Aftermarket coil over for California? | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by pmb458, May 9, 2011.
  1. pmb458
    pmb458 Rookie
    Mar 24, 2011
    47
    Exactly who makes them?
    I want stiffer suspension
    The factory is way too soft for my like
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,727
    The OEM platform has completely adjustible suspension--that is the effect of coil-overs come on the stock car--that is you can set ride heights and corner weight the suspension on the stock setups.
    So, all you need are stiffer springs and stiffer shocks.
  3. The Palerider
    The Palerider Formula Junior
    Sep 11, 2008
    463
    Miami, Florida
    Michael
    Just curious, is yours equiped with Magnaride or not?
  4. pmb458
    pmb458 Rookie
    Mar 24, 2011
    47
    I am not 100% sure but when I select to sport the suspension firms up directly.
  5. rainforest
    rainforest Formula Junior
    Apr 14, 2010
    419
    Not sure? Didn't you feel it in your pocketbook when you chose the option?
  6. tazandjan
    39,166
    Credibility issues or a very rich owner who already has coil-overs and does not know it.
    Taz
    Terry Phillips
  7. RickLederman
    RickLederman F1 Rookie
    2,837
    Swanton Ohio
    Rick Lederman
    If it firms up a lot in Sport, then you have magneride. I happen to chat about that with the MAG mechanic last Monday. No magneride then the sport button does nothing with the suspension, it can't since there is nothing to adjust, just engine and trani mapping.
    Rick
  8. tazandjan
    39,166
    Rick- And that is very interesting because that makes the California the first Ferrari in a long time that is available without variable shock absorbers. Even the parts manual refers to them as dual mode with adjustable setting (magneride), and fixed setting for the standard shocks.
    Taz
    Terry Phillips
  9. pmb458
    pmb458 Rookie
    Mar 24, 2011
    47
    Thanks a lot Rick!!:) I guess I have Magneride. When I switch to SPORT. I can feel it firms up and stiffer but nothing compare with my 997TT with SPORT on. How do I tell if I have magneride on my Cali? My suspension looks like aftermarket coil overs. So now, should I go H&R? Novitec springs or coil overs? Does KW has anything for Cali????
    I want to make this cali as sporty as possible. :)
  10. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    If you bought the car new you could look at the sticker (I always keep them).
    If you bought the car used, get the VIN and call the dealer and ask them what's on the car.
    I would think magnaride would be the ultimate. But I like a comfortable ride. Save the kidneys. ;)
  11. pmb458
    pmb458 Rookie
    Mar 24, 2011
    47
    Guys, I have magneride. (CCM1) I checked with my dealer today
  12. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
  13. scrowe
    scrowe Karting
    Mar 7, 2011
    185
    SoCal
    Steve Crowe
    Maybe someone can help me out here. I have the "Magnaride Dual Mode" on my options list specified as (option) MADM. I thought that CCM1 referred to "first generation carbon ceramic breaks"?
  14. scrowe
    scrowe Karting
    Mar 7, 2011
    185
    SoCal
    Steve Crowe
    "breaks?" - give me a brake! I meant "brakes" (duh).
  15. pmb458
    pmb458 Rookie
    Mar 24, 2011
    47
    This basically the sport springs with nose lift? not the actual entire suspension. correct?
  16. Exotica Motorsports
    Nov 1, 2003
    3,673
    Washington
    Jason Godsil
  17. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,890
    contact your dealer and request they contact the factory on your behalf. The factory may have a software solution to your desire for stiffer set-up. Good luck and let us know.
  18. pmb458
    pmb458 Rookie
    Mar 24, 2011
    47
    My dealer don't allow us to adjust the coilovers or change aftermarket parts.
  19. D-Gunz
    D-Gunz Karting
    Apr 9, 2013
    154
    San Diego
    David W.
    Go buy from RMT (rebuilders master tech) - I worked with them for a month to "perfect" the stock Ferrari Coilover (with Magna-ride) for 2009-2014 California. It took some engineering but they got it right. I paid $1000 for BOTH rears and save $3k vs buying from the dealer.
    I took out the stock coilovers and shipped to Florida; they rebuilt them and sent them back and I reinstalled them. Good as new.
