AIRBAG ECUs DEFECTIVE! | Page 3 | FerrariChat
Discussion in 'Technical Q&A' started by ExcelsiorZ, Feb 3, 2010.
  1. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    #51 Loser, Feb 5, 2010
  2. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #52 eulk328, Feb 5, 2010
    If they actually eliminate any spark when the last connection is made I would sure think they must be doing something (and likely something beneficial). The price certainly seems reasonable.
    The simple fact that they will "save you" from incorrect polarity connection makes them worth every penny, and then some, in my book (even if they did nothing else). What does in cost to get the diodes replaced in an alternator? What about serious acid burns or worse if you're jumping a typical car, where the battery is not hidden in the wheel well, and it explodes from reversed polarity?
    http://www.amazon.com/Michelin-5100-.../dp/B002RRZX06
  3. UConn Husky
    UConn Husky F1 Rookie
    4,425
    CT
    Jay
    NICE work guys!!!! Great thread here...I never even knew this was an issue. Now I'll make sure the battery is charged good before trying to crank it over.
  4. fatbillybob
    Aug 10, 2002
    29,413
    socal
    never seen surge protection for a car. How does it work? Something you made or something you bought?
  5. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #55 eulk328, Feb 5, 2010
  6. KKSBA
    KKSBA F1 World Champ
    15,303
    SBarbara-La Jolla CA
    KKSBA
    That's pretty cool. But, who has tested it in their Ferrari to see if it doesn't blow an ECU when your low on battery and need to jump.
    Have you had to jump start since you put it in? Anyone?
  7. KKSBA
    15,303
    KKSBA
    #57 KKSBA, Feb 5, 2010
    I tried to lookup the Airbag ECU in the 355 schematics. Of course, it's not listed. The airbag light is, and it will take time to trace it with all the page-offs.
    I love how some items are listed in the Italian legend but not the English. Those Italians, they have such a sense of humor.
    I did some research. The official term is ACU (airbag control unit) but ECU works too and TRW makes them, but their newest one only resembles this one but is obviously a later rev. I couldn't find info on their older units. None of the PCB designators match anything.
    I did find ACU repair guys. Just google "Airbag ECU repair". And several will pop up. I didn't see any American ones though, liability?
    That made me think deeper about this.
    It might be fun to figure out what went wrong for that knowledge, but we don't have an "ACU tester" so once we repair it we will not know if it will work properly and under all conditions.
    Plus, who wants to plug this sucker in after it has been "repaired - IE the light is off" and have it fire an airbag inadvertenly.
    And, you can't sell it on eBay either since you will have liability if it does something bad.
    Maybe its best to leave the repair to companies that have the experience, and the test protocols for it.
    One interesting thing I saw, was a reference that because of the high price of ACU's they are being keyed to the car to prevent theft. I don't know which cars this applies to.
    Lets get the part# for the regulator and see what it is.
  8. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #58 eulk328, Feb 5, 2010
    I cannot say if they work or not. I do suspect they are very simple inside and probably use components that cost very little (big profit margin). It's a small amount of money (if it works) versus the price of any ECU. I know some people that weld on cars use them and others say just disconnecting the car battery is fine. Could be snake oil..... don't know for sure. I'm pretty sure you're not going to find anyone willing to purposely test it on their Ferrari.
  9. KKSBA
    15,303
    KKSBA
    I'm pretty sure your right.
  10. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    Apparently my soldering iron isn't powerful enough to overcome the heatsink, so I need to buy a more powerful one. More later...
  11. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    #61 ferraridriver, Feb 5, 2010
  12. KKSBA
    15,303
    KKSBA
    Its too bad TRW didn't hire someone like you to be part of the design team. Makes complete sense to me.
  13. ferraridriver
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    Or maybe have the air bag ECU powered via a relay with the relay activated by the speedometer sensor. If the speedo sensor signal is powerful enough to activate a relay it could be done with a relay and two diodes.
    That way the air bag ECU would be powered up when the car first moved and stay powered until the key was turned off.
  14. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,700
    San Carlos, CA
    Mitchell Le
    All of these are good ideas, after the fact. If they had known the cause of the problem, they would have designed a simple time delay circuit to solve it. Ferrari with its small volume would not have tried to go back and clean up the problem after production, especially when the problem results in more money for them.
  15. KKSBA
    15,303
    KKSBA
    It appears this is a TRW ACU and would be destined for more cars than just Ferrari. It's to early to say it is not Ferrari influenced, but it wouldn't surprise me to hear that this ACU was not specially designed for Ferrari.
  16. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Understood. And has been noted, just protecting against sparks/reversed polarity is "progress".
    I'd just like a "definitive" answer to the "will they protect my electronics? question - I'm guessing they could charge a small fortune if they offered a warranty covering any parts destroyed as a result of using 'em......
    Cheers,
    Ian
  17. tbakowsky
    Sep 18, 2002
    20,081
    The Cold North
    Tom
    That ECU is used in MANY cars. Its programed differently for different applications. Trouble is, once you have repaired the thing, you still need the correct scan tool to clear the airbag light..in Ferrari's case the SD2.
    IMHO, messing around with this thing is kinda dangerous. Lets say it works out for you, but a week later your driving along you favorite road in the middle of your favorite twisty section, and BLAM..off go the airbags, and your into a tree or worse!!
    Tempering with an airbag system is HIGHLY ILLEGAL..in Canada anyway.
    The other thing you MUST realize..DO NOT under any circumstances use a test light anywhere in the circuit. Use a high impedance meter to test the system.
    I would buy the correct unit along with the updated harness from Ferrari, install it yourself, then take the car to the dealer to have it set-up and cleared. You'll be good for another 13 years..IF YOU DON'T BOOST THE CAR!!!!
  18. ExcelsiorZ
    ExcelsiorZ Formula 3
    1,267
    Beverly Hills
    Clearing the airbag light isn't such a big deal. It takes literally just a few minutes.
    This ECU may be "like" other Airbag ECUs but lets be serious here for a moment. On Ebay all ECUs for airbags are typically $50-$60. Range Rover and E46 M3 ECUs listed at $99. I suspect new these ECUs are pretty cheap for most cars. If I could replace my ECU in the Ferrari for that cost level this wouldn't be an issue. However, the Ferrari ECU on Ebay is over $1200.
    Also, I've owned and jumped BMW, Mercedes, Porsche, etc., and at one point or another jumped from a low or dead battery. Never blew an ECU. Two nights ago I jumped a neighbors C70 Volvo. No airbag light!
    If this had been a GM or Toyota problem it would be all over the news! Unfortunately, most Ferrari owners bow down to Ferrari with lower expectations, as if Ferrari was doing them a favor by letting them drive one of their cars.
    I wonder how NHTSA would view this problem. I think starting a car with a low battery, particularly a car not intended to be a daily driver, is to be expected. I don't think an ECU for a critical safety component should be acceptable given the existing government regs. I'll be calling NHTSA and the DOT on Monday.
  19. tajaro
    tajaro Formula Junior
    Mar 22, 2009
    686
    Gulfport Florida
    Erik V
    #69 tajaro, Feb 6, 2010
    OK- you guys have scared me enough to do something. I will certainly remember- but you never know what could happen so a simple 2" x 4" sticker on the battery and wheelhouse might stop a tragedy...
  20. ExcelsiorZ
    1,267
    Beverly Hills
    Brilliant! Yes sir! Warning appropriate and failure to warn noted ;)
  21. CraigFL
    CraigFL Formula Junior
    Jan 17, 2001
    954
    Panama City, FL
    Craig
    If I were going to take a guess at what is happening...
    I suspect that the battery acts like a heavy duty voltage regulator when it's charged and working correctly. If the battery is low, it doesn't, so when you crank the starter, which is a very high inductance, you generate high voltage spikes that aren't supressed by the battery and this is what kills the ACU. I suspect we could use some kind of capacitor or surge supressor like a transzorb on the voltage supply to this unit to keep this from happening.
    Now as to what actually fried during the spike is up for another guess. Most modern electrical circuits, especially those designed for cars are set up to handle things like this. So I'm not sure why this is a problem other than maybe the battery location in relation to the starter and how they are wired. It just may be the chip is gone and the system essentially unrepairable.
  22. speedmoore
    speedmoore Formula 3
    Apr 15, 2003
    1,541
    Austin, Texas
    D Moore
    Replaced 3 last year all in 355s and saw 2 more clients declined to replace putting it on buyer they were selling car to with the firm note air bag ecu needed replacing at $1700 plus R&R
  23. ExcelsiorZ
    1,267
    Beverly Hills
    While the ECU may be by TRW, the wiring to it, including the power surges caused by that wiring are pure Ferrari.
  24. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    In general, I think Ferrari owners have shot themselves in the collective feet by not actually driving the stinking cars during the covered period. I mean, if people put 10k miles a year on them, think how many more things would be sorted before the warranty ran out?
    Of course the guys buying them new are not the guys complaining now. They are too busy enjoying scuds and calis.
  25. f355spider
    f355spider F1 World Champ
    18,059
    Along with a battery tender, get yourself a top notch battery too. The top rated battery from Consumer Reports is the Sears Platinum absorbed glass mat battery (AGM). Totally sealed, never needs water, will never leak electrolyte. It is an 880 cold cranking amp brute with a four year free replacement warranty. Only sold in a Group 34, it will fit in a 355, even though the terminals are not reversed like the oem battery. Fortunately the battery cables are long enough to reach anyway.
    http://www.sears.com/shc/s/p_10153_12605_02850034000P
    I believe this battery is made by Odessey.
