Air Temp Sensor??? | FerrariChat
Air Temp Sensor???
Discussion in 'LamborghiniChat.com' started by the Wizard, Nov 19, 2012.
  1. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    #1 the Wizard, Nov 19, 2012
    Hey guys,
    My 99 SV threw a code for the intake air temp sensor. I switched the right and left sensors, and the code switched sides. I think I was told a while back that this particular sensor is rare and expensive ($300). Seems strange cause its such a simple sensor?
    Anyway I noticed this one on eBay, that says is for a 98 Diablo. Is the 98 air temp sensor the same as the 99?
    http://www.ebay.com/itm/AIRTEX-5S1054-Air-...p=mtr#vi-ilComp
    Anyone know anything about it? The store selling it knew nothing, and even when I called the manufacturer they said they actually buy this one and only know it fits some Kias?
    Ross
  2. exwpart
    exwpart Rookie
    Oct 9, 2011
    11
    #2 exwpart, Nov 20, 2012
  3. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
  4. gday
    gday Formula 3
    Sep 10, 2004
    1,086
    CA, USA - NSW, AUS
    Mick
    Not 100% certain but I think the same part is used on all Diablos and many Murci's.
    -mick
  5. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Is this part commonly available? Guess I could make a call, but anyone know?
  6. gday
    gday Formula 3
    Sep 10, 2004
    1,086
    CA, USA - NSW, AUS
    Mick
    Yes.
    -mick
  7. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    You know approximately how much?
  8. gday
    gday Formula 3
    Sep 10, 2004
    1,086
    CA, USA - NSW, AUS
    Mick
    Somewhere in between $200 and $300.
    -mick
  9. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Three hundred dollars does not sound all that expensive, given todays times and market.
  10. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Are you fkin kiddin'? The one on eBay is $22.08.
  11. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    And all this is is a tiny variable resistance temp sensor, tiny in size, and probably on every other car......
  12. gday
    gday Formula 3
    Sep 10, 2004
    1,086
    CA, USA - NSW, AUS
    Mick
    In a generic sense that's true but getting one with the correct profile would take a bunch of research.
    -mick
  13. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Why not just buy the one on eBay and compare resistance vs the other you have?
  14. James_Woods
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Maybe L owners have a different attitude than F owners.
    But yes, it was posted in jest...
  15. gday
    gday Formula 3
    Sep 10, 2004
    1,086
    CA, USA - NSW, AUS
    Mick
    You will need to know the full R vs. T curve i.e. the resistance cold, the resistance hot and then is the change linear, logarithmic etc.
    -mick
  16. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
  17. gday
    gday Formula 3
    Sep 10, 2004
    1,086
    CA, USA - NSW, AUS
    Mick
    There is tons of stuff on ebay and other misc. web sites that show cross reference listing to Lamborghini parts that simply are not. Not passing judgment on this part but it would be a least caveat emptor.
    -mick
  18. Laust
    Laust Rookie
    Aug 23, 2011
    45
    I don’t have specific Diablo parts compatibility knowledge, but:
    The big manufacturers often put their name and part number on the sensors, so I would inspect one of the Manifold Air Temperature (MAT) sensors for inscriptions and if there Google it to find a direct replacement, circumventing the Lamborghini mark-up.
    Alternatively, just buy one with the correct connector and compare the resistance to that of the remaining good MAT sensor, for example at just 2 temperatures.
    The typical MAT (and coolant) sensors are Negative Temperature Coefficient (NTC) thermistor type sensors with resistance of about 3300 ohms @ 20C and 350 ohms @ 80C.
    The MAT sensors are there to provide small adjustments in fuel delivery and possibly also timing.
    Laust
  19. the Wizard
    the Wizard Karting
    Feb 5, 2008
    64
    Agoura Hills, CA
    Ross IV
    Last,
    I went ahead and ordered one....figured for $20 it'll be a good experiment. I'll do as you say and report back.....
  20. deon.smith
    deon.smith Formula Junior
    Jan 23, 2009
    548
    Oklahoma
    I believe you might need 7M919529A.
  21. gday
    gday Formula 3
    Sep 10, 2004
    1,086
    CA, USA - NSW, AUS
    Mick
    Thats the manifold absolute pressure sensor.
    -mick
  22. deon.smith
    Jan 23, 2009
    548
    Oklahoma
    You are correct. My mistake. 07M919529 will fit:
    Diablo (1991)
    Diablo 6.0 (2001)
    Diablo GT (1999)
    Diablo Roadster (1998)
    Diablo SE30 (1995)
    Diablo SV (1997)
    Diablo SV (1998)
    Diablo SV (1999)
    Murcielago (2003)
    Murcielago Coupe update
    Murcielago Roadster
    Murcielago Roadster update
