Aging Engine Compartment Electrical Connectors | FerrariChat
Discussion in 'Boxers/TR/M' started by Jbar2002, Jan 18, 2022.
  1. Jbar2002
    Jbar2002 Karting
    77
    John Barhydt
    I'm in the middle of engine out maintenance on my 1994 512TR. One of the plug connectors to the Complete Phase Sensor (146233) crumbled a bit when it was unplugged. I priced a new part, then decided to fix the plug/connector.
    Is anyone aware of a good source for replacement connectors? Worst case is that I can weather seal the connector with epoxy. Another option I supposed is to replace the connector with a Weather Pack connector setup assuming there is enough slack in the harness. Image Unavailable, Please Login
    What are others doing to address this type of situation? For those who compete in concours, would using a non-factory connector setup like Weather Pack result in a loss of points?
    Thank you in advance.
  2. EZORED
    EZORED Formula 3
    1,031
    Scottsdale, AZ
    Dennis
    don't you just love 30-year-old cars!!
    Jbar2002 likes this.
  3. Rifledriver
    36,859
    Yes, a non standard connector would result in a deduction. I have seen the 3 wire Bosch style connectors for sale.
  4. Jbar2002
    Jbar2002 Karting
    77
    John Barhydt
    No kidding. My illness is that I happen to like cars from the 80s and 90s. My #1 retirement expense has been keeping my old fleet running reliably. No complaints though-just problems to solve.
    EZORED likes this.
  5. dontilgon
    dontilgon Formula Junior
    May 30, 2011
    332
    NY/PA
    Joseph
    Post some more detailed pics of the plug and I will check my electronic component manual for a match
  6. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,791
    Bolognaa
    SRI's gold connector kit included a lot of connectors for my Testarossa (but not all of them). Pricey, but, it helped a lot.
  7. Jbar2002
    Jbar2002 Karting
    77
    John Barhydt
  8. Jbar2002
    Jbar2002 Karting
    77
    John Barhydt
    Good thought - I will check that out. Thank You.
  9. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,791
    Bolognaa
    I am having different issues. The SRI kit fixed a lot of electrical gremlins, but now some of the grounds (such as for the instruments and window motors) need to be investigated. When I turn the headlights on, all my temp gauges climb a bit. The joys of 30 year old cars, etc.
  10. ago car nut
    ago car nut F1 Veteran
    5,477
    Madison Ohio
    David A.
    Run a dedicated ground wire from engine frame grd. to battery, it will help. Window motors are improved from fixes from this forum. Run the headlight switch thru relays with direct 12+ from battery.
  11. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    When you look for the matching connector…the back taper is important.
    It is important because it fits in the support bracket.
    Mine did the same. I have not found a good solution yet.
  12. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
  13. Jbar2002
    Jbar2002 Karting
    77
    John Barhydt
    Correct. So the problem becomes functionality vs appearance of originality. I've ordered a handful of the EV1 connectors to experiment with, although I'm thinking my first attempt might be to fill in the broken part of the connector with some epoxy, sand it to shape, and paint it. Not a good long term solution though.
  14. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    Another problem is tracking down the OEM for the connector. if the electrical contacts are still good, what about making a mold from another connector and using epoxy to replace the missing plastic. I've done something like that before. Use a good 24hr cure type , not the 5 minute type. And make sure the epoxy is non-conductive,; you dont want to short out the cable.
    Jeff Pintler
  15. Jbar2002
    Jbar2002 Karting
    77
    John Barhydt
    I talked with a vintage racer friend about fixing old plastic connectors, and he told me that he has fixed small plug clips with a product called "Q-Bond". Where I live a similar product called "RapidFix" is readily available. Q-Bond comes in black whereas the RapidFix comes in clear. Both products appear to be finely ground silica and cyanoacrylate glue. I experimented this afternoon to understand how the product works and to test for conductivity. I made a "mold" from blue painters tape and laid 2 wires in the mold. I layered the product in as instructed and ended up with a very solid "blob" of material with 2 wires tightly encapsulated. I found no conductivity between the wires, and the resistance of the encapsulated wires was the same as a non-encapsulated piece of wire. Assuming my meter is sensitive enough for this test it seems that the RapidFix claim that the product "can even be used to insulate low voltage wiring" is legit. I've watched videos claim that the material can be sanded to a smooth finish - I haven't tested that claim yet. The challenge in using this product to repair a connector is finding a material that can be used as a mold that will release and not become part of the connector. I also need to verify the heat rating of this product vs a high-heat epoxy or plastic welding glue before I do anything rash to the un-obtainium part. Just sharing info at this point.
  16. Rifledriver
    36,859
    Rhode Island wiring service and many others reproduce automotive wiring harnesses. Id get a picture off to a few of those and see if they have a source for them or know of any to try. A lot of these connectors are not that uncommon and there are many suppliers.
  17. Jbar2002
    Jbar2002 Karting
    77
    John Barhydt
    Thank you for the tip.
