAS
    on the 1-4 side which im am throwing the 1113 code, i get closed 0.958 and wide open i get 0.144. I swap out sensors and it was still the same, so 3 different sensors give the same reading.
    At this point, i believe something is causing the reading to be messed up . Could this wiring be grounding out causing false readings?
  20. Qavion
    Feb 20, 2015
    14,598
    Ian Riddell
    As you are backprobing the connectors on the car side, I suppose a high resistance at the connector pins/socket could cause a higher voltage reading. The higher the resistance, the more the voltage drop (assuming the internal resistance of the ECU remains the same). I can't remember if you tried cleaning the pins/sockets.
    The ECU on the faulty side could be putting out the wrong voltage leading to a higher mV reading. What happens when you swap ECUs?
  21. ernie
    Nov 19, 2001
    22,627
    The Brickyard
    The Bad Guy
  22. m.stojanovic
    Dec 22, 2011
    3,307
    Serbia - Niš
    Miroljub Stojanovic
    The left and right TPSs rotate in opposite directions, one turns clockwise and the other anticlockwise. This is why at WOT, if connecting your voltmeter to the same pins left and right, you get 4.41 V on one and 0.144 on the other. To compare the left and right readings correctly, measure the voltages as I informed in post #31 and you should get low voltage at idle and high voltage at WOT on both sides.
    However, you do not need to bother with the voltages at WOT just take the readings at the idle position. If you took the idle readings of 0.642 left and 0.952 right on the pins as I mentioned in the post#31, then, obviously, they are still both outside the specified range, the right one very much so. it should not be difficult to bring the left reading to below 600 mV by some filing of the TPS mounting holes but the right one needs further investigation:
    First, make sure the grounding points on your cylinder heads (2 at each timing cover) are clean (not tightened over paint) and not loose. See the picture below.
    On both TPSs, check the voltages between ground and Pin 2. The readings should show 5.0 V on both sides. These voltages are supplied by the ECUs.
    Also, in order to double check your measured 0.642 and 0.952 volts, repeat the readings by connecting your multimeter between a good ground point and Pin 3 of each TPS.
    ernie likes this.
  23. m.stojanovic
    Dec 22, 2011
    3,307
    Serbia - Niš
    Miroljub Stojanovic
    CORRECTION: Check the voltages ground to Pin 2 of left TPS and ground to Pin 1 of right TPS. The readings should show 5.0 V on each TPS.
    ernie likes this.
  24. Ferrarium
    Ferrarium F1 Veteran Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I went through all that as well, remember your throttle linkage affects it if it has been messed with by others prior. It may gap perfect with geometric method but be off with throttle linkage attached. Disconnect that sides throttle linkage then check it.
  25. joshtownsend
    Jul 12, 2007
    422
    H-town...TEXAS
    Qavion likes this.
