Air conditioning compressor oil | FerrariChat
Discussion in '360/430' started by London, Feb 20, 2014.
  1. London
    London Karting
    Aug 29, 2009
    189
    London
    The service schedule for the 360 calls for
    at major services. How do you check the quantity of oil in the compressor?
  2. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    I don't have an answer but would be interesting in knowing if anyone actually changes there refrigerant and filter?
    Alan
  3. jpk
    jpk Formula Junior
    My A/C was blowing kinda warm. At my last service they topped off the refrigerant as it was quite a few PSI below full.
  4. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    ...you can't "check" the level and unless your system has a leak, there is no need to add oil.
  5. London
    London Karting
    Aug 29, 2009
    189
    London
    #5 London, Feb 20, 2014
    I changed the AC filter last year, as it was recommended to me in order to preserve its efficacy at removing moisture from the system. After all, these cars are getting on to be 10+ years old and I doubt many ever had their AC filters replaced (although the service schedule says replace every 2 years). Unfortunately in my case the (steel) nut joining the filter to the (aluminium) AC pipe had seized, and I stripped the thread of the aluminium pipe trying to un-seize it.
    Now, guess what is more expensive - the AC filter or the pipe it is connected to? I'm sure you guessed correctly - the latter, P/N 66090200, is £209+VAT+overnight shipping from Italy since I was in a hurry...
    Anyway, I don't regret doing it, as I had suspected the filter was as old as the car itself, so it was a good thing that I changed it.
  6. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,924
    Weston, FL
    Scott
    You can't. The oil is suspended and flows through the entire system.
    Scott
  7. jpk
    jpk Formula Junior
    What is the part number for the AC filter?
  8. Mozella
    Mozella Formula Junior
    Mar 24, 2013
    905
    Piemonte, Italia
    #8 Mozella, Feb 21, 2014
    I agree. "Checking the oil level" makes no sense since the typical way of doing this (for an automotive A/C system) with a rotary compressor is to add a prescribed amount of oil to a clean system when starting from scratch.
    Here are a few hints. The "filter" in the above photos is actually a "receiver-filter-dryer". It's job is explained in the name. It acts as a reservoir for refrigerant, it filters out debris, and it absorbs moisture.
    Here's why: The A/C cycle starts when gas is compressed and sent to (usually) an air type radiator ( a condenser usually located near the engine radiator) to reject much of the heat acquired when a gas is compressed. Because the refrigerant is very carefully formulated for the system in question, this cooling of the hot, high pressure gas results in it condensing into a warm liquid.
    Next it goes to the expansion valve where the warm liquid is expanded back to a gas by passing through a tiny orifice, usually equipped with an automatic throttling device. If this tiny opening is clogged with a piece of dirt or if water in the system freezes there, your A/C won't work. That's why you need a filter and a dryer.
    There is a significant drop in temperature when the liquid expands to a gas as anyone who has used a hand held butane torch knows. This cold gas flows through another radiator (the evaporator) located inside the passenger compartment where a fan blows cool air onto the occupants. From there, the now warmer gas returns to the compressor. That's it. You have passed Air Conditioning 101.
    Because the compressor is driven by a shaft, it has a seal separating the high pressure refrigerant from the atmosphere. This rotating shaft seal will always leak a tiny bit which is why you need your system checked and topped off every 4 or 5 years. Letting the shaft sit in one position harms this seal, so you should run your A/C for a few minutes every month. Of course, Ferrari owners typically violate this rule, but do your best; i.e. when you do drive your Ferrari, don't forget to turn on the A/C even if it's cold outside.
    Your home refrigerator, by contrast, has everything (including the electric motor) sealed in a can, so it doesn't typically leak and might run for 50 years with a little luck.
    I would argue against changing the receiver/filter/dryer on a regular basis if the A/C is working. When it no longer cools correctly, find any A/C technician (he/she need not be a Ferrari mechanic) and attach a set of gauges so he/she can check your system. If there isn't a leak other than the normal small leakage associated with the shaft seal, perhaps the addition of a little refrigerant is all you need. But whenever you open the system, be sure to change the receiver/filter/dryer, evacuate the system to remove any moisture, and then recharge with the proper amount of refrigerant (usually done by weight)
    By the way, these receiver/filter/dryers come in many sizes. Many have a sight glass built into the top but not all. As long as the fittings are an exact match for your car then any receiver/filter/dryer near the correct size will be fine although since they're usually connected with rigid tubing, you'll have to find one with the correct orientation with the inlet and outlet in the proper position because you might not have much ability to move the connecting tubing. This varies from car-to-car. Consult with your A/C technician and/or a smart auto parts store counter clerk.
  9. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    All due respect, what you are showing is not an A/C filter but the receiver drier with the trinary switch. The receiver is like an accumulator that has a diseccant cartridge. They do not need to be replaced every two years, only when the system is serviced (b/c of leaks) since moisture may saturate the diseccant (45 mins in the oven can help if it is inobtanium). Trinary switch is a safeguard for the compressor which prevents the system from running below a certain pressure. BTW, the compressor can be rebuilt for less than $300, and most pipes and parts can be had at a fraction of the factory prices (A/C systems are as basic as a two stroke engine).
  10. London
    London Karting
    Aug 29, 2009
    189
    London
    #10 London, Feb 22, 2014
    The AC "Dehydrating Filter", to give it the name Ferrari uses, is part number 65628300, approx £66+taxes in the UK from Eurospares.
  11. London
    London Karting
    Aug 29, 2009
    189
    London
    Thanks for the clarification. I called it an "AC filter" since I was too lazy to type "dehydrating filter" which is what Ferrari calls it. Replacing it every two years is what the service schedule calls for but I do agree that it sounds a bit too much. However I certainly won't be waiting another 10 years to replace mine this time.
    Btw the pipe I had to replace has some kind of sensor attached to it, and it is a special shape for RHD cars (LHD cars use a different pipe) - I'm not sure there was any alternative but buy the original Ferrari part as I did...
  12. jpk
    jpk Formula Junior
    Thanks! Car is in for service and I'm having them change the part out. Learn all kinds of interesting things on FerrariChat. Maybe makes me slightly more OCD than is required learning of all these maintenance items, but it feels good.
