aftermarket stereo wiring help | FerrariChat
Discussion in '308/328' started by Veleno, Dec 22, 2010.
  1. Veleno
    Veleno Rookie
    Jan 10, 2010
    25
    Does anyone know where I can tap in to get power for the HU I'm installing? I need a constant (red on harness) and a switched (yellow on harness) power.
    I did do a search but nothing stating where I can tap for power.
    Thanks for any help guys and Happy Holidays!
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    what car? A Toyota, Honda, Ferrari, which model?
  3. speedy
    speedy Formula Junior
    Oct 18, 2005
    625
    Plano, TX
    James Gardner
    I chose not to tap into the original wiring (call me crazy)... I ran a large stereo amp power wire directly from my battery, through the firewall to a mounted dual row barrier strip on the right side of the fuse panel (308QV). It allowed me to tap into direct power when I installed my updated door locks and window accellerators. I slept better at night knowing that I wasn't jacking with the old factory stuff.
    Good luck
  4. BigTex
    79,380
    Houston, Texas
    Bubba
    With fusing I'm hoping......
  5. speedy
    Oct 18, 2005
    625
    Plano, TX
    James Gardner
    Oh yes indeed... The Spal door lock kit came with an in-line fuse.
    Also I should edit my original post. The firewall is behind the seats... It should be the front bulkhead I suppose.... :)
  6. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    Go ahead and do like everyone else - tap into the power supply for the clock for the constant +12 and the power to the wipers for the switched +12.......
  7. Veleno
    Veleno Rookie
    Jan 10, 2010
    25
    Thanks for the help guys.
    This is for an '84 308.
  8. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    The info is in the owners manual schematic. I would humbly suggest you splurge on a set of Paul's excellent schematics
    http://www.ferrari308gtbi.com/
    Very easy to read. No affiliation. Well, except that I like them.
    Birdman
  9. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    I grew up on real car radios. Whenever I needed gas money I'd stop at a used car lot to repair their defunct car radios at fixed $5 each using vibrators I rebuilt by filing the contacts. So, what is an HU?
  10. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    Just a guess, but I think Head Unit.
  11. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,294
    Ventura, California
    Robert Garven
    Oh my.... I spent weeks trying to get a small subwoofer wired under my seat. Finally gave up but have a Kenwwood HU that takes a USB and sounds great until it gets warm then starts distorting. I have given up for now. But when I get the car running again!!!
    BW I tapped into the top side of my rear window defroster. On the GT4 the stereo is always on
    Rob
  12. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    #12 Paul_308, Dec 23, 2010
    Rob, 1974-1985, the rear window heater is supposed to use left fuse 4 which is powered by the ignition key 'accessories' (+'run') position (as do as the a/c and heater fans on fuse 5).
    das ist sehr interessant - methinks you have never turned your key off, just sit there listening to the radio.
    Small woofers like 8" go fit nicely into the passenger footwell.
