Aftermarket replacement for Timing Belts? (Ie Chain Kit) | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Looney, Aug 4, 2005.
  1. Looney
    Looney F1 Rookie
    Jul 1, 2004
    2,767
    Gold Coast
    BB
    Hey guys,
    ive been lurking on these boards for about a year now, and constantly belt services are of mention.
    Was just curious if its possible to get some sort of aftermarket kit, which replaces the timing belt with a timing chain? this could prove to be a cost saving over time, especially with cars like 348 or 355, where they sometimes book as much as 40 hours to do the 3 yearly belt service?
    any comments?
  2. pete04222
    pete04222 Formula Junior
    Nov 1, 2003
    613
    Maine, USA
    Peter Cyr
    A chain is not the answer. They are expensive, noisy, they stretch so you need to adjust it frequently (each roller is a wear point), they require lubrication and they are heavy so they rob your engine of power (and each roller is a friction point). And the sprockets will wear out also so now instead of just changing the belts you need to replace the chains and sprockets.
    The belt is the way to go. It is lighter, quieter and more efficient. But they do wear out. The reason for the frequent replacement is preventative maintenance. The Ferrari engine is an "interference" engine meaning that if the belt breaks the piston can hit a valve that is open.
  3. fanatic1
    fanatic1 Guest
    Nov 1, 2003
    561
    columbus
    philip
    I hear about F cars being "interference" engines.........Aren't most engines like this. Can anyone tell me some of the other manufactureres that if your timing belt/chain breaks, "nothing bad" happens. I have a friend with a Toyota Tacoma and when his timing belt broke, it ruined his engine, same thing happend on a Honda I know of...........any ideas, are most engines like this?
  4. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    13,312
    Central NJ
    Several of the older Toyota 4's are non-interference. That said, my '01 Rav-4 doesn't have a belt.
    Art S.
  5. Kds
    Kds F1 World Champ
    A chain will outlast a belt by a ratio of at least 5-1.....both time and mileage wise in my uneducated opinion. It's the only way to go from a cost/benefit standpoint. In my 29 years of being around cars (I'm 45 now) I have never broken a timing chain and have only heard of ONE......yes ONE occurance "firsthand" wherein this has happened......seen lot of belts go however.
    As to the question posed by the OP regarding Ferrari.......my take is that R+D costs + limited volume + product liability - operating/marketing expenses = financial deficit.
    My choice would be a gear drive personally.
  6. Capone
    Capone Karting
    Mar 29, 2005
    246
    Midwest
    Just don't let the car sit for long periods of time without starting. I met a guy last night with a Boxer that has the ORIGINAL belts. He starts it weekly to keep the belt moving (remember its on a tensioner) No worries.
  7. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    I had a Peugeot 1988 1.9 GTi,( performance chot hatch in 20 somthing years) and had belts break and it never harmed the engine.Just replaced belt and tore of again.
  8. ryalex
    Aug 6, 2003
    25,964
    Las Vegas, NV
    Ryan Alexander
    I think KDS is in the right direction with the chains being superior. Lambo was smart to do this IMO.
    However, as Pete says, it's preventive. I recall reading that to meet DOT standards, cars have to have timing belts with a 100,000 mile minimum life. I could be wrong on that, but it seems that Ferrari has gotten plenty of service hours out of their stated maintenance plan.
  9. Vlad328
    Vlad328 Formula Junior
    Mar 16, 2004
    279
    New Orleans, LA
    Vladimir Zuzukin
    New Maseratis have chains instead of belts. Ferraris may switch to chains too, if customers are happy with the Maseratis. Timing belt broke on my Toyota MR2 on the highway about ten years ago. Didn't damage the engine, and car still drives great 10 years later.
  10. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Wow, that's gonna be expensive one day, probably sooner than later!
    As for a DOT requirement that timing belts have a 100K life... I've never heard of such a thing. I'm not sure I've ever heard of the Department of Transportation dictating ANY minimum service intervals. That doesn't really sound like a part of their mandate (nor that of even the EPA or NHTSA). Nothing turns up on a quick internet search, either.
  11. scorpion
    scorpion Formula Junior
    Jan 19, 2004
    469
    Kentucky
    On models where the engine needs to be pulled to change the belts a chain replacement might be a good idea. However, on a 308 ypu don't pull the engine and the replacement the belts is only part of the story. The additional service, valve adjustment, hose replacement, gaskets, etc that are associated with the major service will still be needed. You might save $1,000 on belts (probably less as long as the other work is being performed ) every 5 years but no more than that. Assuming parts and labor for a chain replacement run $3,000 (remember we are talking Ferrari parts prices) it would take at least 15 years to get back the cost of the chains. Why bother, plus if you do the work yourself, you can do it in a weekend (after the first time).
  12. tuttebenne
    tuttebenne F1 Rookie
    Mar 26, 2003
    3,218
    Bay Shore, NY
    Andy
    As mentioned, chains need lubrication; the additional engine cases and castings add space, weight and cost. Chains are heavier as are gear drives. Gear drives create noise as do chains. Belts are lighter and quieter. The problem with belt changes is that they are expensive if done by dealership technicians.
  13. Koby
    Koby Formula 3
    Dec 14, 2003
    2,307
    The Borough, NJ
    Jason Kobies
    already did, the F430 uses a chain
  14. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Hondas use non-interference engines AND have cam belts that do not need replacement until 105k miles.
  15. UroTrash
    Jan 20, 2004
    40,470
    Purgatory
    Clifford Gunboat
    Likewise, Miatas are non-interference.
  16. ryalex
    Aug 6, 2003
    25,964
    Las Vegas, NV
    Ryan Alexander
    #16 ryalex, Aug 4, 2005
    Well, except when you get caught up driving for a gay parade.
  17. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    This has been beaten quite a bit, but belts are really a cheap way out no matter how you cut it. Quieter, quicker to rev up, etc. are really just rationalizations and not necessarily true. If belts are great, then why do F1 cars use gear drives? And why do 7000hp top fuelers use chains?
    And, it's hard to say which is less expensive to build. But; gear drive would be the most expensive. Chains leaves you with 5 hardened gears and a chain. Belts are 4 cheap seals, a cheap rubber belt, and 6 relatively crude pullies. I find it hard to believe Ferrari would cop out based on cost, but what other reason is there really? Chain and gear drives make an easier engine to package in a frame, and the weight gain is small in the grand scheme of a car. Maybe they just wanted to be different.
    This all said, I'm fine with the belts on the 308. They're easy to replace (one of the few benefits of the transverse engine). But I'd trade them for a chain in a second...
  18. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    lol.
  19. LetsJet
    LetsJet F1 Veteran
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Is it possible to use a pully that would use two smaller belts? That way if one broke the other would keep it from damaging the engine.
  20. jungathart
    jungathart Guest
    Jun 11, 2004
    3,376
    NoVA, AmeriKa
    Komrade Jung
    personally, I think LEATHER is the way to go!
    OOPS..... wrong forum...
  21. Master Shake
    Master Shake Rookie
    May 26, 2004
    25
    Boerne, TX
    Samuel Zehr
    I have a 1999 Jaguar that broke a timing chain and cost me a lot of money. Bad tensioner design leads to failures on these cars. Ask anyone with a newer Jaguar V8 and you here of more than one in 29 years.
    Sam
  22. Looney
    Looney F1 Rookie
    Jul 1, 2004
    2,767
    Gold Coast
    BB
    yeah, but your talking about a jaguar???
  23. AndersJL
    AndersJL Formula Junior
    Apr 16, 2001
    376
    Sweden
    AL
    I read an article in AutoBild, No 27, 2005, that Continental will be launching a new series of belts, designed for "the lifetime of the car": the ContiTech.
  24. Fred2
    Fred2 F1 World Champ
    18,181
    nj
    I think the issue here is where the broken belt would end up. It most likely would get sucked into the good belt, breaking that one too.
  25. parkerfe
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Ferrari uses belts because it is required as part of their dealer benefit package known as the The Ferrari Dealers Retirement Pension Fund.
