Air Conditioning and Radio fuse blowing? | FerrariChat
Discussion in '456/550/575' started by Steve Miklos, May 6, 2022.
  1. Steve Miklos
    Steve Miklos Karting
    Feb 20, 2008
    65
    34562
    Hi the 20 amp fuse is failing blower works compressor does not radio quits. I isolated radio and fuse still blows any thought? Car is 2000 550 Thanks in advance!
    Steve
  2. Qavion
    Qavion F1 World Champ
    14,260
    Ian Riddell
    20 amp fuse #22 only powers radio & compressor clutch compressor clutch failed or clutch wire shorted to ground blower on different fuse disconnect wire on compressor and see if fuse still blows punctuation helps sometimes you're welcome ;)
  3. maranello72
    maranello72 Formula Junior
    Jul 4, 2009
    353
    Munich, Germany
    Stefano
    Steve,
    I've had this issue on my 1999 550. It turned out to be the AC compressor leaking oil onto it's electromagnetic clutch's winding. As a result the winding's isolation dissolves and you have a short circuit. The compressor's front seal is the culprit and it can be replaced, but I chose to get a new compressor.
    The oil also drips on the alternator, and you should see a few drops directly under it on the belly pan. This could eventually damage the alternator.
    Stefano
    Qavion likes this.
