Aircon leak | FerrariChat
Aircon leak
Discussion in '456/550/575' started by asalcedo, Dec 15, 2016.
  1. asalcedo
    asalcedo Karting
    Mar 20, 2005
    67
    I have recharged twice in a week the air conditioning circuit in my 550 of 1998.
    The mechanic (not a Ferrari one) used a modern machine (Bosch I think he mentioned) that attempts to detect leaks (but it did not) and used gas with a dye that leaves marks where it leaks.
    After carefully inspecting the visible aircon circuit they did not see any leaks.
    He says that to find the leak they need to remove parts to access the hidden parts of the circuit which may imply a good number of hours.
    Is there a spot that fails more typically that I can tell him to check first?
    Is this something that a non Ferrari specialized (but very experienced) mechanic can do?
  2. maranello72
    maranello72 Formula Junior
    Jul 4, 2009
    354
    Munich, Germany
    Stefano
    Did you check the front seal of the AC compressor as well? When that fails oil and gas leak out quickly.
    Good luck,
    Stefano
  3. Rifledriver
    37,105
    The compressors are junk and leak like a sieve. About 50% of the cars that come here for the first time, the compressor is soaking wet. I have them rebuilt regularly.
    If it comes to needing to take anything apart to fix it I would say it is very foolish not to have a Ferrari guy do it.
  4. asalcedo
    asalcedo Karting
    Mar 20, 2005
    67
    Yeap. The mechanic confirmed that the compressor needs to be replaced. There is a significant leak in between the two halves.
    What's the part number for the compressor?
    I do not see it in diagram Ferrari 550 Maranello - Air Conditioning System: Page 056 | Order Online Eurospares
    Thank you
  5. Rifledriver
    37,105
  6. asalcedo
    asalcedo Karting
    Mar 20, 2005
    67
    I am in London, UK. Can I have it rebuilt here?
  7. Rifledriver
    37,105
    I certainly would not be the person to ask. Ask your Ferrari mechanic. If he really is a Ferrari mechanic he will have done many and if he is not a real Ferrari mechanic you probably don't want him removing it.
