At least it's not just me, AP headers are way way to loud, it's not a small difference, it's huge, I was told a fix on another thread was to ware earplugs when I drive it :0 It's also much more noticeable for me as my 430 is a spider. I still cringe at how loud and embarrassing it was, never again, I'd rather weld mine up every year if I have too, only cost me a bottle of red wine as a gesture Sent from my iPhone using Tapatalk
Did the welds seem to take and hold up well? The reason I ask is I had heard before that the type of steel used in the OEM manifolds could be tricky to weld. Just curious how the welds worked in your personal experience? Also, I can't recall, but did you remove the precats from your MKIIs?
Mine have been on a year now with no problems, no weld issues although I do agree that the standard manifolds are very poor quality in terms of materials and design. I kept my precats in, there is no correlation between the precats and the area that the manifolds crack, the cracks occur in the same place at the 4 pipes into two joint due to heat expansion, its just metalwork, nothing technical, no black magic, I got sucked in by the fabricated horror stories sadly, hindsight is a wonderful thing!!.
Im wandering if theres a way to keep the aftermarket manifolds for the sake of better quality and find a way to quiet them alittle bit.
That's the holly grail, the demand is there if a manufacturers would listen to what owners are telling them, the F430 stock sound is sublime, no more volume required. I paid big money for my AP's, they looked awesome, I had them ceramic coated, so impressed, but then after I had them fitted my happiness quickly ended, sold them having covered less than 1k miles, what a waste. Stick to stock and decat if you feel safer, my friend said he hasn't noticed any noise increase after decatting the stock OEM's, which I thought was very interesting as the lack of precat when fitting aftermarkets were blamed for the huge increase in volume?
My challenge headers are basically stock headers without the precat and they are maybe 10-15% louder. Nothing like the aftermarket headers with the oversize pipes. The bigger pipes can flow more so can give some hp at full RPM. But these bigger pipes/collectors may well be responsible for the mid-range torque dip many have experienced. Challenge cars and scuds have the same size header pipes as stock 430's. Pretty sure Ferrari knew what the were doing. (aside from the solid exhaust mounting on 430's that causes the cracking)
I'm the same as your friend... I didn't notice much difference with the AP. Maybe on cold start since I think the valves open a bit on cold start? With the valves closed and stock muffler, I really don't see how it could be too loud.
Lots of great feedback on the forums for the Capristo mounts. Super high quality build and materials. I plan on keeping an eye on the glass packing as that seems to be the first sign of header failure. My shop carefully inspected everything they could without taking the clamshells off. Everything looked great. At the end of the day, I'm willing to accept the small risk of header failure because I've mitigated it as much as possible. I have Mk II headers (sure, still not perfect), they've passed inspection, and we're using the Capristo mounts. I simply wasn't willing to live with the annoying AP setup any longer. I've owned my 430 two years now. She's got 33k miles now, 14k of which are mine. After about $25k invested in maintence and service, she's running and looking better than she likely did when she left the factory. Couldn't be happier.
If that's the case, then I may consider AP for less. I don't daily and Ronnie's youtube videos sound so amazing. Any supporting info on Fabspeed and AP being the same? Al
Very common knowledge. Lots of threads on this. Only suckers pay the Fabspeed markup on those headers.
Look up my YouTube videos on stock F430 manifolds, so easy to smoke test them if the manifolds are off the car. fabspeed, AP yes they are all the same! Sent from my iPhone using Tapatalk
How do you tell if you have the MKII manifolds? Here are my versions off the car: Image Unavailable, Please Login
I don't know that I have ever seen a definitive answer to your question. This is as close as I can get: http://www.ferrarichat.com/forum/technical-q/482650-430-how-tell-visually-if-headers-mki-mkii-version.html The only reason that I know that I have Mk II headers on my 430 is because I have the service records from the prior owner that indicate that the 1661 bulletin was followed under warranty.
Please zoom in to my picture, this picture is a perfect illustration of my MkII manifolds that have cracked on both sides when I checked them by smoke test which I uploaded to youtube in 3 shorts video clips., The crack site is the same on every failed set of stock manifolds across the world. The precat degradation (argument/utter fantasy) has nothing to do with this area of weakness due to as we all now know is heat expansion related. Bits being sucked into the a cylinder is complete fantasy also, Ferrari would have recalled all F430's if that ever happened, even one occurrence, all talk and scaremongering with no evidence. I bet my house and all I own that there are many F430 owners driving 10's of 1000's of miles each year obvious to a cracked manifold since their last service or even the one before as it is still not easy to detect by sound. It's a metal pipe, weld it, heat strap the manifold, drive on and enjoy. Image Unavailable, Please Login
An exhaust leak pre-o2 sensor will throw off the fuel trim readings, possibly causing the car to run rich. This incorrect fuel composition will impact catalyst wear and durability. Over time if the cat breaks apart it falls into the cylinder and can cause significant damage. The crack is not spreading to the catalyst or cracking the catalyst, it's the byproduct of how the car runs with cracked headers.
Thanks Turbotuner, that does make sense, cracked manifolds are not idea granted, but not the end of the world, if it was there would be broken down F430's lining the streets, plus Ferrari would be falling all over themselves to give us all new engines free of charge, even as a precaution because nobody knows just how long they have been running on cracked manifolds. My car is a late 2005 so I fully expected to have MkI's on, they were MkII's, no mention in my service file sadly but that is because years ago the manifold issue was swept under the carpet much to the relief of their owners.
Reminds me of Porsche's IMS problem. People are still asking about it on the forums even on the newer cars - it hasn't been an issue in years. But I guess if we didn't talk about the 430 Headers all we'd have left are "How much is my ______ worth?" and "How many _____s were made" threads.
Agreed. User/Owner forums like this are invaluable, but there will always be an element of sorting the wheat from the chaff ;-)
If any vehicle has an exhaust leak pre-o2, it should be repaired quickly. I would not advise anyone to run any vehicle, especially an F430, with a cracked header. If you choose to file this with 'my 360 made it 7 years between belt changes', that's fine, but understand it's a risk and not recommended. Most people suitably maintain/repair their cars, so there aren't many stories of catalyst failures due to exhaust leak. There are many documented cases of cracked headers though, so the failure is not disputable imo.
Thats simply untrue, cracked stock headers don't cause any pre-o2 errors what so ever, this is why so many go undetected until annual service time. I know, I got ripped off as an unsuspecting customer purchasing from a rogue supercar dealer in Preston, they were adamant the manifolds were okay, another indy close to me thought otherwise, my local official dealer couldn't confirm, to my supprise!, so I decided after all I had read that at least one side was cracked, tapping sound on startup that disappeared when warm, so I made another poor decision and purchased AP manifolds that were stupidly loud, couldn't live with them, so then I checked the manifolds and I was right and wrong, not one side but both sides had cracked, went back to said rogue dealer as I'd only had the car 5 months and covered 600 miles and they politely told me to F^£k off, I had a loan initially so thought I was protected, indeed I was if I had not inspected the manifolds myself, so learn from my expensive mistakes. 1. buy from main dealer only, if you use an unauthorised dealer, the day you pick it up, take it for a full inspection at a main dealer. 2. Don't buy aftermarket manifolds if you don't want tinnitus or bleeding ears and void Ferrari warranty.
I'm not sure I follow your disagreement and ensuing story. Are you saying your car didn't have a CEL? That's not unusual, it's not a catalyst below efficiency threshold error like a secondary o2 sensor would report. The first o2 sensor actually reads some of the a/f mixture and tries to keep fuel trims adjusted. If outside air is introduced via a cracked header, this can cause the car to run more fuel/rich and that wears the cats out and causes potential crumbling that falls into the cylinder. While you may not have enjoyed a perceived increase in sound w/ replacement manifolds, you can't argue that it's ok to run cracked headers for a long period of time.
