After sitting in the garage unattended for 7 months | FerrariChat
Discussion in '308/328' started by mike996, May 4, 2010.
  1. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,876
    Mike 996
    My 328 started like it had been running yesterday. Only prep work was some Stabil in the gas back in early Oct and the batt disconnected at the big red neg connector. No charging of any kind - I am very anti-unattended charging.
    Even the air conditioning worked well!
    Really love being together with my 328 again...sadly only for 2 months and then it's back in the dark for it until Sep. :(
  2. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Good stuff :)
    A few years ago mine sat for more than a year and a half without being run. No gas stabilzer etc. Simply bought a new el cheapo battery to replace the old el cheapo battery (never bothered trying to test/charge it). Started up after just a little cranking and ran fine.
  3. Neonzapper
    Neonzapper F1 Rookie
    Oct 19, 2008
    2,580
    MD/FL/Philippines
    Mykol
    That's a great car you have there, Mike996! I remember when you posted about taking it for a last spin before putting it away for the Winter. I don't know if I could go that long without seeing my F-car.
  4. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    Glad its running right for you!!! I am sure that its glad to see you as well!!
    PDG
  5. kemullins63
    kemullins63 Karting
    Feb 12, 2010
    78
    Kansas City Missouri
    Kirk
    I let my 81 308 sit for a couple years without even starting it (females tend to cause priority shifts, never letting that happen again)... anyway... Put a new battery in and cranked her over...didn't start. It had been so long since I started it, I forgot I should be hearing the fuel pump (which I didn't now). The ethanol in the fuel I sispect, had siezed the pump.
    So I drain the fuel (which smelled like varnish), put in a new fuel pump and accumulator, new fuel lines and brand new gas... fired right up! Now of course I have half the engine apart changing out the water pump and cam belts and tensioners.... etc... etc. :)
  6. f1lupo
    f1lupo Formula Junior
    Aug 4, 2008
    726
    Toronto, Canada
    Johnny S
    yep that's all i do to to store my 328 and also fill my tires up another 10psi to avoid flat spots and conditon leather :)
