Aftermarket ECU (Motec) install in 308 | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by mk e, Nov 17, 2006.
  1. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    I'm all set. I ordered 1/16" x 1" adhesive backed rubber from mcmaster when I ordered the wire wrap.
    I've had a lot better luck with T6 than T651. In this case I just wanted a couple straight bends and Lana was home, so I used the torch. When Lana isn't home, I throw it in the oven, set it to clean and it comes out dead soft.
  2. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,468
    Dumpster Fire #31
    SMG
    hahaha, oh man just think you're one of the few worried about getting caught with some car part in the oven instead of porn or a misstress.
    reminds me of the evening i spent with my buddy detaling our cars the night before a drive, we tried to play off that we spent the night at a strip club but wife wouldn't believe it! she knows me too well, if i burn the evening away it's always something car related.
    ..at least i have a good cover should the need arise ;) nahh, she's to cool with my addiction as it is.
  3. Norpower
    Norpower Rookie
    Dec 20, 2005
    25
    Mtl. Canada
    Dino Giar
    I have my Motec M8 installed in the rear rt side behind the engine and it works flawlessly.Wires are much shorter as well.
  4. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    I didn't catch your earlier mention of struggling with bending aluminum. 6061 (usually T6 hardness) can be curved and welded but doesn't like being bent too sharply. While not quite as strong as 6061, the best aluminum "alloy" for any kind of forming operation is 3003 which is realy not an alloy. It's 100% pure aluminum. All the other alloys have additives to give them various mechanical properties. The 3003 type usually comes slightly work hardened from rolling it into a sheet but still bends nicely. If you want to get really crazy with coumpound shapes you can anneal it to make it softer. It's very weldable and of all the alloys it's the most resistant to corrosion and cracking. Kitchen aluminum foil is made of 3003. Most aluminum, car bodies are made from this stuff and on aircraft it's formability is used for the highly curved transitions between the wings and the fusilage for example.
  5. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    I just realized the GM IAC stepper motor I have eats 4 of the 8 aux outputs...that will never do, I had other plans for them. The motec manual doesn't provide a lot of guidance on stuff like that. A bosch unit only needs 2 output...just one more reason to build a new intake.
  6. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    A Ford IAC valve (cheap) has 2 wires.
  7. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    I'm probably being overly cautious, but I don’t want to take any chances. I would save some wire by mounting it in back, but it wouldn’t really be any easier to install I don't think. I would still need to run quite a few wires up front (tach, front wheel sensors, power, intercooler pump, intercooler fan, radiator fan, slip indicator light) and it’s not really much harder to pull the larger bundle once everything is apart. Plus all the fuses and relays are together this way and I like that....not that is works any better.
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    I knew the ford unit only eats 1 output, but I wasn't sure how well they work since everyone else thinks they need atleast 2 and I've never messed with one. Is that what you are running? If so, are you happy with it?
  9. ATSAaron
    ATSAaron Formula 3
    1,136
    Shady Shores, TX
    Aaron Bunch
    We use them on most of the stand-alone cars at the shop. Be sure you test it before you install it. They work pretty well. My M4 didn't have any trouble running it. The older Autronic SMC doesn't pulse it at a high enough frequency so you can really hear it click. Just play with the frequency setting in the Motec until you find one it likes.
    Edit - oh yeah, we tend to use them because they bolt right up to aftermarket Ford 65mm throttle bodies that are available EVERYWHERE.
    Aaron
  10. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    yeah, I knew better but I had a piece and it was the right size......it all turned out fine in the end, I just got to make it twice. I worked in a shop years ago where one of the guy would laugh and say "We make everything nice because we make everything twice". :)
  11. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    I messed around with the IAC and finally just removed it. Could not get it to work properly and was able to program around it. Tonight I removed everything out of the trunk area. There was tons of insulation and multiple fiberglass panels all designed to keep heat out of that area. If all that is gone from your car, then for sure, the CPU should not be mounted there. BTW, does anyone know what all that white baffling stuff is made of?
  12. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Do you know what the fequecny on the M4 is? For no particular reason other than it makes all my yellow wires go the same direction I was planning to use my ign5&6 which are 5000hz. My aux 1-4 are 10000 hz
    Have you use a bosch or subaru 3 wire for comparison?
    I have a ford throttlebody, but it's twin from a mustang and not equiped for IAC. The twin is a nice fit to the blower inlet. I built a GM unit into the throttle to blower adapter because the haltech needed it. I could just as easy mount a ford unit I guess.
    Does pep boys have them and what do I ask for?
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    All that is gone from my trunk and it gets hot in there. I don't know what it's made from.
    Which IAC were you using? The only thing I wasn't able to do with the GM unit is start the car cold, it just didn't flow enough air and I hard to crack the throttle 1/2 way. After the engine was running it worked well though and it warm started fine...just the cold start problem.
  14. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    No, but breathe deep. :)
  15. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Yeah, I have two 5.0 Mustang throttle bodies on there and one still has the Ford IAC on it. The other IAC opening is plugged. It all works well!
  16. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Mike, I was working with a GM 4 wire treaded IAC unit. After the second one, I gave up trying to make it work. I could not get the engine to idle correctly when cold.
  17. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Same as I had. I did actually port mine a bit to get it to flow more, but it was still marginal. I found that if I set the idle hot using the butterfly with the IAC closed, I had enough air to get a good cold idle. I also found that it's critical to have the timing and fuel map set be constant in the idle range. If the timing in particular changes as rpm increases slightly (the engine tends to hunt at idle. Like say the map says 10 at 1000, and 15 at 1500 the engine hunts, but adding a 10 at 1250 point solves the problem.
    Maybe I'll go ahead and run 2 wires back. I can use the ford unit and if there is still a cold start or idle problem I can use the second for an idle solenoid to supplement the IAC or switch to a bosch IAC.
  18. TommyA
    TommyA Formula Junior
    Oct 7, 2002
    549
    Atlanta
    Tommy A
    Will the Ford throttle body fit on to the stock intake?
    If not what kind of mods need to be done to fit?
  19. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    I doubt it will fit but I haven't tried it. Mine is a 77 (formerly carbureted) 308 which now has a supercharger and electronic programable fuel injection and ignition. Everything on top of the engine is custom. I suppose you could make some sort of an adaptor plate.
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    an adater can be made to put just about anything together, I can't imagine this would be any different
  21. ATSAaron
    ATSAaron Formula 3
    1,136
    Shady Shores, TX
    Aaron Bunch
    It's way less than that. I can't recall, but I think on the M4 software it is selectable in the idle menu. I think it was happy around 400 hz.
    We used an antique Link ecu on an MR2 yesterday to get 380 wheel horsepower (about 470 at 20% drivetrain loss) at 1.6 bar of boost (23 psi) on ~102 octane). It's a built bottom end (that we built) but a stock cylinder head. Cams would put us over the 500hp mark. Pump gas (93 octane) made right at 400 flywheel hp.
    Aaron
  22. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    It's selectable on the M800 too, I just didn't want to use an output that wasn't capable of the required output....I've got a couple that are only 200hz, they're going to fan/pump relays.
    That all works out, pump gas should be good for about 250 hp/l, exactly 400 on a 1.6l engine.
    Making hp has never really been an ECU issue, so I'm not surprise. The ECU issues are generally more about transition performance, particularly off idle. The real early ECUs only had 8 rpm and load points...they ran and made hp, but streetability just wasn't there. The new ECUs do a much better job.
  23. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,813
    The twilight zone
    Does anybody have a source or what to ask for on the Ford IAC (most parts stores only understand make and model these days)? It looks like there are at least 2 versions, one a TB mount and one with hose barbs….I guess I could use either since I’m currently set-up for neither
    How about a source for the connector? The guy I normally deal with said he doesn’t have a source for Ford connectors. I need to find a ford TPS connector too.
  24. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
  25. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    I'm pretty sure my 5.0 throttle bodies came from the 1987 Mustang. Other Fords of that era used the same IAC. I've seen them attached to other throttle bodies. Finding an electrical connector for the IAC wasn't easy but I did find one. I'll try to figure out tomorrow where I got it and what the part number is.
    BTW: I'm still waiting to get hold of the CF guy.
