News
after market tail lights
Discussion in '360/430' started by raywong, Apr 17, 2020.
  1. raywong
    raywong Formula Junior
    Aug 29, 2004
    661
    Hong Kong
    Raymond
    Has anyone seem in person the after market tail lights from superformance? How is the quality? My lights have cracks in them.
  3. mike32
    mike32 F1 Rookie
    May 13, 2016
    3,382
    Uk
    Is it the mounting posts that are cracked or the lenses
  4. Bob in Texas
    Bob in Texas Formula 3
    Apr 23, 2012
    2,377
    Just East of Weird
    Bob
    If you are talking about the posts...
    Check out the tail lights available from Scud Ing Swiss. In either case, I’d suggest reinforcing the posts with one of the aftermarket kits found on eBay.
    On the other hand you might try repairing the posts on your current tail lights with the below kit
    https://www.ebay.com/itm/283843557079
    Sent from my iPad using Tapatalk Pro
    whatheheck likes this.
  5. brookliner7
    brookliner7 Formula Junior
    May 5, 2018
    584
    San Antonio, TX
    Hans
    Check eurospares.com, I have a pair of after markets and they’re different than the OEMs, I should’ve spent the extra money to get the OEM. Don’t make my mistake
  6. f355spider
    f355spider F1 World Champ
    Rossa Subscribed Owner
    May 29, 2001
    17,271
    Hugh G. Rection
    Where did you obtain your aftermarket tail lights that you are unhappy with?
  8. f355spider
    May 29, 2001
    17,271
    Hugh G. Rection
    Just to link up some of the options:
    Superformance offers OEM and aftermarket:
    http://www.superformance.co.uk/360/lights.html (I'm unsure if any of these would work for USA/CDN cars as the part numbers do not match)
    Scuding Swiss offers aftermarket:
    https://www.scuding.com/Shop/en/rear-lights-optical-clusters/18-rolu43c-f430-light-cluster-clear.html
    Eurospares only sells oem it appears:
    https://www.eurospares.co.uk/parts/ferrari/f430-scuderia-usa/all-pages/headlights-and-taillights-71401
    Ricambi America sells oem:
    https://www.ricambiamerica.com/car-diagrams/ferrari/v6-v8/430-group/f430-05-08/front-and-rear-lights.html
  9. raywong
    Aug 29, 2004
    661
    Hong Kong
    Raymond
    Cracked lens. The aftermarket ones are a lot cheaper but how is the quality?
  10. mike32
    mike32 F1 Rookie
    May 13, 2016
    3,382
    Uk
    Rear lights on a uk car are different to those in the states. Different pt no as well.
  11. mike32
    mike32 F1 Rookie
    May 13, 2016
    3,382
    Uk
    If its just the single short post which is cracked you can repair this by cutting it back and tapping out and fitting a stud bar. I did this after i found a loose light- did all 4 and no problem in 5 years.
  13. brookliner7
    May 5, 2018
    584
    San Antonio, TX
    Hans
  14. AandSC
    AandSC Karting
    215
    Jax, FL
    Allen
    Here’s a pic of the Scud Ing Swiss aftermarket taillight vs OEM. The only noticeable difference is the lettering on the lens.
    My originals had cracks, which I repaired with one of the available reinforcing kits. That worked well, but I decided since I was going with the Scud Ing Swiss LEDS that I would try the aftermarket lights. I don’t think they will last longer than the OEMs due to the design, but they are a lot cheaper, so replacing every eleven years or so is a bit more palatable.
    I did save my reinforced OEMs in the event I want to go back to them at some point in the future.
    psych0hans and f355spider like this.
  15. Bob in Texas
    Apr 23, 2012
    2,377
    Just East of Weird
    Bob
    Ive had the Scuding Swiss lights for a year and the inner light -drivers side top post cracked. Use one of the reinforcing kits first. I took all 4 back out when the one cracked and used one of the kits on all of them.
    AandSC likes this.
  16. AandSC
    AandSC Karting
    215
    Jax, FL
    Allen
    Appreciate the heads up Bob. I’ll have to get another reinforcing kit on order.
  17. mike32
    mike32 F1 Rookie
    May 13, 2016
    3,382
    Uk
    Just drill and tap the bottom post re my pics above and it will last forever. 15 min job
