Air filters for velostacks | FerrariChat
Discussion in 'Technical Q&A' started by aasprou, Nov 22, 2005.
  1. aasprou
    aasprou Rookie
    Jan 29, 2005
    9
    Anyone done this recently on a euro carb 308GTB,? would love any links ideas etc.. I recently replaced the OEM air filter with an ITG foam job,
    and before fitting it , decided to start the car. Mmmmmmm!
    nice really nice!!!!
    Stas.
  2. walawdog
    walawdog Formula Junior
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    #2 walawdog, Nov 22, 2005
  3. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Where did you get those? Very interesting.
  4. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    If you want "the sound" you need to remove the baffling from the airbox. You will be AMAZED at the increase in sound quality plus MUCH better breathing with this mod using the stock air filter. Do a search for "Airbox Mod" and read all about it.
    Birdman
  5. walawdog
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    I ordered my individual air cleaners from a local shop in Auburn Washington, but, I think they came from Weber/Redline? I can check on it if you want to do a similar set up. All I can say about them is that they need to be cleaned often, and they come apart super easy. Also, you will need to order the short velocity stacks from Durable One to be able to use them as the stock stacks are way too tall to fit.
  6. morcal
    morcal Formula Junior
    389
    Turin,Italy
    Cal
    #6 morcal, Nov 26, 2005
  7. morcal
    389
    Turin,Italy
    Cal
    #7 morcal, Nov 26, 2005
  8. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    I know this has been dscussed in the past but doesn't the hot air get sucked in and also the lost of the air ram effect get lost due to removing the airbox?
    I'm with Birdman on the baffle removal.
  9. morcal
    389
    Turin,Italy
    Cal
    #9 morcal, Nov 26, 2005
  10. Sloan83qv
    Sloan83qv F1 Rookie
    2,537
    with BIG Dave M.
    Little Dave M.
    #10 Sloan83qv, Nov 26, 2005
  11. aasprou
    aasprou Rookie
    Jan 29, 2005
    9
    Wow ! I like where do you get these from?
    stas
  12. walawdog
    Nov 9, 2004
    829
    Bluefield, WV
    Anthony
    Look at my response above. I think you can get them from Webber/Redline.
  13. aasprou
    aasprou Rookie
    Jan 29, 2005
    9
  14. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Can someone talk a little about the science/art of air intake? There are several issues I'm confused on.
    First, it seems velocity stacks will allow dust in and wear out your pistons etc. in short order, especially on close tolerence engines like in a Ferrari. Is that a concern for you guys?
    Second, in my car at least, such an arrangement leads to decreased HP. I have the air filter is a seperate metal box, then a flex hose to a large airbox that's attached to the side of my side draft carbs. The reason for this convoluted air path is my CV carbs need a nice uniform air flow to give best performance. Some people have used K&N filters with varying sucess, but the stock arrangement is really the best. Do downdraft carbs, or Webers, have a different airflow requirement?
    So far all the comments are positive concerning the use of velocity stacks on a Ferrari with the Webers. So...what's the deal?
    Ken
