Air conditioner condenser vent - 328 | FerrariChat
Discussion in '308/328' started by mike996, Jun 19, 2010.
  1. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,842
    Mike 996
    Today, for the first time, I actually was looking at the condenser with the system on. With the "hood" open I noticed that a lot of hot air pulled by the condensor fan was blowing up into the hood area. I realized that the louvered vent mounted in the passenger side wheel well behind the condenser doesn't pass very much air. If you remove that vent panel, there is a large increase in airflow.
    It seems that a heavy mesh (1/4" or larger screen would be a lot more effective for cooling than the oem vent. Has anyone tried that? I was thinking about running the car without the vent but I'm a little concerned about "large" debris being kicked up and damaging the condenser. I don't know if it would make any difference in cooling capability but it seems to me that a much greater airflow across the condenser might result in better cooling at all speeds.
  2. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    I've wondered this as well, Mike. That's a pretty small louvered area that the condenser has as an outlet.
  3. afterburner
    afterburner F1 Rookie
    3,458
    Switzerland
    Urs STEMMLER
    Just some basic thoughts - I dont know about the 308 in particular, but I have spent quite some time in wind tunnels with various projects:
    The airflow trough a radiator is due to a pressure difference between the front and backside of it.
    When you properly design (shall we trust Pininfarina/Ferrari on this?) you determine the necessary minimum intake size (to keep the drag low) in relationship to the rad's true air-transparency (most of its surface is blocked by fluid channels and fins, so the necessary intake is quite small).
    The flow is generated by adjusting the outlet size to create that pressure drop, and bigger does not necessarily mean better.
    There is a right size of outlet depending on the pressure difference between intake and outlet area, which itself is influenced by the flow via the rad.
    The airspeed in the intake is quite high (low pressure) compared to the possible max. speed through the rad (lower speed = higher pressure, which you need to get it trough the rad).
    To get the air out of the outlet, it needs to speed up quite a bit (to a lower press. than the intake to help suck the air trough).
    When you open up the outlet section beyond ideal, the flow speed drops, the pressure goes up, less air goes trough the rad.
    Also, if the condenser is vented into the wheel well, its airflow influences the pressure inside the wheel well, and therefore the lift coefficient of that corner of the car.
    This said, with a stationary vehicle, you need the fan in any case to create the lower pressure behind the rad, and the open panel would help. When you drive, the situation changes. And Ferraris are designed to be driven, not traffic-jammed...
    Try to remove the louvered panel and see if the condenser works better, and check if the front end still feels the same at speed.
    PS: making the intake bigger beyond the necessary size will also NOT increase the rad's performance, as the additional air in front cannot get trough the rad anyway.
  4. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,842
    Mike 996
    Well, of course there is no way to tell the effect at speed as far as lift/aerodynamics are concerned anywhere around here! But the airflow through the condenser with the vent removed is probably close to double what it is with the vent attached. This AM I ran the a/c with the vent on/off at idle and the air at the center dash vent was noticeably cooler with the condenser vent removed. I don't have a thermometer so I can't say how many degrees that actually was.
    Then I drove around with the condenser vent removed. I couldn't tell much difference in the performance but the compressor was short-cycling which normally indicates a low charge. So on Wed I am having the system serviced (vacuumed/recharge) so that will give me a better idea of the actual difference the vent makes, if any.
    The system was last serviced in '08 and though I have had US cars that never needed service the entire time I owned them, we all know that 3x8s are not famous for robust ac and I suspect the performance will improve at least a bit after the service and it will give me a better starting point re the vent. It seemed to work better last year, especially when I learned that the ac is most effective with the dash vents pointed at the windshield. But in the last few weeks here with some 90 degree days and high humidity, it is not working well at all.
    "shall we trust Pininfarina/Ferrari on this?"
    No, I wouldn't. European ac in general was pretty poor performance-wise compared to US ac back then. In Ferrari's 3x8 case, the ac is more like a late 50's US add-on (like the Mark IV Monitor of that era) than an actual engineered-in ac unit. It seems obvious that the system was put in to satisfy the marketers, not to actually run you out of the car due to the cold. When you consider that the same York compressor in the 3x8 was in Chrysler imperials and WOULD run you out of the car, it is clear that the system is very poorly designed from an ac capability point of view.
    IMO, (and I'm NOT an ac expert) the lack of flow through the condenser and the lack of flow from the cabin fan is the issue.
  5. afterburner
    3,458
    Switzerland
    Urs STEMMLER
    #5 afterburner, Jun 20, 2010
    As much as the 308 series was certainly not designed with a/c in mind, the Mondial was and came with it as standard equipment (sensor controlled automatic a/c-heater). Not that it is a modern design from the compressor side... (York-type double piston)
    My Mondial QV has both a louvered passage with limited flow to the wheel well, and a big outlet towards the bottom, between the rad and the wheel well.
    Despite an R134a converted system, it works OK here in HK's hot/humid climate - as long as the car moves. Stationary and above about 30°C (=airflow only generated by the fan) the overpressure switch stops the compressor quite frequently. There is a yellow light indicating that condition in the check control monitor. This happens despite the non restricted outlet on the Mondial, indicating the condenser/fan is way too small to handle serious cooling work in tropical conditions when stationary.
    The aerodynamics though work on the Mondial, as the systems happily cycles when driving.
    And yes, the interior fan's air moving capability is seriously limited, despite the car actually having functioning outlets behind the rear side glass. Slam the doors and you can feel the air getting exhausted via the little black triangles.
    PS: I haven't restored that area of the car yet...
  6. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    Mike996, it'll be interesting to learn the results of your experiment after you have the unit serviced so please let us know how it turns out.
    The heat load through the large highly sloped windshield is huge. The side windows also are sloped meaning the overhead sun enters there as well. The roof of the car is not particularly well insulated. The liner just above my head gets very warm when the car is driven in strong sunlight. If I were taking the car on a lengthy trip in the summer, I'd probably do something abominable like putting foil on the roof of the car to reflect that thermal load.
  7. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,842
    Mike 996
    #7 mike996, Jun 23, 2010
    Today I had the ac system serviced. On the way to the shop (60 miles each way) between 8:30-9:30AM the outside temp was around 80 with a good bit of humidity and it was uncomfortably warm in the car all the way with the compressor cycling on, running for about 20-30 seconds and then off for a while, repeating this all the way. On the way back, between 12:30-1:30 with temps in the mid 90s and worse humidity the compressor stayed on most of the time and the cabin was "not bad." I would have liked it a bit cooler but it was not uncomfortable at all. The ac performed better than it did the last time I had the system serviced and I believe this is due to removing the vent which provides greater airflow through the condenser.
    I now believe that the best way to increase ac cooling is to change the oem condensor from a multiple-level coil unit to a larger, single coil unit that could mount in front of the oem coolant radiator. Seems to me this wouldn't be too difficult to do and, at least in the 328, there is plenty of engine cooling capacity to handle a condenser in front of the radiator. The oem condensor has several sets of coils behind each other so it is much less efficient than a larger condensor with a single level of coils.
    I don't know if I am interested enough to actually pursue this but IMO, trying to make/find a "better" condenser to fit in the oem spot is pointless. The limited space REQUIRES a condenser with multiple layers of coils which automatically means that only the first set of coils gets "cool" air. I think any custom ac shop could come up with a suitable condenser and mount it nicely in front of the radiators. Or just purchase a condenser for a typical US car and that would probably do the job just fine.
  8. BlueMax
    BlueMax Formula Junior
    Aug 6, 2006
    291
    Norfolk, VA
    JR
    Mike,
    I went with a modern cross-flow aluminum condenser on my 79. It works very well and runs at least 50-60 psi less on head pressure (better cooling). I also rewired my relay board to bring both fans on (instead of just the right side) when the ac turns on . I don't think this is much of a factor on the 328 as I believe you can manually turn these on from the cockpit. (?)
    I was just looking at an older thread where you were asking about dimensions of the OEM blower motor and looking to put a larger one in. I did this and it just bolts right in to the stock evaporator box. There are pics on my thread "my 308 AC refurbishment". If you have specific questions regarding measurements, I have my old motor sitting in a box and could easily take those if you are interested.
    Cheers,
    J
  9. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,066
    Kansas
    Sean F
    Path of least resistance. If the hood is open it's not going to work right. When I redid my AC a few years back with a new compressor, the AC shop told me we had to have the hood closed so the fans would blow through it otherwise it all goes out the top.
    The best way to improve flow is to put in some Hayden fans, and then put louvers into that lover aluminum panel so the air blows out under the car. Otherwise it just ends up in the passenger compartment. Or put a QV style hood on the car.
  10. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,842
    Mike 996
    "When I redid my AC a few years back with a new compressor, the AC shop told me we had to have the hood closed so the fans would blow through it otherwise it all goes out the top."
    The fan pulls it through the condenser so no matter what, air is pulled through. The problem is that because of that louvered vent, the air cannot escape as fast as the fan can pull it so the flow is reduced. Opening the hood actually helps the airflow through the condenser, giving the air a larger outlet that it doesn't have with the louvered vent in place.
    The louvered vent is a problem. I did some more testing today and removing the vent makes a noticeable difference. With the vent installed and the car stopped, the cabin starts heating up immediately (condenser fan working fine). With the vent removed, the cabin stays cool when stopped. I then tried running down the road with/without the louvered vent installed. The cabin was able to withstand the direct sun, 95 degree heat and high humidity without becoming uncomfortable. With the louvered vent installed, it became decidedly uncomfortable. As I said, even without the vent it is not going to freeze you out of there but it certainly made the difference between sweating and not.
    IMO the most immediate improvement to ac is to remove that louvered vent. ;)
  11. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,842
    Mike 996
    I got a PM from someone telling me that I was full of fecal deposits and that removing the vent cannot help and may hurt. So I thought I'd respond to that publicly:
    Well, instead of calling me an idiot or whatever, Just remove the 6 screws that hold the vent and try it for yourself. It takes maybe one minute to remove it. Then, with a PROPERLY charged and operating ac system, see if it helps or not. Doesn't cost a penny to try it. However, if your ac system is not fully charged and/or otherwise operating properly, then removing the vent probably won't make any difference.
    Also note that my post was about a 328; I have no idea if a 308 is setup the same way and with the same ac components.
  12. Lawrence Coppari
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    #12 Lawrence Coppari, Jun 25, 2010
    Mike, I agree with you. I don't see how removing the louvered section could possibly impede air flow with the fan pulling wind through the condenser and then having to push it through the relatively small louvers. By removing the louvers, you're lowering the back pressure on the fan. I think the fecal deposits were erroneously deposited.
