Air conditioner - Heater do whatever they want | FerrariChat
Discussion in 'Boxers/TR/M' started by SOFTWAREGUY, Apr 4, 2015.
  1. SOFTWAREGUY
    SOFTWAREGUY Karting
    Oct 20, 2004
    153
    I was driving along on a hot day, the air conditioner was blowing cold.
    After a few miles, it started blowing hot! Not outside air temparature, heated hot.
    Later on it decided to blow cold again.
    Has anyone had this happen to them? Any thoughts?
    Many thanks.
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,541
    romano schwabel
    have a look at the fuse box
    may be bad connection and when it was blowing hot there was no connection and because of vibrations it suddenly had contact again?
    or may be less refrigerant in the system?
  3. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    Melting Fusebox ........
  4. ago car nut
    ago car nut F1 Veteran
    5,502
    Madison Ohio
    David A.
    The heater hot water valve under the pass side. It defaults open all the time. It grounds to close. It could be the automatic climate control. Mine has done this intermittent. Under the pass side foot panel, I was thinking about plumbing in a manual water shut off valve. I rarely drive my TR in cold weather.
  5. SOFTWAREGUY
    SOFTWAREGUY Karting
    Oct 20, 2004
    153
    Many thanks. Will check things out on Monday.
  6. Steve Magnusson
    26,826
    One thing that will be a strong clue for where to investigate is if the passenger cabin air blower also stops working when the air (wrongly) goes hot (if the coachwork was moving when "it started blowing hot", the ram air effect will still bring air into the passenger compartment even if the blower is dead too):
    If air (wrongly) goes hot, and the cabin air blower stops working = very likely a fried connection in the k white connector (or some other fault causing the whole AC system to lose +12V power).
    If air (wrongly) goes hot, but the cabin air blower keeps working = a more subtle control (sensor, AC ECU, hot water valve) problem.
  7. chabch
    chabch Formula 3
    Aug 15, 2010
    1,075
    France
    Christophe
    Spot on! +100
  8. SOFTWAREGUY
    SOFTWAREGUY Karting
    Oct 20, 2004
    153
    Can you tell me where the "k white connector" is located? I was told it is in the passenger side, but cannot locate it.
    Many thanks.
  9. ago car nut
    5,502
    Madison Ohio
    David A.
    K white connector is under front bonnet. in the fuse box. Looking at the fuse box from the front. K white connector is top left, horizontal, under headlights and condenser fan relays
  10. SOFTWAREGUY
    SOFTWAREGUY Karting
    Oct 20, 2004
    153
    Many thanks ago car nut!
  11. Steve Magnusson
    26,826
    #11 Steve Magnusson, Oct 16, 2017
    The k connector is on the US Passenger side (RH side) of the TR fuse-relay panel as shown in the pic above. (Great, now I've got a new ***** -- the default location for photos is above the text, and the "attach" stuff doesn't work like before...)
  12. ago car nut
    5,502
    Madison Ohio
    David A.
    Not related to this post. But can you tell me how to add arrows like above?
  13. Steve Magnusson
    26,826
    I just put the pic in an Excel file, add the arrows/text boxes/whatever, and then use the snipping tool to make a .jpg file out of the displayed Excel page.
  14. Melvok
    Jul 25, 2008
    14,268
    Mel
    Any news on your AC problem Softwareguy or what ever your proper name is ?
