Air filters | FerrariChat
Air filters
Discussion in '308/328' started by ferrariowner, Nov 3, 2020.
  1. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    What air filter do you use? I use the K&N but after watching this video I have some concerns.
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Simply put on a purely scientific scale the OEM type paper filters keep the most particles out of the engine. That said the extra debris a K&N filter lets in is so insignificant that it makes no difference to engine life. Think of it like spitting in the ocean vs peeing in the ocean. Either way you are not changing the volume of the ocean although a scientist will tell you that you are.
    ferrariowner likes this.
  3. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I use the standard one and see no benefit to KN.
    Milkshaker0007, epb0 and mike996 like this.
  4. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,870
    Mike 996
    K&Ns have been demonstrated innumerable times to be less effective at filtering than paper filters. There have been instances where KN filters actually provided more airflow than a standard paper filter but this will depend totally on the design of the OEM filter. IOW, if the OEM filters' design requires the use of a paper filter that does not have sufficient capacity for the engine, the KN may provide a power (and wear) increase. OTOH, if the OEM design does provide sufficient capacity - which most do - , a KN will do nothing but degrade the quality (cleanliness) of the air getting into the engine.
    JCR and epb0 like this.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,951
    Isle of man- uk
    The oem filter will let enough air pass for max engine power, what are you gaining by putting a filter in with more or bigger holes
    mike996 and epb0 like this.
  6. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    I use UFI paper
  7. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    The reason I used the K&N filter is due to the large turbo/hi boost. I don't know how restrictive the paper filter is in this regard.
  8. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,606
    California SF bay area
    Paul
    When I first got the 308 I bought a K&N. It didn't fit. You could force it in but it wasn't a perfect fit so I dumped it and went back to the UFI. In regards to performance, at any given point in time you have two cylinders drawing in air, one 90 degrees behind the other. You have a peak hp rpm and a redline rpm and it would seem to me that the engineers who designed this engine wouldn't then attach an air intake that was incapable of meeting the demands of those specifications. So, in my opinion, the performance increase claims made by K&N are wildly exaggerated.
    epb0 likes this.
  9. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Paul,
    I tend to agree. But I don't think they considered adding 22-25lbs of boost which is about double the needed airflow over naturally aspirated engine. I doubt the K&N is appropriately sized in that regard either :(
  10. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    It's simple. A fitter is a resistance to flow. The resistance is dependent the permeability or porosity of the filter. Lower resistance means greater porosity. But the greater the porosity the poorer the filtering ability. Porosity depends on the size of the holes in the filter element. If you want lower resistance with the same area you have to increase porosity. If you want lower resistance with the same porosity you have to increase the area of the filter. K&N use an element with greater porosity to reduce flow resistance and tries to compensate for the reduced filtering ability by applying oil to the element which makes it "sticky". It somewhat similar to furnace filters that use electrostatic charge to make the filter "sticky" to dust particles. But in the case of the K&N the stickiness doesn't generally compensate enough to bring the filtering ability up to that of the dry OEM filters.
  11. johnk...
    Jun 11, 2004
    11,214
    CT
    John Kreskovsky
    Expanding on my previous comment with respect to this post, when the engine is sucking in air it "swallows" a certain volume of air. The key here is "volume". With a filter of lower resistance the pressure drop across the filter will be lower. Since the density of the air, thus the mass of air in a specific volume is higher if the pressure is higher, reducing the pressure drop across the filter will increase the mass of air taken into each cylinder. Then, assuming that the mixture (A/F ratio) is corrected for the actual mass ingested (like K-jet with lambda control) you inject more fuel and can get a little more power. With carburetors, not so much.
  12. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,803
    Australia
    Mark R
    UFI paper on my 328.
    Good enough for Ferrari, good enough for me.
    Milkshaker0007 likes this.
  13. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,606
    Paul
    Well I'm not familiar with your system but it would seem the boost is downstream of the filter and it's being controlled by maybe a waste gate or something like that so the filter is not the limiting factor but yes, in such a case the original intake system is not speced for those parameters.
  14. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    Based on the square inches of filter area, the stock (carbed car) paper filter is good for somewhat over 400 rear wheel HP, before you start getting above 1" Hg (~3%) pressure loss across the filter. About ~90 sq-in of simple surface area.
    Based on dyno experience on other motors. If you have an injected car, figure 90 sq In of simple surface area of your filter is good for 400 RWHP
    I wouldn't ever run a K&N filter, they were rejected for OEM use by Chev and Chrysler because of lack of filtration, plus to make them work even that good, you have to oil and wash them regularly
    Doug
    mike996 and waymar like this.
  15. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    I tend to agree Doug. Surprisingly they are approved on certain aircraft and you would think they have a higher standard.
  16. Imatk
    Imatk Formula Junior
    May 6, 2007
    765
  17. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,805
    Cerritos, CA.
    If you live in an area where the environment is clean, K&N filter is ok
  18. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,606
    Paul
    Aircraft run in a different environment and most have carb heat or alternate air systems that bypass the filter entirely. A car is bound to the ground behind other vehicles that are constantly kicking up dust and debris so you wouldn't ever want to run unfiltered intake air for any significant length of time.
  19. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    Some aircraft operate from dirt and grass runways.
  20. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,606
    Paul
    Even so it's only take off and landing and they don't do that following behind someone kicking up dirt. Cars operate in that environment 100% of the time. Look at a typical Cessna or Piper Aircraft that could have an O-520 which is an eight and a half liter engine and the filter is tiny compared to a car so they have to be pretty free flowing.
  21. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    Not much road dust at 10K feet.
    Doug
  22. Dr Tommy Cosgrove
    36,385
    Birmingham, AL
    Tommy
  23. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    If you still have the original (restrictive) air box on a carb car, air filter differences are irrelevant.
  24. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    The carb airbox isn't that restrictive.
    The inlet sq inches are good for 400 HP, again, based on dyno results from other air intakes.
    The air flow area on the sides, between the filter and the airbox, could be larger, but doesn't look like it is an issue, from experience, but I have no actual data to back that up.
    I seem to recall, but am not sure, that there is a sound baffle between the inlet oval, and the air filter, that may restrict flow by some unknown amount. The flapper valve for the heat riser may also create turbulence and restrict flow by some unknown amount.
    Only way to tell for sure is to measure pressure differential inside the air filter element, vs atmosphere or boost pressure, at high RPM WOT. And differential more than 6" water column, is restrictive.
    Doug
