air bag light | FerrariChat
air bag light
Discussion in 'Technical Q&A' started by garybryan, Jan 4, 2009.
  1. garybryan
    garybryan Karting
    Nov 6, 2006
    173
    Denver
    i replaced the oe steering wheel with a carbon fiber wheel. afterwards the air bag light is on. the battery is fully charged & was never low. before the R&R, i turned off the power via cutoff in trunk. car is a 2001 360. had to have been easiest wheel i've changed & i've removed a bunch. air bag pins have continuity that ohms the same as other bags i've checked. clockspring also seems to check ok. all connections seem proper. i see in the owners manual "never remove steering wheel. this operation, when needed, must be performed by authorized personnel of the ferrari assistance network". so i'm thinking maybe any disturbance of air bag may cause a code. i have a snapon modis scan tool which is very limited & tells me nothing on air bag codes. i checked past threads with no help. don't mean to ramble on, but i would like to kill the light (not pull bulb). so my question is, anybody know how to pull codes? or clear codes? thanks for any input
  2. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    The airbag light must be cleared with an SD box. You'll have to go to a service center that has one.
  3. flipdowt
    flipdowt Karting
    Dec 13, 2008
    204
    Mahopac,New York
    John Flip
    I have a similar problem...check in the 360/430 discussions under the title "check engine light recommendations", it may help
