430 - Airbag ECU connections | FerrariChat
430 Airbag ECU connections
Discussion in '360/430' started by marc996, Oct 2, 2023.
  1. marc996
    marc996 Karting
    May 12, 2019
    64
    marc bethell
    Hi, I've got an intermittent airbag light on, so assuming its a dodgy connection. I see from the wiring diagram that the ECU is somewhere in the middle of the car and there are connections to the seats. Has anyone got anymore detail on exact locations, I assume the ECU is under the centre consul, but how do you access it?
  2. LorenzoR
    LorenzoR F1 Rookie
    You have to remove the center console. The airbag ecu is under the front center console. IMPORTANT.. Before unplugging an airbag connection make sure you shut off power to the car utilizing the battery cut off switch
    marc996 likes this.
  3. colorfull
    colorfull Formula 3
    2,283
    Franklin Park, New Jersey
    John Napoli
    The ECU has pretty heavy duty connectors and not easy to get to
    If you suspect a wire or connection I would def start with under the seats, connectors are much more fragile and there is seat movement
    If you're US based, you'll also need to check the COPD (weight sensor pad) in the passenger seat
    Is there any particular time it's coming on? Something that is triggering it?
    flash32 likes this.
  4. marc996
    marc996 Karting
    May 12, 2019
    64
    marc bethell
    It's been happening for a while now, originally off more than on, and originally seemed to be triggered when parked outside on hot days, but now it's more on than off with no rhyme or reason.
  5. colorfull
    colorfull Formula 3
    2,283
    John Napoli
    Just taking shots I'm the dark here, but if that is the pattern, maybe something to do with the COPD, since the seat is the only thing that would be affected by an increase in cabin temp, maybe there is some swelling in the seat that caused it to be impacted, again, just a guess.
    Have you tried turning the airbag off with the key switch in the right door jamb just to see if that makes any difference?
    flash32 and EastMemphis like this.
  6. Qavion
    Qavion F1 World Champ
    13,917
    Ian Riddell
    Interesting. I was under the impression that airbag system lights were non- auto resetting. i.e. once the lamp was illuminated due to a fault, it stayed on and Ferrari SD tools were required to extinguish the lamp.
    Experts…. Does the light extinguish if you pull the Airbag fuse or does the instrument panel need to see an ok signal from a powered ECU before it extinguishes the light? Is it possible that the lamp circuit itself is intermittent?
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    I think i would be pulling the battery if messing about with that.
  8. Qavion
    13,917
    Ian Riddell
    It’s interesting to see that the Airbag System is only powered by the ignition, but I think I’d be playing it safe by at least turning off the battery and waiting for the capacitors to discharge.
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    I dont have much faith in a switch in the negative line
  10. Qavion
    13,917
    Ian Riddell
    Given the number of components in the system, the difficulty in accessing these components and the lethality of these components, wouldn’t it be best just to take the car to someone with the proper diagnostic tools?
    Airbag lights can be caused by:
    ECU
    Lamp circuit failure (intermittent or otherwise)
    Passenger seat COPD
    LH Seat belt pretensioner
    RH Seat belt pretensioner
    Driver's airbag (including clockspring)
    Passenger airbag
  11. marc996
    marc996 Karting
    May 12, 2019
    64
    marc bethell
    Switched off the passenger airbag and light still on ☹️ I'm just going to have to try all the connections.
  12. marc996
    marc996 Karting
    May 12, 2019
    64
    marc bethell
    Thanks for info.
    The car was actually in for service at a main dealer last week, so asked them to look at it, but as luck would have it the light didn't stay on when they took it into the service bay
  13. marc996
    marc996 Karting
    May 12, 2019
    64
    marc bethell
    Connected a scanner.
    2 faults in Airbag.
    1. Current. Front airbag drivers side, 1st stage, value too high.
    2. Intermittent. Front airbag drivers side, 1st stage, open circuit.
    Does this mean anything to anyone?
  14. GogglesPisano
    GogglesPisano F1 Rookie
    3,034
    East Bay, California
    Joe
    Some quick digging lead to this:
    https://www.berlingoforum.com/thread-13088.html
    https://www.6speedonline.com/forums/cayenne-958/412704-driver-s-side-airbag-stage-1-2-limit-value-exceeded-anyone-ever-fixed.html
    Both issues correlate the other thread you found citing clock spring.
    I realize those are both not Ferrari but likely use similar components being Euro vehicles and would in turn have similar issues.
    I'd start there.
  15. Qavion
    13,917
    Ian Riddell
    Don’t know what 1st stage is, but there are only 2 wires going to the airbag from the ECU (basically for trigger power and an earth). Since the ECU is difficult to get to, rather than doing resistance checks between the ECU and the airbag, perhaps, as suggested in the links, put a resistor across the pins of the plug going to the airbag. But what I don't understand is how the airbag light can be intermittent. I thought airbag lights were latched on if faults were detected.
    Here's an F430 clockspring with what looks like a broken 2 pin airbag connector.
    The yellow/orange sheathed wiring is for the airbag. The black 8 pin plug goes to the manettino module (for horn, start and manettino functions).
    Here are some other views of unbroken airbag connectors, but it's not clear what kind of latching mechanism they have. Given that the first photo shows a broken plug, they may be difficult to remove (?)
    I don't know how accessible the outer 12 (?) pin plug is to allow you to do wiring checks of the clockspring itself (when fitted to the car). The wiring diagrams suggest that the airbag wiring going to the clockspring outer plug is brown and blue (and the wires are on pins 9 and 10). It looks like the wires are different colours when they come out of the clockspring (going the airbag). Yellow and pink? Or white and red?
    You could do a resistance check across the airbag itself. When doing the checks, maybe insert a known value resistor in series with the airbag wiring to reduce the test voltage going to the airbag from the ohmmeter.
  16. marc996
    marc996 Karting
    May 12, 2019
    64
    marc bethell
    Thanks for everyone that contributed to this post.
    I can now add some light myself, what threw me a little was the fact that I couldn't find a 430 wiring diagram and assumed a 360 was the same, it isn't.
    The clock spring is actually easier to diagnose than I thought. I removed the airbag and steering wheel revealing the clock spring. When you unplug the car side of the clock spring it puts a short cct on the airbag wires, which means you only have to connect a meter to the airbag side connector to measure the resistance of the clock spring. In my case it was all over the shop, sometimes Diss. It turned out to be the front connecter, which I was able to clean.
    Interestingly when I put it all back together the airbag light was off and didn't need resetting (the fault was still in the ecu memory though so I cleared that).
    Qavion likes this.
  17. Qavion
    13,917
    Ian Riddell
    Great tip, thanks. So 1.6 ~1.9 ohms sounds like a good target value for the self-shorting connector.
    Seems like an improvement on earlier Ferraris. Maybe only certain airbag faults are non-resettable.
    Was the purple/yellow connector easy to remove?
    The Ferrari F430 airbag wiring diagrams only include the wiring to the car side connector anyway
  18. Qavion
    13,917
    Ian Riddell
    I see now that photos of the spring contacts inside the plug confirm the pin numbering system of the plug. Pins 9 & 10 short via the spring contacts. The correlates to the limited information in the wiring diagrams.
    It's a pity you didn't do any other wiring checks to see which pins on the 12 pin plug on the car side (D072) of the clock spring match the 8 & 2 pin plugs on the wheel side (EM37 and airbag plug). Pins 1~8 on the 12 pin plug may not correspond to pins 1~8 on the 8 pin plug.
    The are noticeable wire colour changes going in and coming out.
    e.g. pins 9 and 10 (airbag wires) on D072 are white/blue and brown/white going in and white and pink coming out. I don't know which corresponds to which.
