Air in Mechanical Fuel injection System | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by Napolis, Mar 25, 2009.
  1. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    960
    Arizona
    Jim
    Doing a little brainstorming on this issue. Is it possible the low pressure pump is on its way out? I.e. if the low pressure pump is not putting out enough capacity, the main fuel pump could be sucking the FI tank dry after a fairly short period of time. When you let the pumps come up to pressure when you start it, the low pressure pump has enough capacity to partially fill the FI tank. But when you run the engine the low pressure pump can not keep up with demand. Have you checked the low capacity pump to see if it is functioning like it should?
    Cheers Jim
  2. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    I'll check on Monday for the Bosch part #. There are only a couple that will maintain flow/pressure and they aren't cheap, I think they are Porsche Turbo maybe. Certainly would suspect your high pressure as I believe in "if things don't change, they must stay as they were", therfore something occured while sitting. Also where and what filters are used, is there a fuel cell with foam?
  3. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Thanks All.
  4. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Ok. It seems Sal has been mixing in a touch of oil for years so that's under control. We spoke to Kinsler who's a friend. We're going to ship her to Brian Joseph who's shop is near Kinsler. Brian restored our Duesenberg and Studz. Sal is going to work with Brian and Kinsler to get to the bottom of this once and for all and have our pumps, high and low, check valves and distributor checked and bench flowed. We'll then test out there and bring her home. May take her to Meadowbrook first.
    Will Report.
    Thanks!!
  5. ggjjr
    ggjjr Formula Junior
    Nov 11, 2003
    932
    Detroit
    George
    Jim,
    Do you spend any time visiting Brian's shop?
    George
  6. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Hi
    Yes. A great shop. Will definitely go there again when 0846 is there.
    Best
  7. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Good luck with it - when I saw this title come back up to the top, I was hoping you had it fixed and were going to tell us the answer.
    I for one am totally baffled how air (or whatever, fuel vapor?) could get into the high pressure part of the system unless it came in through the vacuum side of the low pressure system...but I guess that's just me.
    Be sure and let us know what happened!
  8. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #58 Napolis, May 12, 2009
  9. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #59 Napolis, May 13, 2009
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    That test setup is just "Rube Goldberg" enough to be the work of a real genius. ;)
  11. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Been following this with interest. I think the suggestion that the feeder pump can't keep the accumulator tank up to level is a great one to investigate.
    Otherwise we need to bear in mind that in a pressurized system, the ingress of air is rather difficult.
    Could it be that the primary mechanical pump has too much pressure, and thus thepressure difference over the secundary pump is too little?
    For an electrical pump, I'd think that even the pump of a Jag EFI V-12 would have enough capacity, and they are plentyful from a junkerif just to try it out.
    The test set-up sure looks intrigueing!
  12. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Problem is not plumbing or pumps. Problem is Lucas Unit. Shuttle is worn and way out of spec. Rebuild should fix problem. While we're at it we'll also Blueprint slide throttles, intake manifold, pumps, PSI relief valves, one way valves, injectors, etc.
    but problem isn't with those components or engineering.
    As an aside I have a rebuilt Lucas MKII unit that fits a BBLM or a 512S/M which I don't need and would sell should anyone need one.
    The Test Bench is very cool. It checks flow at idle and max revs and gives you a place to start.
  13. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    I mentioned before that on one of my DFVs the injection pump was bypassing way too much due to wear in the shuttle sleeve. After repair the engine ran far better at all rpm's. Glad you have found something. I sent mine to the UK FWIW, around $500 a cople years back.
  14. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    #64 brian.s, May 14, 2009
    I hated rebuilding the slides! It is absolutely important to follow the original pattern of ball/rollers and total cleanliness, the gas is enough lubrication (another reason to use the 2 cycle oil).
    i've redone those a couple of times between practices at GPs, once at the Glen and at Monza.
  15. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    We're getting closer. Jim Kinsler rebuilt and cleaned the slide throttles. He flow tested the intake manifold and blueprinted it. (It was off). He rebuilt and flowed the fuel distributor which was WAY off. Sal and him will begin to put it all back tomorrow and I'm hopefull that I'll be test driving her this weekend.
    I'm very impressed with Kinsler.
  16. JCR
    JCR F1 World Champ
    11,109
    H-Town, Tejas
    Yes, he has the reputation as the MFI guy. Keep us posted on the progress.
  17. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Jim also found that the injector nozzles were different and out of spec. Getting them out wasn't easy but he did and he replaced them.
    Should begin to go back together today.
  18. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Glad to hear this is getting itself back together.
    EDIT - didn't mean "itself" - meant glad you guys are getting it back together. Probably at great effort.
  19. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
  20. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Looking great!
    May we expect some vid of the start-up? Pretty please?
    Is that the floor of the new playroom?
  21. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    No car is at a friends shop near Kinsler. From there it will go to Meadowbrook.
  22. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    So glad it's coming back together. It seems that the problem was as on mine, too much clearance in the pump body? these are basically a simple system, but need care to set up and maintain.
    Brian
  23. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    I think that was the major problem. The plumbing was correct. The check valves were OK. The low and high PSI pumps were fine. The intake manual needed work to make it flow evenly and the injectors were shot and dirty so we replaced them. We should be trying to start her in a few hours.
  24. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #74 Napolis, Jul 10, 2009
  25. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,988
    Atlanta
    John!
    That made my Friday. Looks great
