Air Intake Clamps for MAF Sensors | FerrariChat
Discussion in 'Australia' started by JonM, Feb 12, 2019.
  1. JonM
    JonM Karting
    Oct 31, 2017
    132
    South Gippsland, Victoria, Australia
    Jon Maratos
    Hi everyone.
    I'm having issues with my 360 throwing CEL's with a code of P1126. This is basically saying that the mixture is too lean for bank 2. I've tried swapping the pre-cat O2 sensors between banks but still get CEL. Was thinking it might be the MAF sensor on bank 2 so wanted to swap them around and see if the code switches to bank 1 before outlaying the $$ on a new sensor that may not fix the problem.
    The problem I have is the ear clamps that hold the sensor to the rubber, corrugated hose leading to the plenum. I haven't been able to find them anywhere, and although I can use the normal, adjustable clamps for the initial swap, would like to be able to put the ear ones on eventually. I can get smaller ones, but nobody seems to have the 87mm ones that are on it.
    Has anyone managed to find these anywhere in Oz? My alternative is to order them from Eurospares or Scuderia Parts, but seems a bit ridiculous not to be able to source them locally.
    Thanks,
    Jon
  2. knocker
    knocker F1 World Champ
    Jul 10, 2017
    12,306
    Sydney Aus
    Adrian
    A photograph or two might help your search Jon, you never know [emoji12]
  3. knocker
    Jul 10, 2017
    12,306
    Sydney Aus
    Adrian
    Ok cheers Jon in 3 weeks I’ll be ordering an AC condenser from eurospares uk, I’m in Sydney so if you get really stuck I can throw a couple of clamps in the order and for what it’s worth I had an engine check light come on and just rolled bank 1 maf sensor a couple of mill to the left and off goes engine light ,last service no fault codes whatsoever [emoji849] pm me if you want the clamps but it’ll be a month before you’ll get them [emoji106]
    JonM likes this.
  4. Maranello550
    Maranello550 F1 World Champ
    Aug 25, 2011
    12,433
    HongKong
    Gary
    I think Eurospares is free shipping until the 28 th Feb Adrian. So best you order before then otherwise it will cost you an extra 50 quid......
    knocker and greg246 like this.
  5. Maranello550
    Aug 25, 2011
    12,433
    HongKong
    Gary
    Jon phone Pierre from Corsa Veloce in Sydney....He has a huge inventory of 360 parts including complete engines and gearboxes......He might be able to help....
    knocker and JonM like this.
  6. JonM
    JonM Karting
    Oct 31, 2017
    132
    Jon Maratos
    Thanks Gary - hadn't thought about trying mechanics. Might give mine a call first, but will keep Pierre in mind. Jon
    Maranello550 likes this.
  7. knocker
    Jul 10, 2017
    12,306
    Sydney Aus
    Adrian
    Cheers Gary I forgot about that ,good call [emoji106]
  8. F-Serge
    F-Serge Formula 3
    Aug 3, 2004
    1,944
    UAE
    Serge
    Jon, call Nathan at Zagame, he'll get you these clamps over from Italy if they don't have them in stock. Price wise Zag is very competitive.
    JonM and knocker like this.
  9. knocker
    Jul 10, 2017
    12,306
    Sydney Aus
    Adrian
    True he’s very helpful [emoji106]
    JonM likes this.
  10. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,838
    Burradoo... Actually
    Graeme
    Why are you using those cheap crap clamps, only because they are what Ferrari use?, they only used them for speed of assembly.
    Norma clamps are the way to go, similar ones are used on the V12 cars.
    Don’t use the ones with slotted thread section, Norma clamps don’t cut what’s under them.
  11. MonsterCro
    MonsterCro Formula Junior
    Mar 4, 2014
    599
    Sydney Australia
    Steve
    maybe he wants to enter a concours or better yet get classiche. You don't want to lose points from not having the correct hose clamps:D
    imagine a 360 with a red book:D
  12. IanB
    IanB F1 World Champ
    Jun 15, 2006
    16,223
    Unfortunately post 456 V12's use the same single-use clamps. You're correct about assembly speed, but they also cannot loosen and provide an instant indication of failure. e.g. they're much safer for fuel lines than a screw clamp.
  13. JonM
    JonM Karting
    Oct 31, 2017
    132
    Jon Maratos
    You're right, I'm only wanting to use them as that is what Ferrari uses, and I want the car to be as original as possible. That said, I'm prepared to look at alternatives, but looked at the Norma website and they seem to make about 40 different clamps, including ear clamps, so not sure which one in particular you are recommending.
  14. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,838
    Graeme
    JonM likes this.
  15. 360 Kiwi
    360 Kiwi Karting
    Mar 11, 2010
    66
    Christchurch
    Wayne
    Hose clamps do the job ok but they are a bit wider than the factory clamps.
    JonM likes this.
  16. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,838
    Graeme
    The nice thing about Norma clamps they are narrower than the garden variety
