Air Asia X A330 paint mixer simulation | FerrariChat
Discussion in 'Aviation Chat' started by BubblesQuah, Jun 25, 2017.
  1. BubblesQuah
    BubblesQuah F1 World Champ Silver Subscribed
    Nov 1, 2003
    13,232
    Charlotte
    Wow, this went on for 2 hours while they returned to Perth. Described as some engine issue. Why wouldn't they shut down that engine?
    [ame]http://www.youtube.com/watch?v=nCYz_pBFZ4c[/ame]
  2. TheMayor
    TheMayor Ten Time F1 World Champ Rossa Subscribed
    Feb 11, 2008
    106,086
    Vegas baby
  3. BubblesQuah
    Nov 1, 2003
    13,232
    Charlotte
    I hadn't considered that the engine was windmilling after shutdown. That's crazy. :eek:
    From pprune:
  4. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    "A few years back an EK A330 suffered an engine failure (main fan blade separation during the climb at about 35000 ft) during departure from Lusaka, The crew shut it down, but the vibrations from the windmilling donk were so severe that the Captain told me he couldn't read any instrumentation, and thought that the engine would separate. They had 3 pilots on the sector and the augmenting FO had to do the landing performance calcs on the portable laptop, as the touch screen fixed EFB's were unusable. He said the vibrations only receded to comfortable levels when that slowed down with flap 2. "
    This should be added to their shutdown in flight check list. Slow down and fly it with flaps 2 to the nearest airport and land. Not fly it at .80 for another 2 hours till more things rattle off.
  5. joker57676
    joker57676 Two Time F1 World Champ
    Apr 12, 2005
    23,767
    Sin City
    Deplorie McDeplorableface
    I was going to ask why they didn't slow down, descend, and land ASAP???
    Mark
  6. jcurry
    jcurry Two Time F1 World Champ Silver Subscribed
    Jan 16, 2012
    24,072
    In the past
    Jim
    When conducting ETOPs that may not be an option.
    The structure is certified for these loads considering ETOPs. The successful conclusion to this event, an uneventful landing, confirms this, right?;)
  7. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
  8. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    My rationale would have been to land at the first airport after turning around. After looking at the flight path, he flew over the entire west coast of Australia to get back to Perth. I would not overfly a perfectly suitable airport.Sounds like he wanted to get the plane back to base for MX and flew over some perfectly good airports.
  9. TheMayor
    Feb 11, 2008
    106,086
    Vegas baby
    My question
    Fake Chinese made fan blades?
  10. jcurry
    Jan 16, 2012
    24,072
    In the past
    Jim
    Understood. I'm sure corporate/maintenance was telling the pilot to get it back to base. $$ to swap an engine at a remote location, and it was flying along just great with plenty of fuel.;)
  11. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
  12. Juan-Manuel Fantango
    Juan-Manuel Fantango F1 World Champ Rossa Subscribed
    Jan 18, 2004
    14,611
    Juan
    I've wondered about the touch screens as everything is going here, GA included.
  13. beast
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    At 12:00 they discuss the process of making the fan blades. I have a feeling on this blade they had a speck of contamination that caused the failure. Titanium is a pain in the butt to work with and the smallest bit of contamination can end with deadly results.
    [ame]http://www.youtube.com/watch?v=VfomloUg2Gw[/ame]
  14. Bob Parks
    Bob Parks F1 Veteran Consultant
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    I remember the tests that were being run during the SST program to find out the best way to drill it.After running test after test they finally figured that the best way to drill it was to use a moderate speed with a lot of pressure and cooling lubricant. Tough material to mess with. I have a titanium test leading edge slat rib that was cut with numerical control machine and you can see deviations that you wouldn't see in a steel or aluminum rib.
  15. beast
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    I tried to machine Titanium a couple of times. The worst part if it is the fact that if you cant keep the part flooded with coolant it builds up and retains so much heat it is crazy. I have heard of even a few shops that had major fires break out because of not enough coolant and the chips getting to hot.
  16. teak360
    teak360 F1 World Champ
    Nov 3, 2003
    10,065
    Boulder, CO
    Scott
    That's wild. I wonder how many components in that plane were prematurely loosened or damaged by the shaking?
  17. Juan-Manuel Fantango
    Jan 18, 2004
    14,611
    Juan
    Every single fan blade is worth as much as the average family car....as you watch this video you are amazed at the engineering, what he mind of man can conceive, he can achieve.
    Here's the fan blade test segment. Equivalent to a one ton car being dropped off a 200 foot cliff.
    https://youtu.be/VfomloUg2Gw?t=2447
  18. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    I seem to remember that Peter Revson's fatal crash at Kyalami in '74 was due to Shadow experimenting with titanium in the suspension. Because the components had not been machined properly, they were severely weakened and failed. Reading this post reminded me of that long-ago tragedy.
  19. Ferrari 308 GTB
    Ferrari 308 GTB F1 Veteran
    Feb 21, 2015
    8,035
    Tropical
