Air Filters | FerrariChat
Air Filters
Discussion in '365 GT4 2+2/400/412' started by Godspeed!, Sep 3, 2008.
  1. Godspeed!
    Godspeed! Karting
    Dec 1, 2006
    137
    Mandeville, Louisian
    Dave Foley
    Anyone know of a source for the "FM 10416" air filters or alternatives?
    Also need to replace the mangled soft rubber seal for the air box cover. Thanks!
    BTW survived the storm, no major damage, except to me after helping a neighbor cut up and haul to the street a downed large pine! Worn out!
    Godspeed!
    Dave
  2. b3tech
    b3tech Karting
    Apr 17, 2007
    100
    Los Gatos CA
    Boyd Bowdish
    Dave,
    thank God about the good fortune against Gustav. Air filters for the carbed cars should be replaced using a K&N. Size the internal opening from the tube leading to the air box and place the air filter just in that inlet. The original filter does nothing except filter air at that point. The rest of it, does nothing.
    Good Luck
  3. britalian
    britalian Karting
    Feb 10, 2006
    64
    Atlanta
    LL
    We are the primary supplier of these filters in this country. They are available in our ebay store here http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=350095651732 While anything is possible... I am not convinced without further research that the filters in C/4s and 400C cars only have air pass thru them at the incoming tip. I will concede that this is probably the place where more of the heavy particles build up as the air comes into the air box.
  4. Rifledriver
    37,105
    You are correct Lee. While the end facing the snorkle will naturally get the most dirt the entire area of the filter material has air space around it and allows air flow.
    A fliter stuck in the snorkle would have considerably less surface area, would clog faster and restrict airflow dirty or clean.
    Those air boxes were hardly a terrific design but neither was a bunch of side draft carbs placed directly over the exhaust manifolds. If lower cost air filters are what is desired that could be more easily achieved by installation of a Chevrolet 350 and a down draft carb.
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    You are wrong.
    Bad advice.
  6. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    Hey, doesn't someone in Farmers Branch (Tx.) have that set-up for sale? LOL
  7. It's Ross
    It's Ross Formula 3
    Jul 30, 2007
    2,028
    Barrington, Ill. USA
    Ross
    According to the side panel on a UFI box the same filter is also used in Volkswagon K70, which I think is the micro bus. How humble and inexpensive those must be.
  8. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    The VW K70 was a sedan produced for a few years, only sold in Europe I believe.
  9. Godspeed!
    Godspeed! Karting
    Dec 1, 2006
    137
    Dave Foley
    Yep, I have done a bit of air box design in the past, and am in agreement with Lee and Rifleman. A lot more to all this than most people think. But.............how cool what is a K70 Micro bus??? With a good Chianti in hand, I will search the net.
    Thanks for all the responses!
    Godspeed!
    Dave
  10. britalian
    britalian Karting
    Feb 10, 2006
    64
    Atlanta
    LL
    Close... but no cigar. The air filter you are referring to is not the filter this thread is discussing. The 365 GTC/4, 365 GT4 2+2, and Carb 400 use a very special air filter that does not fit any mass produced cars. However the Volkswagen filter you are referencing is indeed the same UFI number for the 400i and like the VW the 400i air filters ($26.50 ea FNA) list for about 10 % of the Carb filters ($263.17 ea. FNA)
    I understand trying to save a buck and there are a few cross references out there that are legitimate ways to save; but IMO the time you spend hunting down the mostly "teaser" cross references is likely worth more than the savings they offer. Usual scenario is to save a few bucks and have a questionable non original part & worst case you spend a lot of time to risk seriously affecting your car.
    And what about the long term issues. When you go to sell your car what is the next buyer going to think when he gets in here and looks at these posts? I know I've seen some Pep Boys test mules in here that I would not feel comfortable buying. That is unless the price was heavily discounted and then where did that savings go?
  11. Schumi
    Schumi Formula Junior
    Jun 5, 2002
    867
    Missouri
    Daren
    What is the UFI part number for the air filter on a 400i?
  12. blkprlz
    blkprlz Formula 3
    Mar 24, 2007
    2,169
    Tampa bay
    Bruce
    The Ferrari # for the UFI filter is 113283.
    UFI's # is 30 830 00
    Here are some x-ref's:
    Fram: CA 3135
    Mann: C 3997
    V.A.G.: 028 129 635 A
    Knecht Gruppe: LX 221
  13. Schumi
    Jun 5, 2002
    867
    Missouri
    Daren
    Thank you.
