Aftermarket Headers Heat Issues Consensus? | FerrariChat
Discussion in 'Technical Q&A' started by AZSpider, Jul 1, 2007.
  1. AZSpider
    AZSpider Karting
    Oct 8, 2004
    202
    San Diego CA
    Well I am still chasing the alternator failure after installing the NAPerformance headers on my 355 Spider and trying to determine wether it had any cause for this problem.
    How many others have installed these and what if any is the consensus if the heat is causing any issues in the engine compartment?
  2. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    Are they ceramic coated? My understanding that without heat shielding of some kind you would be hosed, with the possible exception of ceramic coating.
  3. AZSpider
    AZSpider Karting
    Oct 8, 2004
    202
    San Diego CA
    No they are not. That is why I am asking the question here, to ask those that have them what their experiences are.
  4. Llenroc
    Llenroc F1 Veteran
    5,539
    Colorado
    Vern
    Either put sheilding around them or have them coated inside and out. I have factory headers without shielding but ceramic coated. I insulated my alt. and brake lines that are below the headers. I have had no problems in 10,000 miles but I also have no heat traps in my exhaust system ie; bypass valve, cats or muffler. IMO You should be fine if you have them coated properly.Also the tubes look great without shielding. Regards, Vern
  5. 355
    355 F1 Rookie
    3,643
    Toronto
    Frank
    They may look great and they may be ceramic coated but from the people I have talked to you will run into problems sooner or later. The Tubi headers are the best and OEM second because the are shielded. But Tubi are by far the best choice.
  6. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    14,054
    MO
    Omar
    Are the Tubi headers coated?
  7. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    I had the original set in my car, and put over 5000 miles on them, including over one LA summer, and used the car as a daily driver for much of that time. So, 100+ degree days, sitting virtually still for sometimes hours on the 405.... I had them wrapped with heat tape, and had no problems whatsoever. Of course, YMMV.
    Out of interest, why are the tubi headers the best?
  8. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    I think you will need to do something to take care of the heat, either ceramic coating or heat shields. I have heard of people fabricating their own shields, but I have never seen pictures. Realizing that it would be a PITA to remove the headers and have them coated, the heat tape may be the way to go for now. I have seen that done recently... trying to remember the thread.
  9. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
  10. f355spider
    f355spider F1 World Champ
    18,053
    Nope, ss with heat sheilds.
  11. duskybird
    duskybird F1 World Champ
    12,672
    29 Electoral Votes
    Bill B.
    Ceramic coating or wrapping will help hold the head inside the pipe and keep it out of the engine compartment. Heat shields dissipate heat over a larger area where it does less damage. There are applications in which coating or wrapping add a couple of hp due to the more efficient exhaust flow.
  12. xavior
    xavior Formula 3
    Aug 22, 2006
    1,793
    #12 xavior, Jul 2, 2007
  13. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    QV in London rebuilds the stock items, with thicker material. I put a set in and they lasted over 20k on my 355. About 25% of the original headers, and better.
    Art
  14. Valence
    Valence Formula Junior
    Jan 20, 2004
    883
    Charlottesville, VA
    Chris& Brian Coffing
    Wrap them or cook your electrics!
  15. k wright
    k wright F1 Rookie
    Feb 4, 2004
    2,544
    North East TN
    Kent Wright
    I think you would be wise to go witih something more than the ceramic coating. Ceramic coating is better than nothing but not close to the factory heat shields.
    Lots of expensive parts near the headers that are heat sensitive. Don't risk it.
    ken
  16. xavior
    xavior Formula 3
    Aug 22, 2006
    1,793
    How about..... Coating then wrapping them? Thoughts?
  17. f355spider
    18,053
    That's what I did! ;)
  18. duskybird
    12,672
    29 Electoral Votes
    Bill B.
    Check the specifics of the coating. Some you can and some you cant.
  19. Dino
    Dino Karting
    Nov 3, 2003
    116
    San Diego
    Does anyone have the approximate cost of a set of 355 Tubi headers?
    Dino
    San Diego
  20. f355spider
    18,053
    Last I heard, around $5300. for the "street version" with the heat shields. But, they are not street legal (EPA approved) in North America, and are difficult to obtain from the usual sources.
