430 - Ah the fun of a convertible.. | Page 5 | FerrariChat
430 Ah the fun of a convertible..
Discussion in '360/430' started by DrivnXcitment, Jul 28, 2023.
  1. Qavion
    Qavion F1 World Champ
    13,917
    Ian Riddell
    #101 Qavion, Nov 28, 2023
    Also, I missed the hydraulic line going to the return (reservoir?)
    With the motor running, it looks like the fluid going through the main valve goes to the return line...
    So perhaps running the motor by jumping the relay would be completely safe. A pressure buildup in the lines would simply force more fluid into the reservoir.
    DrivnXcitment likes this.
  2. DrivnXcitment
    DrivnXcitment Karting
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    I honestly don't know what position they are currently in, but from the geometry of the top linkage, it suggests that the capote flaps ONLY close when the top is down. When the top is up there's wires, hardware, etc where those flaps would go, so mine must be open. I've dug my head as much as I can in the B pillars and can't be 100% certain, but I will take the risk and assume they are open as two objects cannot occupy the same space at the same time HAHA
    Qavion likes this.
  3. DrivnXcitment
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    Now the question lies in, how do we jump the motor to get it to run?
  4. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,828
    Memphis, TN
    The top is "locked" into place when the ignition is off by the cover forcing the "kinematics" into a locked position. That's the snap that's heard when the cover goes down all the way. To release the lock, the cover rams pull back on that "kinematics" arm and that releases the lock. Kind of hard to put into words. I made a video of how the cover locks.
    DrivnXcitment, Qavion and cavlino like this.
  5. Qavion
    13,917
    Ian Riddell
    Just jumper the relay (socket) with a suitable piece of insulated wire. Expect sparks. The relay is connected to the battery permanently so you don't need to turn on the ignition.
    Sockets 30 and 87 (red/white and black wires if you can see them)
  6. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Use the Battery Disconnect before doing above to avoid the Sparks :)
  7. Qavion
    13,917
    Ian Riddell
    Interesting. I had seen your video before, but it's good for putting all the pieces together.
    Anyway, if my (latest) theory is correct, even running the motor (alone) shouldn't activate the pistons, unlocking the mechanism. The fluid is simply dumped back in the reservoir for the motor to use again.
    EastMemphis and cavlino like this.
  8. Qavion
    13,917
    Ian Riddell
    The trouble with using the battery cutoff is that it's too far away from the relay. If something does go awry, you won't be able to remove the jumper wire quickly.
    You can buy plug-in relay bypass switches, but they are a little expensive for one-off applications.
    https://www.ebay.com.au/itm/225845828599?
    cavlino likes this.
  9. Qavion
    13,917
    Ian Riddell
    Well, I suppose you could turn off the battery relatively quickly, but you might want to be close to the pump when turning on the power to make sure it is the roof pump running and check for unusual noises coming from the roof mechanisms.
  10. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Good point and that would suggest there should be a helper operating the Shutoff.
  11. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    I am on the fence regarding F430 Spider vs F430 Coupe which is my reason for my interest in how this thread progresses.
    Qavion likes this.
  12. Qavion
    13,917
    Ian Riddell
    Thanks for checking.
    Well, this kinda confuses things even more.
    Opening Sequence:
    Step #3: Flap control
    In case of a closed softtop, the flaps are basically opened. The flapmotor is activated in the opening direction
    for a short time to ensure the flap position.
    Flapmotor output open F.M/A = 1
    Limit switch Flaps open E.F/A = 1
    Limit switch Flaps closed E.F/Z = 0
    How do they define a short time? Long enough to drop the flaps completely? Logic 1 on the "Limit switch flaps open E.F/A" sounds like the flaps have to be fully down. (EDIT) If the flaps are fully down already, perhaps the short time is just to put additional pressure on the fully open/down microswitch?
    I think we really need to get a ohm reading on the flaps fully down sensor (via the ECU connector).
    I also have to figure out how the Window ECU knows that the windows are fully down, so it can send a signal to the Roof ECU giving it the ok to open/close the top. AFAIK, there is no fully down sensor (unless it's picking up the change in current when the window hits the endstops). Does it even care if the windows are fully down or is it happy with the small drop you get when opening the doors??? Maybe a Spider owner can drop their windows down a couple of inches manually and then see if the roof switch makes the windows drop further?
  13. DrivnXcitment
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    Now that I have my radio code I can do that HAHA
    cavlino likes this.
  14. DrivnXcitment
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    When attempting to lower the top, the windows roll down no matter what their position is. I tried full up, indexed with the door open, as well as rolled down partially.
    Qavion likes this.
  15. DrivnXcitment
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    Motor runs with the jumper. I only did it for less than a second
    Qavion likes this.
  16. DrivnXcitment
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    On a side note, is there anything I have to do with the immobilizer (aka alarm) for the car after disconnecting/reconnecting the master power? It now beeps and makes noises that it hasn't before and frankly I hate the beeps...
  17. Qavion
    13,917
    Ian Riddell
    Wise move. Excellent. So we are back to:
    Window ECU perhaps not giving the confirmation signal that the windows are actually down (assuming the Window ECU knows that the windows are fully down).
    "Flap down" microswitch not showing flaps fully down.
    Since the ECU has been changed, these are the only things stopping the progression to hydraulic operation....assuming it's not something silly like the Roof ECU not getting a valid vehicle speed signal. I assume your speedo is working. Did we check the engine lid switch signal at the Roof ECU connector itself?
  18. DrivnXcitment
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    My speedometer has always been working well. The windows do their magic with the switch operation, so clearly a signal is getting to the windows, but no clue if the signal goes anywhere past that. The engine lid switch seems to be working appropriately as I can get the car into gear and drive, etc. I haven't checked it a the roof ECU connector. Where was that one again? LOL all of these wires, relays, and terminals are blurring together on me.
    Qavion likes this.
  19. DrivnXcitment
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    Also how in the heck can I check any microswitches? They are buried in the running gear of the top and I can't move the top. hmmm. Stupid car haha
    17,000 miles and this thing is having this many problems. The joy of owning a Ferrari I guess.
  20. Qavion
    13,917
    Ian Riddell
    They can be checked from the ECU connector:
    https://www.ferrarichat.com/forum/posts/149417352/
    I wonder if it's possible to hear the flap motor running briefly (put the windows fully down first so the flap motor sound isn't drowned out.
  21. Qavion
    13,917
    Ian Riddell
    #121 Qavion, Nov 30, 2023
    The engine lid switch input should be on pin 5 of the upper Roof ECU connector
    (EDIT) Check the harness side (with the Roof ECU connector disconnected). I believe my image shows the Roof ECU side (or the wire side of the plug, not the face of the plug)
    I've flipped the image to show the face of the connector:
    Pin 1 is at the top left.
  22. Qavion
    13,917
    Ian Riddell
    #122 Qavion, Nov 30, 2023
    It is possible to activate the flap motor with jumper wires... see this post...
    https://www.ferrarichat.com/forum/posts/149417560/
    BUT, after what you said about there not being enough space for the flaps to move to the up position (with the roof closed), perhaps it's not wise to try to move them. If you did decide to try it, I would only power the motor momentarily (in both directions).
    Anyway, the flap switch resistance check should tell you if the flaps are in the right position for opening the roof.
    See post above for pin configuration.
  23. DrivnXcitment
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    Engine lid pins on both 31H and 2Q show no resistance lid closed and high resistance lid open.
  24. DrivnXcitment
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    Also pin 8 and 9 are showing 0 Ohms. (key off, no switch activation)
  25. DrivnXcitment
    Apr 29, 2006
    220
    St. Augustine, FL
    Bryan
    Where is 17Q the flap motor to jumper from 4Q? Any clue for polarity of which way they'd go? I know we were unsure before.
