aftermarket piggyback ECU options | FerrariChat
Discussion in '360/430' started by sleepinglh, Mar 9, 2018.
Would you turbo your F430 if its under 15k as a DIY job?
  1. Definitely
    17.6%
  2. No Way
    70.6%
  3. Maybe
    11.8%
Multiple votes are allowed.
  1. sleepinglh
    sleepinglh Karting
    Jul 30, 2015
    82
    Sydney Australia
    Q
    Hi all, Just laying down some ground work for my Turbo Flex Fuel F430 project.
    As you all know the F430 has 2 separate ECUs one for each bank.
    does anyone have the wiring schematics for the ECUs?
    Anyone know the specs of the stock injectors and fuel pump?
    Have experience with wiring up a standalone or piggyback ECU on the F430 that you'd like to share?
    Havent found and plug N play solutions so if you have any... would be nice if you could share too.
    Thanks in advance
  2. 02360spider
    02360spider Formula 3
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    Why not just have the ecu flashed instead of going crazy with all the wires?
    Sent from my SM-G950U using Tapatalk
  3. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    How serious are you going on this turbo build? Are you doing any internal work or just putting a turbo on?
  4. sleepinglh
    sleepinglh Karting
    Jul 30, 2015
    82
    Sydney Australia
    Q
    It'll be low boost 3-7psi and E85 is a must.
    so flashing the ECU is not an option...also dont like running a boosted car with MAF.
    no internals just gonna throw on a single turbo setup with W2A intercooler.
  5. Mickster
    Mickster Formula Junior
    Oct 24, 2015
    608
    Sweden
    Mikael Andersson
    Not even a thicker head gasket to get lower compression?
    I would have done at least the head gasket if I was to strap a stress fan on my car.
    Quite easy job and also better reliability.
  6. 02360spider
    May 27, 2015
    1,753
    Dartmouth
    Richard oliveira
    You doing a build thread on this?
  7. sleepinglh
    sleepinglh Karting
    Jul 30, 2015
    82
    Sydney Australia
    Q
    Compression is not a problem since I'll most likely stay under 7psi which puts the compression ratio around 16.7:1 when boosted.
    Its perfectly fine when paired with e85 and most of it will come down to how well its tuned.
    Most manufacturers with 15:1 - 16:1 CR
    I'll do a build thread on this once I start but most likely start mid year and wrap things up before 2019
  8. sleepinglh
    sleepinglh Karting
    Jul 30, 2015
    82
    Sydney Australia
    Q
    Thanks for voting the polls.......now I'm even more dead set on the project seeing NO as the majority.
  9. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,765
    Lake Villa IL
    I've built and owned many turbo cars but prefer the attitude of a naturally aspirated engine in a Ferrari. So my vote of no is personal preference, not trying to crush your hopes and dreams.
    I think AEM infinity, Pro-efi, Halltech or Motec would all handle what you need. If you aren't going to tune it yourself find out what pro's in your area are comfortable and experienced with.
    If you are going to tune it yourself, see what features are important to you and download software for each system to look it over.
    Highly doubt you will find anything plug and play.
  10. azlin75
    azlin75 Formula Junior
    Jul 16, 2017
    785
    Kansas
    Shawn Hicks
    The thing to remember is since the heads ( and block) are aluminum and probably a superior casting you can probably get away with a bit higher compression ( usually 1 point since aluminum wicks heat away better then cast iron). But I agree with mickster I'd sure feel more comfortable lowering the compression a bit. And if it were me I'd want to at least eyeball the internals before I added more pressure to the engine even if it's a Ferrari engine, even if it's only 6-7 psi.
    While I prefer naturally aspirated engines I have great respect for those that modify and tweak their cars. One thing is for sure it will be quite unique.
  11. sleepinglh
    sleepinglh Karting
    Jul 30, 2015
    82
    Sydney Australia
    Q
    Thanks i’ll Definitely have a closer look.
  12. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    I voted no, because I have been taking cars apart and putting them back together for over 40 years, and it is never what you think it is going to. I have a car in one of mu garages with over 130K in modifications in it. It is worthless to anyone but me. I applaud your desire, but in my experience everything that you alter effects more than what you think, and 15K can turn into 50K pretty fast. Good luck.
    F355Bob likes this.
