AIRBAG ECUs DEFECTIVE! | FerrariChat
Discussion in 'Technical Q&A' started by ExcelsiorZ, Feb 3, 2010.
  1. ExcelsiorZ
    ExcelsiorZ Formula 3
    1,267
    Beverly Hills
    My mechanic, a well respected Ferrari specialist in Los Angeles with celbertiy clients, tells me the Airbag ECU used in the F355, 550 and 456 is essentially defective. He says he's replaced half a dozen of them and that the usual cause is simply trying to start the car with a low battery. Yesterday while at his shop we were cycling the top to eliminate air from the system. He asked me to start the car. It went click-click and he then said "Don't!" but it then started before I could release the key. With the car now running he said starting the 355-456-550 can fry the Airbag ECU. Sure enough, the Airbag light came on. He hooked the computer to the car and tried to reset the light but the error code persisted indicating ECU failure. Has anyone else experienced this? I think it is BS. I spoke to Odessy the battery manufacturer and they told me Ferrari was shipping new Ferraris with bigger batteries because Ferrari knew their onboard systems would drain the battery. I was told that nearly every Ferrari arriving at the dock needs to be jump started because of a low or dead battery! Moreover, as Ferraris are not daily drivers they tend to sit making them even more vulnerable to a low battery condition. If this appears to be a defect, and given my mechanic's information and given the fact Ferrari issued a revised ECU later on, I'm suspecting it is, I believe Ferrari owners should be advised of this very expensive situations and remedies made available. Please let me know if you too have experienced an airbag ECU failure.
  2. Rifledriver
    37,345
    #3 Rifledriver, Feb 3, 2010
    This is not news. That airbag system is shared by many cars by the way and is made by TRW, possibly the biggest automotive supplier in the world.
    Shopping for a class action suit possibly?
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    If it wasn't for low quality, there'd be none. ;)
  4. ExcelsiorZ
    1,267
    Beverly Hills
    Yes, but how many times has a person with a Mercedes or BMW started their car with a low battery only to discover they've just burned out a $x,xxx.xx ECU?
    Also note, the TRW original part number is now superceded.
    I don't want a class action, I want Ferrari to stand behind their product.
  5. Rifledriver
    37,345
    A. Quite a few times I suspect.
    B. Meaning what? They also superceded the original air filter number.
    C. They do. The car came with a warranty.
  6. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    They do, but you would need the Hubble telescope to see them.
  7. RRRREDRVR
    RRRREDRVR Karting
    Jul 28, 2004
    135
    Aptos CA
    M Kitchen
    My airbag ECU failed at 40K miles, and my battery wasn't even low. The light just came on after a normal start. Replacing the ECU seemed to fix it. The car is still at the shop on other work, and I plan to get the ECU back and do my own failure analysis, if possible. I've heard of several others with the same problem.
    '95 F355GTS
  8. tech4ferrari
    tech4ferrari Karting
    Jan 22, 2010
    234
    Mt Airy N,C
    casey johnson
    just replaced one last week for the same reason, car came in dead and there was a set of his jumper cables in the front seat, replaced battery, started car and bam...air bag light that would not clear...customer was pissed!!! tried to blame it on me :-( oh well, what can you do!?!?
  9. ExcelsiorZ
    1,267
    Beverly Hills
    THanks. The more information I get, the more ammunition I'll have to approach Ferrari with about making this right!
  10. fatbillybob
    Aug 10, 2002
    29,410
    socal
    Well since you know a ferrari can't be fixed to solve this problem the next logical question is what is the TRW part# of the ECU that works in some other car so we don't have to pay the ferrari tax?
  11. FerrariDeeJay
    FerrariDeeJay Formula Junior
    Jun 2, 2009
    418
    Chino, CA
    Michael
    Mine went dead at about 12k on my 1995 355 Spider. Cause-low battery as well.
  12. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,634
    The Brickyard
    The Bad Guy
    348's don't have this problem.
    :D
  13. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    I have a failed ECU from my 97 F355 Spider on my desk. I'll try to get to the hardware store this Saturday to buy the special bit so that I can open it and see what I can find inside.
  14. eric355
    eric355 Formula 3
    BANNED Silver Subscribed
    Nov 30, 2005
    1,223
    Toulouse (France)
    Eric DECOUX
    #16 eric355, Feb 4, 2010
    Please, can you post some pictures Tom? I'll be glad to see them.
    Probably the high voltage DC/DC converter is faulty and I am curious to see how it is designed and built.
  15. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    I will try to get to it this weekend and post some pictures. Around watching the Colts win the Superbowl that is... :)
  16. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    #18 Loser, Feb 4, 2010
  17. KKSBA
    KKSBA F1 World Champ
    15,303
    SBarbara-La Jolla CA
    KKSBA
    #19 KKSBA, Feb 4, 2010
    Three caps to hold a charge to blow the bag, and a voltage regulator in the heatsink.
    According to Rifledriver, its the caps or the charge controller that frys.
    Pry off the heatsink on the regulator and lets see the part # on that.
    Do you notice any burn marks near the caps or brownish goo on them anywhere?
  18. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    After further examination, it seems that the white component is actually an impact sensor. The metal case that the circuit board was installed in has an arrow on it saying "Forward" indicating that it must be installed in a certain direction. If you hit the box on the forward side, the slider inside of the white component moves. It seems to be on a spring. It is normally contacting two double terminals towards the center of the circuit board creating 1K ohm between the terminals. The resistance to the terminal at the other end is >20MOhms. I'm not sure if the resistance at the other end changes as the slider slides, or maybe it should be something less than 20MOhms normally. I usually suspect mechanical components first when this type of circuit fails. Especially since it is subjected to the vibrations of driving. I might try to cut the top off of the box to see inside it at some point over the weekend.
  19. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    There appear to be several voltage regulators on the board. I am assuming you mean the brown device that is mounted vertically and encased in a stainless steel heat sink/mounting bracket.
  20. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    I will have to unsolder the heatsink first which is more than I have time for right now.
  21. KKSBA
    15,303
    KKSBA
    #23 KKSBA, Feb 4, 2010
    Yes, that is the primary power regulator since it dissipates the most heat. I don't have any experience with Airbag ECU's, but I would say that is the most suspicious part if the Caps don't look burned.
    We might be able to find a simple fix for all these fried ECU's...
    Of course, if it is one of the microcontrollers, that's probably the end of the line because of difficult parts availability.
  22. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    The capacitors all seem to be fine as far as physical appearance.
  23. 355Aloha
    355Aloha Karting
    Feb 15, 2004
    120
    Honolulu Hawaii
    John N
    #25 355Aloha, Feb 5, 2010
    We should all stand together against Ferrari about this problem.
    The dealers say, it is not a problem, they get big dollars every time the ECU fails.
    The independent service providers say they see it all the time.
    If we get together we can get this problem resolved. We can also go to the BBB in New York and fill complaints against FNA.
