anyone who knows wath means code E5 on the display ? the gas was empty and i fill it up but it still give's the code E5 and warm air ...
Important to point out just because you have the E5 code, it doesn't guarantee there is a problem with the heater valve motor. Often it throws a code just because it's in a bad mood. Before you tear things apart, I would turn off the main battery switch for a few minutes, then turn it back on and see what you get. If that doesn't work, check the plug on the back of the climate control module. Either wiggle it a little or unplug it, spray some contact cleaner, and plug it back in again. Be careful, it has over 20 little tiny pins for the connections. They look too small to conduct any electricity... don't bend them.
