AIR FLOW PROBLEM on 348 TS | FerrariChat
Discussion in '348/355' started by Liuck420, Sep 4, 2015.
  1. Liuck420
    Liuck420 Karting
    64
    Liuck
    Hi guys , I write to try to solve a little problem with a 348 ...
    He told me that is not a problem " new " that appeared on the 348 ..
    in practice FAN of AIR , freezes at best, and does not respond to commands to lower it , it goes off ...
    To make it stop you have to give a few pats the side of the center tunnel where the uprights and put the panel controls ... and maybe come off , but sometimes by chance again ... it's like a contact or short circuit . I do not know .... but is Annoying
    Can someone help me??
    Thank you
    Luca
  2. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    Try a search on 348 HVAC. There are quite a few threads about the issues with them. The connectors do come loose so I would start there. Pull it out clean up the connections good and plug it all in good and tight. See if that works and go from there. good luck.
  3. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
  4. bayferrari
    bayferrari Karting
    95
    Bay Area
    William
    Is Ricambi still rebuilding the units? Video is 8 years old.
