air in f1 gearbox line - 360 spider | FerrariChat
Discussion in '360/430' started by fengpi, May 19, 2011.
  1. fengpi
    fengpi Rookie
    Jul 14, 2010
    15
    #1 fengpi, May 19, 2011
    Okay,
    so I did a stupid thing.
    I stucked out some of the fluid out of my f1 gearbox....to replace it with new fluid.
    I went too far and sucked some out of the lines....
    I put the new fluid in.
    Anyways I went to put it into Neutral (I left my car in first gear) the F1 light came on, a siren came on, and my N sign just flashes at me (so it's not going into Neutral properly).
    Needless to say it doesn't start.
    And every time I open my driver door, my pump trys to go, no matter how quickly I open and close it.
    So I'm guessing I have air in my lines.
    Any suggestions....besides having it towed to a shop? Cause I can't tow it because it's stuck in gear.
  2. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    SD2/SD3
  3. tazandjan
    39,175
  4. Juri
    Juri Formula Junior
    604
    Houston, TX
    Juri
    #4 Juri, May 19, 2011
    Taz and Fengpi,
    Just to reassure, I have performed this purging procedure again on anoter 360F1 earlier this week and it worked well!
  5. SED
    SED Karting
    Nov 10, 2003
    61
    Stockholm
    Thomas
    Try to change gears back and forth from 1st to Neutral, after some attempts the gear indicator stops blinking, put it in N and turn of the ignition, now you can try to start the car again... (happened to me once). Try it.
  6. fengpi
    fengpi Rookie
    Jul 14, 2010
    15
    What I did guys is I reset the ECU, then I put it in first gear, held it till it went into neutral. And it started like a dream.
    Thx guys
