Air horn ? | FerrariChat
Air horn ?
Discussion in '348/355' started by Carmellini, Apr 7, 2023.
  1. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    968
    One of my air horns is not working. Are the horns serviceable? I see new ones are cheap, but they look like plastic ( v. metal)?
  2. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    The new ones are cheap but they are plastic as you say. Not sure if the original is serviceable or not. I kept a set of metal ones just in case for this reason.
    The air horn can be removed on the old version from the end that produces the sound. So perhaps you can buy the new ones and swapped over the horns.
    Jackie and bill likes this.
  3. Qavion
    Qavion F1 World Champ
    14,281
    Ian Riddell
    The horn is probably just a vibrating reed in a tube. Did you try flushing it out? Did you check the air line was not blocked?
  4. Carmellini
    Jul 16, 2019
    968
    Yes, inside is a thin brass vibrating reed. Nothing blocked, nothing dirty, and no damage to the reed...???
    I opened it up, inspected and put it back together and it works perfectly....go figure. I wish I had taken
    some photos......
    Only issue, was that I could not get it to snap back together so I used JB Weld plastic bonder and all good.
    Qavion likes this.
  5. Smoothur
    Smoothur Rookie
    4
    Alex Mills
    Ah, the classic air horn conundrum! Been there, done that myself. It's a real downer when one of those bad boys decides to go on the fritz.
  6. Smoothur
    Smoothur Rookie
    4
    Alex Mills
    Now, when it comes to serviceability, it really depends on the horn. Some are built to last and can be tinkered with to get 'em back in working order. But others, especially those cheaper plastic ones, tend to be more disposable.
    If you're leaning towards a replacement, I recently stumbled upon https://bosshorn.com. They've got a bunch of horn options, from classic to custom, so you might just find the perfect fit for your ride.
