Air Filters | FerrariChat
Air Filters
Discussion in '206/246' started by djh4570, Oct 13, 2006.
  1. djh4570
    djh4570 Karting
    Sep 14, 2006
    118
    NewZealand
    Danny John Hayes
    can somebody tell me the part number for a replacement air filter for my Dino. Not the ferrari number (236e-181839) a fram or K&N etc, or alternative manufacturer.
  2. celestialcoop
    celestialcoop Formula Junior Silver Subscribed
    Mar 20, 2006
    715
    Coop
  3. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    Keith Mitchell Wintraub
    Soon after I restored my Dino, I found an original Carrello air filter (paper with a metal wrapping) so I installed that. I looked at these new style filters but I wasn't sure if they were any good. It just looks like carpet with rubber doughnuts on the end!
    Perhaps the new ones are better? equivalent? I know there are some pretty technically savvy guys on this alias and owners who have put these things to the test. Let me know your thoughts/experience with them.
  4. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Ditto on the E-9240 K&M. Also if your into paper filters the Wix 42220 fits the bill.
  5. dm_n_stuff
    dm_n_stuff Four Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2003
    43,725
    26.806311,-81.755805
    Dave M.
    I had a TR6 with a motor that was tweaked by a Brit vintage racer and mechanic. It was making a ton of extra HP. He swore by K&N filters, and I had them in that car. I have not had them in any of the other cars I've owned.
    I'm putting one in the Dino on the next maintenance, but I'm still not sure they really make a difference. And if they do, the performance increase probably wouldn't be noticeable anyway.
    Don't they claim to filter out more particulates and make more horsepower?
    DM
  6. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Actually, the paper filter is better at keeping out the finest particles but the K&N flows more air and does a respectable job at filtering. If you look at the small size of the motor and the very large size of the Dino filter area, you can probably get by with anything available and not find any difference in performance. I tried the paper Wix and now have the K&N and notice no difference. The air cleaner is not the place where you will find restriction in the 246 so you might as well get the best paper you can find.
  7. celestialcoop
    Mar 20, 2006
    715
    Coop
    Here are some other numbers.
    Napa (FIL) 2220 for USD$15.09 - It looks like a fit.
    http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=FIL&PartNumber=2220&Description=Air+Filter+(Gold)
    I'll check with my local NAPA store for avail on this one.
    Also try:
    Fram CA122PL
    AC 136C
    WIX 42220
    Purolator AFP 28
    Fram 2220
    I have not looked up these last five, yet. Anyone have input?
  8. celestialcoop
    Mar 20, 2006
    715
    Coop
    Let's try that URL again:
    napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=FIL&PartNumber= 2220&Description=Air+Filter+(Gold)
  9. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    The origional "Fuzzy" air filter for the Dino's is hard to beat. If maintained properly they last 20 yrs with excellent filtering. Makes it a darn good value over the long run.
    Dave
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  11. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    So, are the fuzzy ones original or are the Carrello air filters with the metal mesh and the paper filament original? I'll have to pull out my parts book and check it out.
  12. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Carello?
    I've only seen UFI as original OEM.
  13. celestialcoop
    Mar 20, 2006
    715
    Coop
    Dave,
    I have one; the outside is a bit dusty and is decorated with a few webs & leaves, but seems pristine on the inside. What manner of maintenance do you recommend?
    Thanks,
    Coop
  14. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Soap and water dunking, a good rinse off, dry em out and stick it back in. The paper replacement does filter a bit better. Each owner has to decide what is "good enough" for themselves. I still have the fuzzy filters in my cars.
    Dave
  15. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    I'll have to get a photo of the Carrello air filter just so you guys don't think I'm making this up! When I bought my car, it had the UFI fuzzy in it. In truth, I'm sure Dave is right on - all of the filters are probably good enough.
    ...Keith
  16. celestialcoop
    Mar 20, 2006
    715
    Coop
    Thanks, Dave. I'll try that.
    Just for grins, I picked up a Napa 2220 (WIX H/D Truck Filter) to verify that it fits. By comparison with the 'fuzzy' filter, it's a tad smaller in O.D. & I.D., and is slightly longer. (Go to the Napa website & it gives you the specs.) The ends are flat, too, but don't have that raised, flexible rubber flange around the inside edge at both ends. However, with a bit of gentle "compression" between two flat surfaces, the cylinder shrinks slightly & fits, save for a slight gap between the lid & cannister after tightening the knurled knob. I'll re-tighten after a few heat cycles & see if the lid will snug up to the cannister. A fresh (thicker) rubber gasket on the lid might also help. At any rate, there is a complete seal inside at both ends of the filter, so all air is cleaned.
    'trust our discussion has helped, Danny John. Any luck Down Under?
  17. djh4570
    djh4570 Karting
    Sep 14, 2006
    118
    NewZealand
    Danny John Hayes
    Many thanks to all those who joined in i found somebody local who can do the K&N filter so i will try that and see how it goes in the fresh NewZealand air.
  18. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  19. 4redno
    4redno Formula 3
    Mar 21, 2006
    1,067
    Seattle, WA
    That is indeed what I classify as a fuzzy filters. The filters which use paper have a metal mesh over them, which is most certainly not fuzzy.
    Cheers...Keith
  20. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Here is what I use, the brown fuzzy UFIs.
    I bought a long term supply of air, oil and fuel filters.
